DIY Wifi Extender - Cantenna Build With a Stand.
Intro: DIY Wifi Extender - Cantenna Build With a Stand.
Bill of Materials:
Two milo tins or similar
F-Type chassie mount
Pig tale for F to Sma
Short piece of copper wire
Tools:
Tin snips
Can Opener
Soldering Iron
Drill
Drill Bit
Original content avaliable at BudgetHack.com
STEP 1: DIY Wifi Extender - Preparing the Cans
Alright then what we want to do is remove the top of one can and the bottom of the other. Once you have done this on the can with the top removed cut out a small strip approx 10mm across and 15mm down the can. Then we are going to use this slit so we can push one can inside the other, The can with the slit will deform slightly but don’t worry about it at this point.
STEP 2: DIY Wifi Extender - Joining Cans
STEP 3: DIY Wifi Extender - Finishing Edges
STEP 4: DIY Wifi Extender - Main Element
Next from your calculator measurement find the height of your main element, Cut a piece of copper wire this length and solder to the top of the f-type connector as shown below.
STEP 5: DIY Wifi Extender - Attaching Main Element
Last thing to do is have a look at your calculations again you can see the distance the element should be from the back of the can, measure this out on the can and drill a hole big enough for it to go through. Once the mount is in place go around and fully solder it to the can like in the image below.
At this point you have a working cantenna , Connect your piggy tail between it and your wifi card and you are good to go. Remember this is a directional antenna so it needs to be point in the direction of the AP your trying to connect to.
(Note: Some people have advised they had trouble finding the pigtales and connector’s so I’m trying to locate a bunch so I can make them available on BudgetHack.com)
STEP 6: DIY Wifi Extender - the Stand
Now what about this stand business, this really was me just mucking about but it turned out to be quiet useful.
What you want to do is take the bottom of the tin you cut off and cut three small triangles out of it evenly around its circumference, bend the remaning triangles down to make a sort of tripod shape. Then you want to bend them in the middle so the corner of each triangle touches then solder them together, now just solder it to the cantenna. This might seem a bit silly but it really helps when trying to point the antenna and it costs you nothing.
Alrighty your probibly wanting to know was it worth the effort well for me yes. I have not had a chance to do exensive testing, but from some basic testing it seems to be giving me a 15db increase over the stock d-link antenna which is certainly a massive increase for the minimal cost of the build.
25 Comments
mrtejas99 4 years ago
docman100 6 years ago
Is the a possible way to make this connect to an AC Outlet? and boost up multiple instead of one device at a time?
astral_mage 10 years ago
http://kioan.users.uth.gr/wireless/cantenna/
mnc_co_uk 13 years ago
Using some rf decouplers and high frequency diodes and an oscilloscope it is possible to measure the SWR.
A good match between your antenna and transmission line will result in a low reflected wave. If the reflection is high compared with the foward wave there is a bad match, poor performance will result and the dimensions of the antenna would need altering.
when building a killer antenna impedance matching shouldn't be taken lightly and it's good to know, if you spend time getting this correct, you'll be getting optimal performace out of your hard work.
Dr.Bill 11 years ago
So impedance matching is Very important. MFJ sells an SWR and impedance analyzer that will tell you when your antenna is perfect. MFJ-259B
susovit 12 years ago
The link doesnt open the calculator. ????
frogman31680 13 years ago
I wonder if having a smooth interior or the ribbed kind affect the signal in any way.
Also, I don't use the coax connector for my wifi. I have a USB adapter... So i would have to adjust this somehow.
Slim49 12 years ago
the interior ribs will not be "seen" during the proprogation of the wave.
mine all worked A OK.
Mr. Steve
Slim49 13 years ago
this one is so easy to do.
need a 18" USB extender. I wrapped a 1" band of aluminum around with 3" of handle below. the ribs are so within the shortest lenght of teh wave as to be no issue. made 2 of these. my friends rave over it.
get a 4" + or- can, I used a tomato juice can.
estimate where the face of the interior trace antenna is & its front facing direction.
cut a slot in the can 1.25" from the rear wall. need a friction fit of your USb donagel.
insert it up inside 1.25" or more, play with it.
You will get some "much improved" signal strenght & more signals that you could ever imagine.
I have built every one of these Wifi antennas.
Mr. Steve
gora_ji 13 years ago
How about an instructable????! ! ! !
Slim49 13 years ago
www.turnpoint.net/wireless/cantennahowto.html
its teh best site of all.
read up at several sites.
search for : CANTENNA, lots of info already is out there.
even just getting the USB donagel inside most any can will jump up signal strenght & numbers of sites.
Luch,
Mr Steve
Javin007 13 years ago
And as a side-note, having actually looked at this site, I can certainly say that no, it's not. And this instructable is far superior.
Slim49 12 years ago
no insult intended!
I used elements off you instructable.:-)
Mr steve
k4gdw 13 years ago
Working with antennas isn't just a simple matter of hooking it up. A transmitter is designed for a specific impedance, measured in ohms. I'm not going to go into a treatise on antenna theory. A transmitter is designed to use an antenna system that has a specific impedance. If the antenna system's characteristic impedance doesn't match the transmitter, then you have an impedance mismatch which can, if the mismatch is too large, cause physical damage to the final transistors in the transmitter.
budgethackdotcom 13 years ago
madworx 13 years ago
BIGHAIRYDUDE 12 years ago
nicky23 13 years ago
