DIY Humidity Dome for Seedlings
Intro: DIY Humidity Dome for Seedlings
When sprouting seeds or rooting clones it's a good idea keep them in a place with warm and humid air(~20-25°C / 68-77 °F). This is where a humidity dome comes in. Putting the seeds or clones in a Jiffy pot or a Rockwool cube and then filling bottom with water will create a humid climate perfect for germination and seed growth.
STEP 1:
STEP 2:
STEP 3:
STEP 4:
STEP 5:
STEP 6:
STEP 7: Done!
Happy growing! here I am starting tomato seeds, pepper, Chinese veggies and sugarsnap peas in plastic cups that can be reused for new seeds after replanting. Holes can be cut with the exacto in the dome for a little ventilation if needed.
Don't forget to vote for your favorite entry in the green contest: https://www.instructables.com/contest/greendesign/
22 Comments
RoniT6 7 years ago
I think something is dead wrong with this method.
As an aquarist, we do emerse grow method (as known as "Dry Start") and use our tanks for that purpose, sealing the top with cling film (stretch wrap) BUT with a very important modification: After sealing the top completely, we tear a little bit from the rims of the tank just to allow the plants to get Co2 from the air as the Co2 is one of the most important variable on plant grow because it is required for photosynthesis process. You need to provide enough Co2 for your plants but sealing the tupperwares like that will cause Co2 to drop ciritical levels or even completely finish.
I would suggest to drill some holes on the top of the upper tupperware so the plants would always have fresh air (both O2 and Co2). Ofcourse this will cause the humidity to drop on the other hand but it can be by-passed by moistering with a spray and/or adding water to the bottom as needed. My guess would be doing so once a day or even once for every 2 days would be enough if the environment temperature is less than ~26C (~79F).
By the way, I have serious doubts about the transparency of those tupperwares. They don't look like they will transmit the light without emitting/changing any spectrum/temperature. Even our glass tanks (made of extra clear glass instead of regular glass which means much, much more transparent than regular glass) loses some of the light, I can't imagine what would a plastic do - or don't.
And again, this will also effect your grow rate in bad way, too.
So, after all, maybe it's not the best idea to use tupperwares to make a DIY humidity dome.
I would definetely go for plexiglass if I were to build my own humidity dome.
Rimwulf 11 years ago
Off topic question: what art program did you use to make the instructions?
Lunarius 11 years ago
For a quicker way to put holes in sturdy or thick plastic, I use an old soldering iron in a well ventilated area. It doesn't take long and it gives even, neat holes that don't have any jagged edges. The little 'rings' of melted plastic will pop off pretty easily, too, when cool. Obviously one needs to be careful with what types of plastic they melt so as to avoid nasty fumes and fire, but it's worked rather well for me thus far.
pudi.dk 11 years ago
GyroGearLoose47 11 years ago
mcmonte 11 years ago
sparkleponytx 11 years ago
snbuch 11 years ago
PeteD31bgn 11 years ago
KOJohnson 11 years ago
billbillt 11 years ago
Chakazuluu 11 years ago
Orngrimm 11 years ago
But one question: With what software did you make those nice pictures?
I used Adobe Flash CS4 for the drawings.
Unfortunately i dont have Ad.Flash :(
Bobey 11 years ago
shiondooko 11 years ago
kirinwantsaskateboard 11 years ago
I love this instructable... I've been looking for something like this for my new seedlings I bought from a gardening expo! This is perfect! Thanks so much for sharing! My vote goes to you for the green design contest!
Kirin :D
