DIY Vacuum Room for Small Resin Castings
Intro: DIY Vacuum Room for Small Resin Castings
Have you ever needed a small vacuum room for resin casting because your clear resin casts were full of bubbles?
Well i recently had that problem so i figured out a solution, i hope you'll enjoy it
STEP 1: What You Will Need
I do not need a big resin cast so i took a 1kg candy box and made sure it was airtight.
You will need a syringe or a hand pump
My syringe was 60ml and it was a perfect fit for my leftover nylon tubing from my aquarium.
You will also need a three way cross for your tubing and two one side valve (also left over from my aquarium but they're cheaper than you'd expect)
STEP 2: Building It!
So now that you have all the requirement make a hole in your box the size of your valve and put the input side of the valve on the inside, then seal it with glue (this ensure that air only leave the box through the valve)
DO NOT put any glue inside the valve! so be careful!
Now you can connect the pump to the tube, and the tube to the three way cross to two smaller tubes, one leading to the valve on the box and the other leading to the other valve, to make sure that air only leave through it
(english isn't my nate language so i can't really explain this correclty, but i made a drawing that will hopefully make you understand how it works!
STEP 3: The Pros/cons and Why Yours Might Not Work
So here is what i got from using it a few times:
Pros:
Really cheap
Fast to make
Durable(ish)
Cons:
The pump is hand powered
Plastic box may bend if you apply too much pressure
(a little bit of bending is ok but too much may ruin your airtight box)
No safe way to deppressurize it, so be careful
"Help, mine isn't working"
A few reasons can cause that to fail:
Your pump isn't airtight aswell for some reason
fix: use cable ties where the cable change, or use electrical tape if you screw around (not sorry for the pun)
Your box isn't airtight
how to be sure: the marshmallow test! put one or two inside your box and start pumping! you can have different results:
The marshmallow was inflating, and suddenly looks like an old person: you have a good pressure no problem
The marshmallow is pulsating like a heart: your pump works well, but there's a hole in the box
The marshmallow is not caring at all: either there's a big hole somewhere, or your pump doesn't work
fix:glue or silicone caulk, and if your box is totally ded, change the box
10 Comments
Bag-Us 7 years ago
whether to eliminate bubbles in resin?
book worm 8 years ago
some resins work better under pressure so if the seals will hold you could use it in reverse and make a pressure chamber too,also good for forcing resin into wood to stabilize it for turning etc
C3DRIC 8 years ago
That is true, however i glued the one side valve in reverse for this one so it wouldn't work, but now that i think of it, i might add another hole and put another one side valve in the other position allowing me to do both
C3DRIC 8 years ago
belsey 8 years ago
Love your marshmallow test!
C3DRIC 8 years ago
Hehe it's pretty funny indeed xD
gwfong 8 years ago
clever
C3DRIC 8 years ago
Thanks!
DIY Hacks and How Tos 8 years ago
Nice. This would work great for a lot of projects besides casting as well.
C3DRIC 8 years ago
Probably, i only thought of the resin cast because i needed it for this now, but there's plenty of stuff to do that doesn't involve casting ^^
