DIY Make 2 SMPS(PSU) Work Together in a Single Pc...
Intro: DIY Make 2 SMPS(PSU) Work Together in a Single Pc...
Run your high end graphics card with a low end PSU costing as low as Rs 300 to 400...Cant believe??...Check this out guys....
STEP 1: Tight on the Budget???....read This....
This is my second instructable i am posting.All u gamers out there,this is a good hack that u can use.Graphics cards are the most power hungry component of a PC.Most graphics card nowadays comes with one or two 6 pin PCI-Express connectors to supply them power.This requires a powerful high end PSU.After investing Rs 10000 (convert to your respective currency if u are from outside India) on a good graphics card,it becomes a strain on the pocket to invest another Rs 5000 on a high end PSU that have the 6 pin PCI express connector.Well,If u have the affordability or u are worried about the impacts of a cheap PSU in the long run,u may ignore this thread.But i assure u,its more important to use a good UPS(which has a built in stabilizer) and have your house properly earthed.Without proper earthing, a high end PSU may fail within 6 months.
STEP 2: What May Be the Solution???.... :-/
Actually i am in a bit of a situation here which u also may face someday....i am explaining it step by step..
1. I have a NVIDIA GTS 250 1GB DDR3 graphics card...but its only DirectX 10 enabled.
2.I bought it for Rs 10,500 along with a COOLER MASTER EXTREME POWER 600W PSU which costs Rs 4000.
3.Now, i need to sale my GTS 250 but i want to keep my PSU cuz its working fine and buying a new one will also cost money.
4.But the person buying it is buying an used card because he it tight on budget.
5.So the buyer wont be able to afford Rs 5000 on a new PSU who is buying an old card for Rs 3000.
6.So,the net result is...I will never be able to sell my Graphics Card....:-(
Then,an idea came to my mind....
STEP 3: The Hack Begins....
The concept used here is to use two isolated power sources and to integrate them into one computer so that they will be switched on and off simultaneously,but will not share their power.It means the second psu is only meant to drive ta graphics card,but will start and stop with the primary PSU.
For doing this,I took 2 FRONTECH 400 Watt cheap power supplies each costing Rs 300.Take the two power supplies and carefully notice the 24 pin ATX power connector.
There is a GREEN coloured cable in the above pic and just adjacent to it is a black coloured cable.In normal situation,when the PSU is open(not connected to the motherboard or anything), it doesn't start just by hooking it up with the AC mains.U need to short circuit the green and the black cable with a pin or some small wire. So basically when u start a PC by switching on the Power button on the cabinet,u are just shorting these two wires.
STEP 4: Do It Carefully....
Cut away the GREEN and the adjacent black wire from the secondary PSU keeping a little wire from the base of the connector as shown in the above picture.(If u want to use it as a standalone PSU in future)This wire will definitely be short.So u may add some wire to extend it as u may have to place this PSU outside the CPU cabinet,but do insulate the joints.Then cut away the green and the black wires from the main psu in the same way,strip away a little length of the insulation each from the 4 pieces of wires u obtain after cutting.Take the two wires from the second psu and join the green and the black wires to their respective coloured wire of the main psu, and then twist them around the wire that is coming from the connector correspondingly.Insulate all the bare ends and you are done.
STEP 5: Lastly U Need to Buy This Connector...
This is a 6 pin PCI Express connector that u can buy from Amazon.in for Rs 100.
Below is the link..
http://www.amazon.in/CNCT-PCI-X-Video-Power-Cable/...
Buy it and you will be able to able to run High end games with a low end PSU.
U will have two SMPS working together.Hook up your PC and Graphics card properly...and enjoy.....:-D
Of course, Reliability is a question here....but for me.it rocks...:D...
Disclaimer: I am not responsible if you burn your graphics card or motherboard or anything else doing this...Best of luck....
18 Comments
mrsam1999 5 months ago
niitiinnegi 1 year ago
Just to add powering it up manually is not safe and I will not recommend this, instead add a small circuit in between the first and second PSU.
That circuit should have a relay obviously with a protection circuit, which turns ON the second PSU as soon as the first one turns ON and also turn OFF accordingly.
Or can use relay modules available nowadays which can work on 5V and comes with a protection circuit too (Like the one we can use for Arduino).
kings_dash 9 years ago
i am running it...for 2 weeks...its working just fine...
akagrawal306 4 years ago
Actually my problem is not a gpu but 4 sata HDDs.
I want to do this with two 250W Delta/HP/Lenovo PSUs.
One to power my Mobo+processor&GPU
& the other for all HDDs+DVS-RW+various Fans & Leds.
Thanks in advance.
EdmundL11 6 years ago
when CPU jam and automatically restart, the secondary PSU not start, what issue of it? i need to shut down and restart again then the secondary psu only can start
szinbone 7 years ago
im going to try this tonight!
bilden 8 years ago
I love when the urge for understanding makes people actually try things out and at the same time puts prestige aside. Prestige in argumentation that is a part of the old world where scientists were battling each other, keeping results secret until critical moments. If something breaks along the way when I try things its just a part of the process.
ChrisC33 8 years ago
You still have a voltage differential and potential short circuit between the two PSUs, the graphics card is slotted into the mainboard. Potential exists between the + power on both devices(since they are separated). It may not happen today, tomorrow, or the next day, but when you get unreliable power(say no Uninteruptible Power SUpply, due to costs) or a load on one and not the other, you will have problems. Before wiring something like this up you should take some lessons online about basic electrical wiring, as micro-electronics are actually "advanced".
Mjtrinihobby 9 years ago
Your arrangement (even on the merit of low cost) will cause rapid failure of the motherboard and or psus. The reason being is when you tell Windows to shutdown and the hardwired psu stays on. What do you think will happen? Also the small tolerances in voltage difference across each psu.. They cannot handle backfeed.
gnelson2 9 years ago
ninjanody 9 years ago
I have to disagree. If you were using the second supply for fans or led mods only there is no problem. GPU on the other hand gets power from PCI-E too exept the 6pin connector so there is a change to fry your mobo or GPU or both with the small tolerances in voltage difference across each PSU.
There are connectors that can power up the second PSU (for fans, leds, pumps only) easily with just a relay. If you have a spare bad mobo to get the psu connector, a 12v or 5v relay, a female molex and a resistor u can build it and have "safer" results. I will not provide link but only the name of this adapter: Add2Psu Adapter
chikid68 9 years ago
a better way to get it to power on would be to run a longer wire between the green wires on both power supplies that way they both turn on together eleminating the spike that comes from powering the second one manually
ptkrf 9 years ago
do not use molex to PCIe power adaptors for hugh end GFX cards! (high end means any card that needs more than one PCIe power adaptor) and god forbid using two separate PSUs to power one GFX cars. You mentioned in comments that you are using one gfx card for graphics and other for everything else, which may work for a while but note that new 750W psu costs less than 100$ . Just as EvolvedAwesome said, one PSU is always better than two (in case of consumer PC)
EvolvedAwesome 9 years ago
Just to anyone who is going to attempt this, it is always better to opt for 1 PSU over two!
cdtaylor51 9 years ago
seamster 9 years ago
Great info! Thank you for taking the time to share this.
welcome...:-)
