DIY LiPo Charge/Protect/5V Boost Circuit
Intro: DIY LiPo Charge/Protect/5V Boost Circuit
In this video I will show you how I combined a couple of ICs in order to create a charge/protect/5V boost circuit for a single cell LiPo battery. Along the way I will show you how I designed the PCB, how I ordered it and what kind of problems occured while soldering the components and testing the circuit. Let's get started!
STEP 1: Watch the Video!
The video gives you all the information you need to create your own Charge/Protect/Boost circuit. In the next steps though I will present you some additional, helpful information.
STEP 2: Order the Components!
Here is the parts list of the circuit with links to where I ordered them.
SS34 Schottky Diode: https://lcsc.com/product-detail/Schottky-Barrier-D...
22µH Inductor: https://lcsc.com/product-detail/Power-Inductors_Re...
FS312F-G Protection IC: https://lcsc.com/product-detail/Battery-Protection...
MT3608 Boost Converter IC: https://lcsc.com/product-detail/DC-DC-Converters_A...
Red LED 0603: https://lcsc.com/product-detail/Light-Emitting-Dio...
Micro USB Port: https://lcsc.com/product-detail/Micro-USB-Connecto...
Green LED 0603: https://lcsc.com/product-detail/Light-Emitting-Dio...
TP4056 CC/CV Charge IC: https://lcsc.com/product-detail/PMIC-Battery-Manag...
7.5k Resistor: https://lcsc.com/product-detail/Chip-Resistor-Surf...
100 Resistor: https://lcsc.com/product-detail/Chip-Resistor-Surf...
1k Resistor: https://lcsc.com/product-detail/Chip-Resistor-Surf...
2k Resistor: https://lcsc.com/product-detail/Chip-Resistor-Surf...
22µF Capacitor: https://lcsc.com/product-detail/Multilayer-Ceramic...
FS8205 MOSFET IC: https://lcsc.com/product-detail/MOSFET_FORTUNE_FS8...
Toggle Switch: https://lcsc.com/product-detail/Toggle-Switches_Re...
0.1µF Capacitor: https://lcsc.com/product-detail/Multilayer-Ceramic...
10µF Capacitor: https://lcsc.com/product-detail/Multilayer-Ceramic...
STEP 3: Create the Circuit/Order the PCB
Here you can find the schematic of the circuit and the Gerber files. You can use them to order the PCBs with JLCPCB: https://jlcpcb.com/order/pcb
Or you can simply open my EasyEDA project with my board design and click the fabrication output button: https://easyeda.com/GreatScott/LiPoChargeProtectBo...
Once you receive the PCBs, all you have to do is solder the components to it with the help of the schematic.
STEP 4: Success!
You did it! You just created your own LiPo Charge/Protect/5V Boost circuit
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
26 Comments
lucylily 5 years ago
Don't waste your time on this. It's nothing more than an a PCB vendor promotion.This is yet another junk circuit from JLCPCB.I got PCB from jlcpcb, but cannot
recommend them (cheap, but bad quality)
CosmiChild 3 months ago
Do not listen to @lucyilly.
JLCPCB provides very good quality for years, same as PCBWay so he doesn't even know what he is talking about...
TanmayB23 3 years ago
Rubines 6 years ago
I modded the device to 12V, but unfortunately the step up driver gets very hot when it is loaded with a 400mAh load. I added a heat sink so the circuit does not enter the overheat shut down protection but it still gets very hot. I added a thermal image after using it for 10 minutes. You see around the step up switcher ic, the temp is at 70 degree Celsius.
FixDaily 5 years ago
You have to change R2= 1K and R3=7.5K and you also need to replace the IC, you probably have a short to GND on IN pin.
MennoLabs 3 years ago
Check the datasheet for the boost converter.
https://lcsc.com/product-detail/DC-DC-Converters_AEROSEMI_MT3608_MT3608_C84817.html
Vout = Vref x (1 + R1/R2)
Vref = 0,6V.
So with R1 = 7.5K and R2 = 1K:
0.6 x (1 + 7.5/1) = 0.6 x 8.5 = 5.1.
And R1 and R2 are R2 and R3 on the board.
Thanks
MennoLabs 4 years ago
Vref = 0,6V.
Uuff 4 years ago
I would like to use this circuit as a power supply for my small project. I need to be able to run Arduino from the battery and, when connected [in my case USB], automatically switch Arduino to USB and charge the battery. is this circuit capable, or can you advise me please.
Thank you in advance for your reply.
deahansteyn 4 years ago
The https://www.instructables.com/id/DIY-LiPo-ChargeProtect5V-Boost-Circuit/ website lists 17 parts and in the Bom it lists 21 parts.
I want to build it is there a way to make output current variable aka adjustable that would be awesome to support more lipo and liion battery's.GreatScott aka Back To The Future ahahaah
KCM5 5 years ago
I know this was posted months ago, so I apologize for necromancing this thread.
In the parts list, two 22uF ceramic capacitors in package size 1812 were used. But of all the components, these LCSC #C28504 are the most expensive - 0.81 USD at the time of this writing. If you wanted to build 10 of these boards, you're nearly $15 USD just for these capacitors.
I suspect you selected these because you already had some on-hand. But this leads me to a question...
Is there any reason a capacitor of the same or similar values (eg. LCSC #C129303) could replace this? The latter cost currently 0.07 USD. I think the answer is no, but I want your opinion.
Now this leads to another question about making the board a little bit "modular"? What I mean to ask is, in your experience, is it reasonable to create a board that will accept the same part in a different package sizes on the same, largest pads? I've attached a picture to help clarify.
The best reasons I can think of are
1: It could be confusing, complicates or messes up the BOM
2: It's (probably) not a best practice, or for some reason frowned upon.
3. EasyEDA might not let you (still inexperienced, so I don't know the answer to this.)
What are your thoughts on this subject?
Deadly shadow 5 years ago
e024576 6 years ago
Regarding ordering components from LCSC - I see on their website a "BOM TOOL" which can import a spreadsheet listing all the components. So, why not include a parts spreadsheet?
warhawk8080 6 years ago
Awesome...always love your designs and things!
Shared this at OSHPark for another way to order the boards...
https://oshpark.com/shared_projects/u9rscwQi
Satrah101 6 years ago
why did you choose 603 parts.
ClemRz 6 years ago
Awesome! What should I change if I want the exact same characteristics but with an output of 3.3V?
emmseysquare 6 years ago
Try creating a voltage divider on the output of the circuit.
AllexandruP 6 years ago
but it s a boost converter ic , i don.t think you can get lower than the 4v or input voltage of i.c
voltage divider maded by 2 resistort and midle to fb of boost ic .
