DIY Foldable Wooden Tray for Sofa
Intro: DIY Foldable Wooden Tray for Sofa
Until recently, there were no hard surfaces near Steph's couch to set snacks and beverages. We had seen this idea for a flexible hard surface on Pinterest and decided to give it a try!
We grabbed some wood molding and sticky felt and got to work!
Be sure to watch the video, it's really short, but it gives you the entire rundown on how to make one. It can be customized to whatever size you need.
Full supply list on our website here.
STEP 1: Watch Video!
For more projects from us, please join our weekly newsletter list here.
STEP 2: Cut & Sand Screen Molding
The tray is made with 25 pieces of screen molding all cut to 12" each.
Mark the first piece at 12" and cut in a miter box with a saw. This piece can now be used to measure all the rest of the pieces.
Using a piece of 150 grit sandpaper, sand any rough ends and edges. Remove the paper labels from the back of the pieces.
STEP 3: Stain or Paint Wood
If you're staining your tray do that now, let dry, then add a protective finish.
STEP 4: Add Sticky Felt to Back
Lay the pieces right side down, line the ends up with a straight edge like a ruler.
Remove the protective paper from the self-stick felt and put on the back and you're done!
STEP 5: Done!
This is a quick project that uses few tools and techniques. It makes a great gift! The size can be customized as well as the finishes to suit the recipient.
For more detail, please visit our website, MotherDaughterProjects.com
26 Comments
rjslsmith64 1 year ago
edmatthews2010 2 years ago
rsnowdale 3 years ago
DIY for Homeowners 3 years ago
LeslieGeee 3 years ago
wes_van 3 years ago
georgemorgan 3 years ago
LADY DIXIE T 3 years ago
RajendraKumarS 3 years ago
lnxusr 3 years ago
ChrisWx 3 years ago
Brush a decent layer of wood glue (but not drippy - read last paragraph!) onto the back of each wooden slat, and place it glue side down on the canvas. Glue and place all the slats close together, removing any glue that squeezes between the slats with a wet rag. Once all the slats are placed, get a board or book that will cover the whole 'tray' and place it on top. Stack some heavy items evenly on top of the board. This will ensure the glue is pressed well into the canvas and prevent any movement while it dries.
You can now trim the canvas as close as you like to the wooden slats. Once trimmed, put some of that same wood glue in a cup or small bowl, and add a little water to thin it out. Apply it to the cut edges of the canvas - just enough to get it wet. A foam brush works best, but you can even use your finger.
Unless you chose a really heavy canvas, the glue may show through on the back - not very attractive. You can use the sticky-backed felt to cover it, or any other cloth with iron-on basting tape. Take care, though. If a lot of glue soaked through the canvas, the felt may not stick well. Even basting tape might not adhere for very long. This is the reason for recommending 12 oz. canvas.
BakerBoy7 3 years ago
asrcav8r 3 years ago
