DIY Front Surface Mirror
Intro: DIY Front Surface Mirror
I see there is a lot of laser enthusiasts on this site (including myself), so
I decided to share some of my experience of making front surface mirror.
Original idea belongs to
I used acrylic mirror for my design.
It's not the best solution but it's very easy and safe to work with and quality of mirror would be acceptable for most laser/optic applications.
So if you are interested, check out my materials:
Here's my another, more advanced, method of making FS mirrors using
Winning Colors Stain Remover.
This safe and reliable method works with any acrylic or glass mirror.
STEP 1: 1.
Procedure is simple.
Put on safety glasses and gloves.
Cut piece you need.
Cut piece you need.
STEP 2: 2.
Shape it.
STEP 3: Remove Protective Paint From Back Side of Mirror
At first use paint remover. I think any kind will work well.
Just one thing to remember. It will dissolve acrylic, so work fast and carefully.
You can use masking tape to protect plastic from contact with paint remover.
Check back side of mirror for scratches, dents, etc...
If reflective coating is damaged from back side, paint remover will go to plastic base and pop mirror foil up.
Next, use acetone to wipe off remains of paint remover and finish cleaning.
Reflective coating is very thin, so handle it accordingly.
UPDATE !!!
Since I've discovered Winning Colors Stain Remover I stopped using any other chemicals.
It's non toxic, environment friendly, water based liquid which will not harm acrylic and your skin.
Now procedure is even easier:
1. Pour Winning Colors Stain Remover into proper container.
2. Drop mirror into container. Painted side up.
3. Let it soak for 30 min or more (time may depend on back paint and size of mirror).
4. If paint got loose and started peeling off, remove mirror and put into container filled with tap water or rinse it under water stream. You may use cotton balls and gently swab mirror while it immersed. Optional step is to rinse mirror with steam distilled water in order to remove any particle left from tap water.
5. Pour remaining liquid back into bottle for future use.
29 Comments
mcm1303 11 years ago
How long do these front surface mirrors last? My understanding is if they are made with Silver Nitrate they will oxidize(?) or darken within a short period of time. Is that the case with acrylic mirror?
noahspurrier 7 years ago
AP Digital light 11 years ago
chaydgb 9 years ago
I would never have thought of doing this! In the absence of paint remover, I looked for alternatives, and found that carburettor cleaner also works.
ivelin 9 years ago
Thanks a lot, just as I was contemplating making a silver mirror (which involves a lot of nasty chemicals and is generally quite a job) I bumped into this, 30 minutes later and I have a beautiful mirror for my vintage camera!
sgt_rock 12 years ago
erniehatt 13 years ago
Im looking, will post If I find anything. Ernie
bratan 13 years ago
Vickal89 13 years ago
Can you tell me which product is similar to this "Winner Colors Stain Remover"? I tried paint thinner (ruins my acryl mirror) or kitchen oil/fat cleaner (doensnt work at all), but it all fails.
I want to avoid to run to the homeworker store thousand times always buying the wrong thing. Can you tell me which features this product must have? Unfortunaly I dont live in US so we dont have "Winner Colors". But I am looking for something similar.
Can I use nail enamel remover for this?
Thank you for your tutorial btw. Its great!
Works pretty well with nail paint remover. Have to scratch though, but the mirror surface is more persistant than on glass than on acryl.
AP Digital light 13 years ago
After paint's got loose, wash mirror under stream of water and use cotton swab to clean mirror's surface.
It always needs time to discover proper stuff. Google your local painting/cleaning suppliers and try to find WATER based paint or stain remover.
Water based solution shouldn't dissolve acrylic ind it's much safer to work with.
bratan 13 years ago
bratan 13 years ago
katzmatt 15 years ago
AP Digital light 15 years ago
lemursquad 15 years ago
