DIY Projection Screen
Intro: DIY Projection Screen
After finding a nice cheap LCD projector I needed a decent projection screen. Here's how I made mine.
STEP 1: The Frame and Fabric.
I decided to recycle some lightweight PVC I made a banner stand with a few years ago I didn't need anymore. After assessing the parts I had to play with, I decided on a good large size with roughly a 4:3 aspect ratio. The pieces in white were the only ones I needed to buy new. I also wanted it to be able to break into two pieces for when I move, so there is one half shaped like a square, and another shaped like a "C".
As for the screen material, I went down to Johannes fabric and looked around for the brightest, shiniest fabric I could find. Surprisingly it was the back side of some terrible gold pleather.
STEP 2: Tie 'er Down.
The fastest and best way I could think of to hold the fabric tight and straight is to tie it down like a drum. I cut little slits every 2.5 inches or so with a razor, then wound string around the pipe and through the holes. I drilled holes in the corners to anchor the string.
STEP 3: Ceiling Attachment
I opted for something more temporary since I change my mind way too much for my own good. The two top points are able to swivel, allowing the screen to be lifted and locked in an upward position. I have a crappy florescent light in the ceiling which I made hooks attach to.
STEP 4: Conclusion
All in all, the screen came out really great considering I only spent about $10 on it, plus the recycled parts. It's a vast improvement over the sheet I was projecting on previously.
FYI: it may seem like one side of the screen is longer, but it's not, the projector is just slightly off angle at the time of taking the photos.
39 Comments
Anja Ulfeldt 8 years ago
Hi Bray! I came across this while looking for LCD reuse hacks. Nice work on the screen :)
all thumbs1 12 years ago
paint the wall where i want the screen to be. has anyone tried this idea? did it work ok?
everyone i couldn't afford grommets and the grommet machine so i put in reinforced button holes with my sewing machine and it has lasted a long time
internethotspot 12 years ago
screenbuilder 12 years ago
illadelchronic 12 years ago
allandnnn 13 years ago
mithandir 14 years ago
Bisquick 16 years ago
jimmy dean 15 years ago
RiddleOfSphinx 15 years ago
mas9779 15 years ago
ThinkBeforeYouSpeak 15 years ago
kenn123 15 years ago
aliceaod 15 years ago
If you need to paint the fabric (as I did, it needed to be silver for my projector), do so BEFORE you put it on the frame. I found that out the hard way. :/
nitram_cero 15 years ago
Bray 15 years ago
jeandeau 16 years ago
dirtypaper 16 years ago
zoundsPadang 16 years ago
