DIY Travel Pillow
Intro: DIY Travel Pillow
Last year I had the opportunity to travel through Europe. It was a grand adventure and I was able to see a lot of places. I also spent a lot of time travelling to get to each place. Between the planes and trains and buses I have to say I did my share of sleeping on the road, and one of the most lifesaving items in my carry on pack was my trusty travel pillow.
Travel pillows are good to pack for a few reasons:
They are small: They won't take up much space in your carry on luggage. Especially compared to an average sized pillow
They are comfortable: Travel pillows are very comfortable when you are trying to rest while sitting up (like in an airplane)
They can help you sleep: Getting comfortable on a plane or a bus is almost impossible for me to do, but with this pillow I was able to get some sleep while I was on the road so I was rested and ready when I got to my destination
STEP 1: Supplies
Here are the supplies that you will need for making your own travel pillow
Pillow Pattern - I found my pattern online here
Fabric - You will about 1/2 yard of fabric.
Polyester Fiberfill - You can find this at any craft or fabric store. I found mine on sale at JoAnn Fabrics
Sewing Needle - for hand stitching
Thread - This can be found in any craft store
Sewing Machine
STEP 2: Cut Out the Pattern
Begin by cutting out your pillow pattern
1. Lay out your pattern on the fabric - The fabric should be folded in half and the flat side of the pattern should be flush with the fold of the fabric. Notice on my pattern there is a side that shows "fold" most pattern pieces will have this type of indication.
2. Pin pattern to the fabric - this will guarantee the pattern won't move as you cut the fabric
2. Cut fabric out - Carefully cut around your pattern to get your pattern piece. Be sure not to stretch the fabric while you cut or your piece will come out misshapen.
3. Repeat. - to make the pillow you will need two U shaped pieces. So repeat steps 1 - 3 to get the second piece.
STEP 3: Sew Pieces Together
Now that you have the two U shaped pieces you can start sewing them together
1. Prep for sewing by laying out pieces - You'll want to lay out the pieces so the right side of the fabric is on the inside and the wrong side of the fabric is facing up.
2. Sew together pieces - Time to go to the sewing machine and start sewing your two pieces together. You want to give yourself about 1/4" seam allowance with your fabric. This means that your stitch will be about 1/4" away from the end of the fabric.
NOTE: Every time you start or stop a stitch its good to back stitch about 1/4". This will help keep the thread in the fabric, and keep it from pulling out easily
3. Leave about 2" of fabric unsewn so you can stuff your pillow - DO NOT SEW ALL THE WAY AROUND! you will have a very flat pillow
STEP 4: Stuff Your Pillow
1. Flip your pillow right side out - Now your stitching seam will be on the inside of the pillow
2. Use fiberfill to stuff your pillow - Use your polyester fiber to stuff the pillow to your desired softness. I liked that the pillow I had on my trip was firm so I put a lot of stuffing in this pillow.
STEP 5: Hand Stitch Closed
Once you have your pillow stuffed its time to finish stitching your pillow closed
1. Fold your fabric about 1/4" to give your the same seam allowance - You will notice your fabric will want to fold into the pillow naturally because of the seam you already made.
2. Thread your needle - Thread your needle and tie the two ends of the thread together. Using two strands of thread to stitch will add extra strength to your seam
For this closer you will be using a ladder/blind stitch
3. Pull the needle up and through one of the folded seams, from back to front, and pull the thread tail completely through. The knotted end of your thread will be hidden on the inside of your pillow
4. Go directly across from your last stitch. push the needle in and then back out of opposite seam crease to create a stitch.
5. repeat this process until your get to the end of hole. You will notice the stitch will create horizontal lines between the two pieces of fabric. (kind of like rungs of a ladder)
6. To finish the stitch pull your needle through a small amount of fabric on the opposite side of your last stitch. As you pull the thread tight you will notice it creates a loop. BEFORE PULLING the tread tight, pass the needle and thread though the loop to create a knot.
STEP 6: Travel!
And now you are ready to go! So go out and have an adventure!
“Not all those who wander are lost.” – J.R.R. Tolkien
5 Comments
Cat00x 3 years ago
ConnieR44 4 years ago
DianeW58 7 years ago
As someone who spends a fair amount of time on a bus or riding a
shotgun, I can certainly appreciate the usefulness of this invention.
It may look a bit goofy, like one of those peculiar inventions -
http://justsomething.co/23-craziest-japanese-inventions-you-never-knew-existed/
- but it is much better than pounding your head against the window
for several hours or making some makeshift pillow from a sweater.
Once we were traveling in Europe on a bus trip for quite a while -
http://en.cutway.net/distance/16205-4623/
- and I didn't sleep really well before that, so I just that
traveling time to get some sleep, although the real rest is always in
a good bed, in my opinion.
ashleyjlong 8 years ago
Very attractive final pillow! I've been needing one of these and may try making my own. Is your fabric cotton? I usually see the ones in stores have a stretchy synthetic fabric and I wonder which would be more versatile.
SNLouise 8 years ago
