DIY $1300 Anti-Griddle for Under $15
Intro: DIY $1300 Anti-Griddle for Under $15
An anti-griddle is an expensive kitchen appliance that flash freezes or semi-freezes foods placed on its chilled metal top part. It's part of the molecular gastronomy movement and used to create all sorts of elaborate dishes, often with a frozen outer, soft inner consistency. Please add other cool ways to use an anti-griddle in the comments below!
STEP 1: Acquire Dry Ice
If you pick-up from the manufacturer, it's about 40 cents/lb. You'll want as much surface area of the ice exposed, so opt for the pellets, if available. If not, use a hammer to break the blocks into pieces. I always ensure my windows are rolled all the way down when I drive this stuff home. Keeping your car free of carbon dioxide is crucial to the rest of this instructable (and your life.)
STEP 2: Mix Dry Ice and Alcohol
Add 90-100% isopropyl alcohol (rubbing alcohol, fuel additive, etc.) to dry ice until it forms a sludge. This lowers the freezing temperature of the dry ice below -100 degrees Fahrenheit. That's getting close to liquid nitrogen, so you can use this concoction to burn off warts too. Unlike liquid nitrogen, this stuff will not simply evaporate upon touching skin, it will stick like glue. So be very careful. Mix in an insulated container in a well-ventilated area with proper safety equipment.
STEP 3: Place a Metal Tray on Top of Freezing Sludge
Pour this freezing slurry onto a baking sheet and place another baking sheet on top. In less than ten minutes, this top sheet will start to form a layer of frost.
STEP 4: Proceed to Use As You Would a $1300 Anti-griddle!
I made these frozen thin-mint pancakes by blending almond milk, banana and a couple thin mint Girl Scout cookies. They were delicious. Happy freezing!
STEP 5: Other Cool Uses for Dry Ice and Isopropyl Alcohol Mixture:
Use this freezing sludge as you would liquid nitrogen: remove unsightly skin lesions, rapidly freeze food products, cryopreserve blood or reproductive cells, brand cattle or your buddies, and even promession (yikes.)
13 Comments
Jobar007 9 years ago
Denatured alcohol would be a good substitute to Isopropyl alcohol. It is common and tends to not be diluted (it is "denatured" by methanol, typically).
How fast does it take to freeze things (like your "cookies")? What about thin cuts of meat? How long before you have to "recharge" your griddle?
Sorry for so many questions, but this sparks so many ideas!
jeff.verive 3 years ago
Jobar007 3 years ago
mart33n33 9 years ago
JDB16 5 years ago
SiafaA 8 years ago
Is the finished "anti-griddle" safe for indoor use?
mikemania 8 years ago
How do you clean up the leftover dry ice/alcohol mix? Can you just wash what's left into the drain?
mart33n33 8 years ago
dlowe5 8 years ago
Somethingtotallyrandom 9 years ago
That was interesting. Thanks for providing it!
PSA: Rubbing Alcohol is typically a 70% alcohol to 30% water solution.
tomatoskins 9 years ago
This is awesome! I'd love to see something made with this!
