Destroy Any Device With EMP Jammer
Intro: Destroy Any Device With EMP Jammer
Imagine that you have powers to stop any electronic device, is it only possible in movies?
well here's the way to make an emp jammer (Electromagnetic pulse jammer)
This device sends high amplitudes of emp to destroy nearby devices, be sure to have fun using this, but be careful this jammer involves thousands of volts which can lead to heart attack or death even (if not used properly)
DON'T USE THIS DEVICE NEARBY ANY MEDICAL EQUIPMENT LIKE PACEMAKERS ETC.
Watch the video
https://youtu.be/l7UMJL3rB3Q
https://youtu.be/4ldKP0aGIhY
STEP 1: Get the Parts
Part list
★☆★ Buy Parts from your online local store ★☆★
1. 32 gauge Magnet Wire http://geni.us/ITPUbly
2. Plastic Project Box http://geni.us/C2eA
3. Push Switch ×2 http://geni.us/TcAmVuf
4. Some kind of glue http://geni.us/FAC7w
5. Hot glue (if you need) http://geni.us/lBnlm
6. 3.7 v battery http://geni.us/8V2i1
7. 7000 volt High Voltage Converter http://geni.us/oFb09C
STEP 2: Connecting Togather
make a coil of 32 gauge copper wire with 5 turns connect an push switch (i call it spark gap) and high voltage converter in series with coil.
connect an push switch to control power to the high voltage converter .
74 Comments
cyanandspace 7 years ago
if somebody could make this for me and send it to me, I would be eternally grateful, and it may even come with a cash reward ;)
JonathanF99 7 years ago
I did one and it worked, I can sell you one
fixxfan2112 3 years ago
U.S cash....
mikeoils0324 3 years ago
I need one of these. Can you make and sell me one?
Contact me @ mikeoils0324@gmail.com
Freddyja 7 years ago
YaddyVirus 7 years ago
Really?
SteveDay72 3 years ago
A real EMP unit would use an off-the-shelf and readily available spark-gap... ie: an engine spark plug. It would charge up a bank of large capacitors and then discharge them through spark-gap(s). House the coil at the back end of a long can and you might be able to make it somewhat directional.
inuyasha1986 3 years ago
alexandersobotovic 4 years ago
lndsoto 4 years ago
XenaOcter 4 years ago
bilGolden 5 years ago
Hrishik5 5 years ago
ronm172 5 years ago
SurplusS 6 years ago
why higher voltage makes greater magnetic field? Doesn't the higher voltage mean lower current and consequently generates weaker magnetic field?(P = IV, also I can't fully understand how the spark gap plays in the circuit. When there is high voltage, electric can go through the spark gap frequently and that makes a pulse, right?
ronm172 5 years ago
ResponseRobot 6 years ago
I believe the spark gap provides quick and easy timing circuit that allows the coil to produce many pulses a second rather than one single long pulse.
iceng 5 years ago
This is a fake project and CAN'T produce an insect flicker let alone any
Electro Magnetic Pulse ..... to damage semiconductor intrinsic diodes..
Especially the TOY PUSH BUTTONS can't carry any amount of current in the tiny wire or they would Weld Shut if the current was correct..
ienu2306 5 years ago
PrakharMishra 6 years ago
