DIY Squid Hat
Intro: DIY Squid Hat
Free Squid Hat Pattern with pictures!
Time to make: 3-4 hours from start to finish.
Supply List:
Polar Fleece (about 2 feet)
All Purpose Thread
Velcro or snaps
Large Craft Eyes (I used 35 mm)
Download and print the pattern images in this step.
Supply List:
All Purpose Thread
Velcro or snaps
STEP 1: Cut Out Pattern Pieces
Print out pattern and cut out.
To save time, fold your fabric in half so that you are cutting out two pieces instead of one.
Place on polar fleece and cut out pattern.
I cut mine free form and just held the pattern down, but it might be a better idea to pin the paper to the fabric first.
Note: Before cutting decide if you want a hat brim that is stretchy or one that fits more precisely. If you want a stretchy brim, which I recommend, pull on your fabric to figure out which way the fabric stretches. Once you've got that place your pattern along the direction of the stretch.
If you don't want your brim to stretch place it in the direction the fabric does not stretch.
STEP 2: Sew Hat Panels and Fin
Pick up two panels of the hat pieces and place them so that the side of the hat you want on the finished hat outside is on the inside, between the hat panels. Match the points together and sew along one of the curved sides. Repeat on the two hat panels left. Do not sew all four together yet!
Take the triangle shaped fin pieces and place them together with the outside of the hat on the inside. Sew along the short edges all the way around the large edges. Be sure to leave the small inside triangle shape open.
Flip the fin piece right side out. Use a pen or skewer to pop the points out.
Sew a 1/4 in around the edge of the fin. This adds stability and texture.
STEP 3: Attach Fin to Hat Panels
Place the fin with the bottom of the fin along the top edge of the inside out hat panels. It won't just fit there, you have to hold it in place with pins.
It is important to make sure the middle of your fin aligns with the seam lines of the hat panels. Otherwise the fin will be sewn on crooked.( Which could be fun!)
After pinning sew 1/4 in from one end of the hat to the other. Be sure to leave the bottom of the hat open.
STEP 4: Attach Hat Brim.
Take your hat brim piece and sew the short end(s) together. You will be left with a big loop.
Fold this piece lengthwise with the good side of the fabric on the outside. We don't need to flip this one inside out.
Pin the open end of the brim to the bottom of the hat panels. The closed end of the brim should be on the outside of your hat, pointing towards the fin.
Sew 1/4 in along brim. If you want this part to look a bit more refined use a stitch that goes over the edge of the fabric or a serger if you've got one. I think most sewing machines have fake serger stitches these days.
Flip brim down.
After the brim is attached lay the hat so that the hat is folded in half from the side. You should have the front and back visible. Sew 1/4 in from the seam along the front of the hat(don't go over the brim!) and stop just before the fin. This will add a nice little ridge detail along the front of the hat which provides stability to the hat top. It keeps your fin perky!
Flip brim down.
STEP 5: Tentacle Time!
You've been waiting for it, the fun stuff!
Match your tentacle pieces up with the fabric inside out. 2 pieces per part.
Sew along edges leaving the bottom bit open. If you sew this shut you can't invert the tentacle.
Flip your tentacles inside out by pushing your thumb up through them and rolling the fabric down with your other hand.
STEP 6: Attaching Tentacles
Pin the two large tentacles to the inside of the hat along the sides. Line the middle of the tentacle up with the seam line of the hat panel sides. This is the same line the fin is attached to.
I keep the brim flipped up for this part. Try to sew directly where the brim was sewn to the hat. you may want to sew over this a couple of times because the long tentacles get tugged a lot.
Look at your paper hat pattern and match up the small tentacles where indicated on your fabric. They should be roughly 1 tentacle width apart and fold over the flipped up brim a bit.
Fold the open part of the tentacle down with the corners angled towards the center of the tentacle. This is to hide the fabric ends.
Pin the tentacles down where you want them and sew along the folded top part of the tentacle.
Optional:
To keep your tentacles down try this.
Cut small squares of velcro and attach them to the underside of your tentacle and the flipped up side of your brim. Make sure you line up the pieces before attaching them.
I used self adhesive industrial strength velcro.
Be sure that the female(soft) piece of velcro is what you use on the hat brim. If you flip the brim down you will be happy you did! The male velcro is very scratchy and abrasive on the skin.
Optional:
STEP 7: Attach the Eyes
I put my eyes above the furthest tentacles and to the sides. The pattern I made marks this spot.
However, feel free to put your eyes anywhere you like, and as many as you like!
On most craft eyes there is a metal bit that you snap on over the stem of the eye. This leaves the stem sticking out which I think is uncomfortable, let alone dangerous. Using a dremel with a sanding disc I remove the excess stem. This is usually short enough for the kinds of eyes I use. However, if you still have more stem sticking out I've been using fasteel, which is a two part epoxy putty, to cover the ends. It is super hard and cures within minutes. I then cover the fasteel with a bit of the fleece. I think I may have super glued it on, so ghetto...
STEP 8: Done!
Now go forth and conquer the world my squid army!
Edit:
Next time I make one of these I will be drilling holes into my squidy eyes and inserting LEDs.
This tutorial is nice for doing just that.
Edit:
83 Comments
dionysus.god 12 years ago
goosezilla 12 years ago
pie popper 14 years ago
I made it a little different, and didn't put eyes on it.
(yes, i have used this fabric in other ibles!)
marshmellowlily 14 years ago
crabezoid 15 years ago
I've got the urge to make a bunch of these hats and run amok causing havok with my very own army of squidlings!
goosezilla 15 years ago
Kirtangamer 8 years ago
UniKitty75 9 years ago
owlyfreak 12 years ago
gdavies1 12 years ago
Now, I feel the urge to wear a cheese hat. Can some one post a pattern for a cheese hat please?
Mauigerbil 12 years ago
rsepulveda2 12 years ago
neoner 12 years ago
kumiko 15 years ago
Those are really big craft eyes!!
ALogan97 13 years ago
Aztalr 13 years ago
Your Average Guy 13 years ago
