Introduction: Truly WiFi Extender
Introduction
Truly WiFi Extender is a WiFi repeater based on Raspberry Pi Zero W. It makes a nice alternative to a commercial WiFi repeater combining low-cost (under 10USD) and highly customizable software. It can also run some ad-blocking solutions such as pi- hole as well. This project is one of a kind because most of the projects on GitHub demonstrate how to create a wireless AP to share Internet access obtained using Ethernet.
View my project on Hackaday Hackaday
View my project on GitHub Github
View my project on Hackster Hackster
Step 1: Prerequisites
For flashing the image onto the SD card I have used BalenaEtcher
- Download the raspbian lite.iso file from the Raspberry Pi website
- Once downloaded, open BalenaEtcher, select the .iso file, select the SD card and click the flash button and wait for the process to finish.
- Then, open the boot partition and inside it, create a blank text file named ssh with no extension.
- Finally, create another text file called wpa_supplicant.conf in the same boot partition and paste the following content.
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev<br>update_config=1 country=IN network={ ssid="mywifissid" psk="mywifipassword" key_mgmt=WPA-PSK }
Replace the mywifissid with the name of the WiFi and mywifipassword with the wifi password
- Power on the Raspberry pi. To find its IP, you can use a tool like Angry IP Scanner and scan the subnet
- Once you find the IP, SSH to your Pi using a tool like PuTTY or just ssh pi@raspberrypi.local, enter the password raspberry and you are good to go
- Finally, update the package list and upgrade the packages and reboot Pi.
sudo apt update -y sudo apt upgrade -y sudo reboot
Step 2: Setting Up Systemd-networkd
From ArchWiki
systemd-networkd is a system daemon that manages network configurations. It detects and configures network devices as they appear; it can also create virtual network devices.
To minimize the need for additional packages,networkd is used since it is already built into the init system, therefore, no need for dhcpcd.
- Prevent the use of dhcpd
Note: It is required to run as root
sudo systemctl mask networking.service dhcpcd.service sudo mv /etc/network/interfaces /etc/network/interfaces~ sed -i '1i resolvconf=NO' /etc/resolvconf.conf
- Use the inbuilt systemd-networkd
sudo systemctl enable systemd-networkd.service systemd-resolved.service sudo ln -sf /run/systemd/resolve/resolv.conf /etc/resolv.conf
Step 3: Configuring Wpa-supplicant
wlan0 as AP
- Create a new file using the command.
sudo nano /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
- Add the following content and save the file by pressing Ctrl X, Y and Enter
country=IN ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev update_config=1 network={ ssid="TestAP-plus" mode=2 key_mgmt=WPA-PSK psk="12345678" frequency=2412 }
Replace the TestAP-plus and 12345678 with your desired values.
This configuration file is to be used for the onboard wifi Adapter wlan0 which will be used to create a wireless access point.
- Give the user read, write permissions to the file
sudo chmod 600 /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
- Restart wpa_supplicant service
sudo systemctl disable wpa_supplicant.service sudo systemctl enable wpa_supplicant@wlan0.service
Step 4:
wlan1 as client
sudo nano /etc/wpa_supplicant/wpa_supplicant-wlan1.conf
country=IN ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev update_config=1 network={ ssid="Asus RT-AC5300" psk="12345678" }
Replace the Asus RT-AC5300 and 12345678 with your Router SSID and password.
This configuration file is to be used for the USB WiFi Adapter wlan01 which will be used to connect to a Wireless Router.
sudo chmod 600 /etc/wpa_supplicant/wpa_supplicant-wlan1.conf
sudo systemctl disable wpa_supplicant.service sudo systemctl enable wpa_supplicant@wlan1.service
Step 5: Configuring Interfaces
sudo nano /etc/systemd/network/08-wlan0.network
[Match] Name=wlan0 [Network] Address=192.168.7.1/24 IPMasquerade=yes IPForward=yes DHCPServer=yes [DHCPServer] DNS=1.1.1.1
sudo nano /etc/systemd/network/12-wlan1.network
[Match] Name=wlan1 [Network] DHCP=yes
- Reboot the Raspberry Pi using
sudo reboot
