Diamond Ice Ring
Intro: Diamond Ice Ring
Need to impress your boo? Can't afford diamonds? Surprise her with an ice ring instead! She won't know the difference.
STEP 1: Materials
Here's what you'll need:
Polymer clay: Super Sculpey is my favorite oven-cure polymer clay. It's smooth, soft, and easy to handle.
Liquid polymer clay: watered-down (so to speak) polymer clay. I use it here as an adhesive. It cures in the oven with the regular polymer clay.
Silicone Rubber: I used Smooth-Sil, available here: http://www.smooth-on.com/Smooth-Sil%3D-Plat/c1131/index.html. It comes in two parts, which need to be mixed in a predetermined ratio (by mass) and then left to cure overnight after pouring.
Modeling clay: I used an oil-based modeling clay like this one: http://www.dickblick.com/products/sculpture-house-prima-plastilina-clay/.
Mold release spray: If you forget this, you'll never get your mold halves apart. Available here: http://www.smooth-on.com/Release-Agents-and/c9_1123_1226/index.html
STEP 2: The Plan
Start with a sketch of your model. The sketch will serve as a reference for the clay master that you'll make. It's much easier to sculpt an idea if you've already worked out all the shapes and proportions.
STEP 3: Start Sculpting
Begin by sculpting the ring shank. Don't worry too much about how smooth it is, because you can easily sand down bumps later.
Bake the form in an oven for 30 minutes at 275 degrees Fahrenheit. Check the clay packaging for brands other than Sculpey. I used a piece of rolled-up cardstock and some cardboard supports to help the ring stay round in the oven. I ended up stretching it a bit, however.
STEP 4: Rough Sanding
Once your ring shank is cured, sand it down with 100 or 150 grit sandpaper to smooth out the shape. In general, try to sand polymer clay under running water, or rinse it off periodically, to keep the dust under control.
If you want, you can continue sanding in stages through 220, 400, and 600 grit. I did, but I'm not sure if it really made a difference during the molding. I went all the way to 600 because I was afraid the silicone would adhere to the clay too much if I left the 150 grit scratches in the surface.
Once you've finished smoothing the surface, return to the 150 grit paper and sand off a flat to prepare for the diamond setting.
STEP 5: Build the Stone Setting
Create a clay disc to form the platform under the diamond. Bake it,, then roughly sand it into shape. To join it to the ring shank, paint a layer of liquid clay onto both surfaces and cure the whole thing in the oven for another 15 minutes or so.
Before you add any clay to the cured piece, brush on a bit of liquid clay to the building surface. Otherwise, the clay won't adhere to itself even after curing.
Build up the rest of the setting by adding more clay where it's needed. Then, bake the piece again and sand the new areas to refine the shape.
STEP 6: Sculpt the Diamond
Sculpt a rough diamond shape, using the body of the ring as a guide for the shape and size. Don't glue them together yet, though. Bake the diamond separately, then use 150 grit sandpaper on a flat surface (like a table or counter) to give the diamond sharper edges and nice facets.
I actually had a hard time getting the diamond to stick to the setting - the joint kept breaking, and I never seemed to bake the liquid clay for enough time. If I did this again I would probably avoid trying to join two large flat surfaces with just liquid clay.
STEP 7: Build the Mold Box
In order to make a two-part mold, you'll need to section off half of your piece using the oil-based modeling clay. Using a piece of acrylic for support, build up clay around half of your model to define the parting line of the mold. Keep the surface of the clay clean and even, especially where it meets the model. This will keep the mold from leaking later.
Form the clay in a boxy shape, with at least 1/4" of space around the edges of the part. The top surface of the diamond can be left exposed, because that's where you'll pour in the water later.
Once you're done with the clay, build the mold box around it. I used rectangular acrylic pieces hot glued together. The pieces should be glued to the base and at every edge. Run a bead of hot glue over the outside of every box joint, so that no silicone can leak through.
Use the back of some tool (or your finger) to poke holes in the surface of the clay. These will serve as registration keys to line up the mold pieces later.
STEP 8: Pour the Silicone
Grab a ruler and determine the approximate volume of silicone you need to mix. If you have a graduated measuring cup, you can easily pour out as much of silicone Part A as you'll need; if not, you might need to use the material's density to calculate how much weight you'll need, and pour it out on a scale. You could also just eyeball the whole thing, but then things might go horribly wrong. I'd stick to using a scale.
Use the mixing ratio given by the packaging to determine how much of Part B (the silicone activator) you'll need. Re-zero your scale and carefully pour the correct amount of Part B. Mix them thoroughly with a stirring stick.
If have a vacuum degassing setup, you can remove most of the air bubbles from your mixture before you pour it. If not, you'll probably be okay anyway. Spray your clay, box, and model with the mold release spray, then pour the silicone slowly into the corner of your mold box. To minimize trapped air, allow the silicone to spread over the piece on its own.
Give your first mold half the proper cure time, then remove the box from the base and peel away the modeling clay. Clean it as best you can from the model, then give everything another good coating of mold release and pour the second half of the mold.
After both halves are cured, you can cast whatever you want. I secured the pieces together with acrylic pieces and rubber bands to provide even pressure and prevent leaks.
STEP 9: Enjoy
You're done! Go get the girl! Or surprise yourself. Whatever you want.
P.S. Step 9 photos were taken by my dear friend Peter Ascoli (http://peterascoli.com/).
13 Comments
karlpinturr 10 years ago
I assume a cold-cast resin should be fine in a silicone-rubber mould?
And do you know how multiple colours could be defined in a one-piece cast like this, at all? - I'm thinking a gold/silver 'ring', but a clear (or any colour you want) 'diamond'.
lava.tomato 10 years ago
For the metal effect I would use a casting powder (this seems like a good tutorial: http://www.youtube.com/watch?v=uoy5kJ607uI). You could probably make the different layers by casting the whole thing with a metal powder mix like in the video, then cutting off the diamond part, putting the metal cast back in the mold, then pouring clear resin in on top of the first layer.
It seems I'll have to experiment to get what I want - and if I ever get anything worthwhile, I'll post an 'ible and cite yours as an inspiration.
alcurb 10 years ago
slaveboy2000 10 years ago
charlieanderin 10 years ago
trollofdoll 10 years ago
redfoxtrystman 10 years ago
amonj02 10 years ago
