DIY Heated Clothing
Intro: DIY Heated Clothing
This is for those motorcycle riders, who like me, don't know when to quit and can't afford store bought heated clothing. I'll show you how I made my pants, but the same can be done for a jacket or whatever else you can think of. I made these last year during the middle of a road trip to battle the bitter cold, and it worked wonderfully. This is how I did it, I'll put some links to other ways on the last step. Also, I took the pictures while taking my completed pants apart (I think I can make them better), so there are not many action shots. Sorry and enjoy the instructable.
* The chief concern with anyone I tell this to is always "Can you catch on fire?". Well to answer your question, no. If you follow the steps as outlined, there is no chance of you catching on fire. There are companies that sell clothes made the exact same way, just with nicer looking materials and a higher price tag. The flash point of most fabrics is much higher than this suit is capable of producing.
STEP 1: Materials
- 30ft of 30 AWG Teflon wire
- Some normal copper wiring (16 AWG)
- Connectors (See note 1)
- Ring connectors for connecting to the battery (See note 2)
- Fuse (Over 4 amps with just pants, over 10 if you make a jacket)
- Fuse holder (See note 2)
- An SPST switch (optional but recommended) (see note 3)
- Thermal underwear (or whatever you want to use)
- Cloth to make a lining
- A thick sewing needle
Note 1: You'll want to chose a connector that can be can be quickly disconnected. This is for the cases where you forget to disconnect from the bike and you try to walk away. Rather than tearing anything apart, the connectors will just come apart. There is an instructable on how to make one that's pretty cool. Here's the link: https://www.instructables.com/id/ThinkSafe%3a-A-Magnetic-Power-Connector-for-Thinkpad/. But if you don't want to make one, you should get a coax type plug or maybe a quarter inch plug, like the ones used on guitars. The coax plugs are what is used on professional clothing. I have a bunch of bullet connectors laying around, so that is what I'm going to use.
Note 2: You can buy a pre-made battery harness with fuse holder for pretty cheap. It's actually cheaper to buy the pre-assembled one than it is to make one unless you have the parts laying around. This second time around I'm using a pre-made one. http://cozywinters.com/shop/wg-dcjk15amp.html
Note 3: You can also buy a pre-made switch which looks pretty nice and is waterproof. This is what I'm using this second time around: http://cozywinters.com/shop/wg-oocoax.html
STEP 2: Theory
This works on the same principal as a light bulb or a toaster. Pass electricity through a high resistance, and you get heat. In this case though, we are controlling how much heat the clothing will put out by varying the length of wire we will use. To figure out how much wire to use, we will use ohm's law or
Current [Amps] = Voltage [Volts] divided by Resistance [Ohms]
The wire we are using has a resistance of .1 ohms per foot. So if we used 30 feet of wire, the total resistance would be 3 ohms. This is ignoring the resistance of the connectors and wire going to the battery but it should be negligible in our calculations. The voltage of most modern motorcycle batteries is 12 volts. So 12V/ 3 ohms = 4 amps. Now we know how much current our pants will draw.
So you want to know how hot this will be? Here's an excerpt from this site
Power [Watts] = Current [Amps] x Voltage [Volts]
Based on our project consisting of a 12-volt battery and a current of 4-amps, the power consumption would be (4-amps x 12-volts = ) 48-watts. The heat output of 48-watts, can be expressed in British Thermal Units (BTU) per hour by performing the following conversion:
BTU / Hour = Watts x 3.413
Put simply, one British Thermal Unit (BTU) is the amount of heat required to raise the temperature of 1-pound ( lb) of water 1-degree Fahrenheit. Thus the vest in our project would output ( 48-watts x 3.413 = ) approximately 164 BTUs per hour. If this value isn't intuitive to you, consider that 48-watts is similar to a 50-watt light bulb, and imagine the amount of heat that a 50-watt light bulb outputs. That may not sound like much, but when that amount of heat is contained under a jacket, you will find that it is plenty warm.
Also, if you were to look at the power output of Gerbing's heated pants, you'll see that they put out 44 watts of energy, so our pants will be warmer than theirs. If you want to go even hotter than that, just use a shorter length of wire. Just remember ohm's law and you'll be all set.
STEP 3: Threading the Wire
Measure out 15 ft (or the halfway point) and mark it. Now starting at the middle point of the crotch, feed the wire all the way up to your halfway mark. Now tie a loose nut or put some tape to keep the other half from passing through. Make your way down the inseam, and then follow the pattern that I drew below. You'll want to finish around the waistband area. This is where we'll attach a connector. Once you finished with the one pant leg. Repeat the process for the other pant leg with the other half of the wire.
This new layout is better as well because it doesn't constrict the legs like the spiral pattern does. It makes it much easier to put the pants on.
STEP 4: Soldering the Wires
STEP 5: Adding a Connector
After all of that is done, you'll want to add a liner. This will serve two functions. One it will protect your wires and two, it will keep you from getting burned. Trust me, this wire gets hot, it WILL burn you...I found out the hard way. I think an easy way to do this would be to buy another set of thermal pants, and sew them on the inside.
STEP 6: Final Steps
STEP 7: More Info
- http://www.mototour.us/technical/electricclothes.htm
- http://home.mebtel.net/~rbutterfield/Heat.html
- http://www.shadowriders.org/faq/electricvests.html
104 Comments
hemstitchin 3 years ago
dean.pham.507 6 years ago
spiritwalker6153 6 years ago
Since I live in South Dakota and I ride pretty much year around, this seems to be a good idea for me. I do, however, have a couple of questions. The first question deals with what sort of clothing I would like to sew it into. Can this wire be sewn into a union suit and still be effective and if so, can it be sewn to the outside to keep from burning me? Also, would it be effective if the wire were to be sewn into say, a pair of jeans? Thanks.
BarbaraL53 8 years ago
I really need to learn how to do this for many clothes due to Severe Raynaud Disease. Is the fiber tape that I see a tape that you sew in and the wire goes through it so wire stays in place. Or is it something else for making heated clothes? I do not know anything about electric as to what to do or what I would need, How can I learn about this or where can I get info as to what I would need that I can follow when I know nothing about any of the electric parts. I can sew though. I need to make tops, bottoms, hat, gloves and whatever I can make. I did have battery heated jacket and a vest but they do not work now. Wish I had someone to help me with the part I do not know to begin with. Or if there is more detailed info on this area of making it. glovethis.
BenD56 8 years ago
Akin Yildiz 8 years ago
2009 to 2015. lots of technological changes, check out my work;
https://www.instructables.com/id/usb-heated-clothin...
fdferris 8 years ago
How about combining this idea with a diy overpants? I'm thinking of doing this for a future project.
https://www.instructables.com/id/DIY-motorcycle-over-pants
Kiteman 9 years ago
You've made a hamster very happy:
https://www.instructables.com/community/Hamsters-he...
THX 1138 9 years ago
According to the post the hamster was burned so yeah, one ecstatic hamster.
sixty7flh 9 years ago
just found this. cool. I am looking at a way to make portable pwer? I have the gerbings and love it, but often I am on one of my "old" generator (low output) bikes.. Figured I need a portable solution......
lrdforster 12 years ago
I just joined the site and will post the circiut and instructions soon.
RichardBronosky 10 years ago
lrdforster 10 years ago
quilter2 10 years ago
Another electric supply source?
Don't need as much heat. Not sure, how much.
12 years with shingles on leg. Keeping the leg warm...layering isn't enough. Or any type of fleece combination.
I can sew ANYTHING. Industrial machines,etc.
Any help would change my life.
Thanks, Jeanie
mcleanjusten 10 years ago
YobazEfendi 10 years ago
wo0x 10 years ago
i wanna make it for a motorcycle 12vcc.
thanks.
Tortin 11 years ago
DehLeprechaun 13 years ago
vze1mk7d 13 years ago
Regarding the 9v battery, if you are talking about the ones used in a smoke detector, then no it won't work. Those batteries are used for low current drain applications. If you got a 9v battery pack or some other large capacity battery, then yes it would work.
