DIY Mini Amplifier Using TDA2822
Intro: DIY Mini Amplifier Using TDA2822
Building a homemade amplifier using TDA2822
Follow the steps here or watch the video to make your own amplifier
STEP 1: Things Required
1. 10k Potentiometer
2. 100uF / 16 volt Capacitor
3. TDA2822
4. 10 Ohm Resistor (3)
5. 0.1uF Ceramic Capacitor (2)
6. 0.01uF Ceramic Capacitor
7. 10uF / 50 Volt Capacitor
8. 3.5 mm Male & Female Jack
9. Switch
10. USB Cable
11. PCB Board, Wires, Battery
12. Soldering Rod. Soldering Wire & Soldering Paste
13. Enclosure for Amplifier
14. Insulation Tape & Scissor
STEP 2: Circuit Diagram & TDA2822 Pin Configuration
STEP 3: Construction
Make all the necessary connection according to the Circuit Diagram as shown in the previous step
STEP 4: Finished Images
Enjoy Making !!!
To watch the testing video CLICK HERE
Testing begins @ 5:27
If you interested in making this product you can please use my affiliate buying links to buy the components
Do you want to support my videos?
If Yes, Please browse and buy things from my Amazon Store. This way I get a small commission which will help me produce more videos. Please use the link to visit my store : http://goo.gl/gKjns4
You can also contribute to me on Patreon using the link : https://goo.gl/JHoagv
Amazon US :
TDA2822 - http://amzn.to/2a3v7r4
10 K Potentiometer - http://amzn.to/29WwHcH
Capacitors, Resistors & Other items - http://amzn.to/29Y2GY4
Switch - http://amzn.to/29YN5L4
Hot Glue Gun - http://amzn.to/29Y2BU8
Soldering Kit - http://amzn.to/29RyXjJ
Wires - http://amzn.to/29Y1kwt
Battery - http://amzn.to/29Y0Shu
PCB Board - http://amzn.to/2abRXw7
Scissor - http://amzn.to/29Y1K65
Insulation Tape - http://amzn.to/29YNZax
USB Cable - http://amzn.to/2a3wlCS
3.5 mm Jack - http://amzn.to/29Y2Rmb
Amazon India
TDA2822 - http://amzn.to/29PvfLD
10 K Potentiometer - http://amzn.to/2a1EA0R
Capacitors, Resistors & Other items - http://amzn.to/29GbUwT
Switch - http://amzn.to/29SqL6Z
Hot Glue Gun - http://amzn.to/29HEslT
Soldering Kit - http://amzn.to/29P00wv
Wires - http://amzn.to/29GdPBl
Battery - http://amzn.to/29HEp9E
PCB Board - http://amzn.to/29Ged2O
Scissor - http://amzn.to/29P2ECE
Insulation Tape - http://amzn.to/29HGzpJ
USB Cable - http://amzn.to/2a5dCWj
3.5 mm Jack - http://amzn.to/2a5dSEL
Follow Me On :
You Tube : https://goo.gl/ctc8l9
Twitter : https://twitter.com/MakeStuff_MS
THANK YOU FOR READING !!!
17 Comments
M4n0v3y 6 years ago
nice!
DIYTechStudio 6 years ago
Thank You !
MTspacez 7 years ago
What is the approximate cost? Where were the parts sourced from?
DIYTechStudio 7 years ago
I have put buying inks in the last step. The approximate cost would be 2 to 3 dollars.
jojo2635646 7 years ago
Magnifique.
Thank You :)
DylanD581 7 years ago
This is a great amplifier? What are the output watts?
Since this is a Bridge Amplifier design the output you can get around 2 watts
jimdkc 7 years ago
Well... it could be a bridged amplifier... except the input of one of the amps is grounded, so only 1 amp in the chip is active! To make it a bridged amp, you'd have to unground pin 6 and feed an inverted copy of the input signal to pin 6.
The way this amp is designed, half of the amp chip is wasted.
Yes this is a bridged amplifier.
"The way this amp is designed, half of the amp chip is wasted" - This is not the case, The bridge amplifier has high output power whereas in the stereo design the output power will be less.This is the reason i have showed the bridge design
jimdkc 7 years ago
OK... I see from the datasheet of a TDA2822 that this is a correct bridge configuration.
Normally for a bridged amp, you have to drive both inputs. Apparently this amp chip takes care of that internally.
j666laz 7 years ago
Why do you use a stereo input jack when it is only a mono amplifier? Or is a stereo amplifier (you show a single speaker)?
Hi, the stereo jack is turned into a mono jack. The only reason to use the stereo jack is because i didn't have any mono jack.
guds777 7 years ago
Cool instruction video, quite informative and sensible.
Thank You :)
charleslinquist 7 years ago
The 10 ohm resistor (R1) will severely limit output power, and even if you do wish to limit power that way, I would recommend moving C1 so it connects between pin 2 (Vcc) and GND. Doing so will reduce distortion.
