Digital Input With a Pushbutton With Arduino in Tinkercad
Intro: Digital Input With a Pushbutton With Arduino in Tinkercad
Let's learn how to read a pushbutton using Arduino's digital input! We'll connect up a simple circuit using a solderless breadboard and use some simple Arduino code to control a single LED.
So far you've learned to control LEDs with code, which is one use for Arduino's outputs. This lesson builds on outputs by adding an input. Your Arduino board can be programmed to listen to electrical signals and take actions based on those inputs. A pushbutton is one kind of switch, a mechanical device that connects or breaks a circuit.
To optionally build the physical circuit, gather up your Arduino Uno board, USB cable, solderless breadboard, an LED, resistors (one from 100-1K ohms and one 10K ohm), pushbutton, and breadboard wires.
You can follow along virtually using Tinkercad Circuits. You can even view this lesson from within Tinkercad (free login required)! Explore the sample circuit and build your own right next to it. Tinkercad Circuits is a free browser-based program that lets you build and simulate circuits. It's perfect for learning, teaching, and prototyping.
STEP 1: Build the Circuit
Explore the sample circuit embedded here by starting the simulation and testing the pushbutton. Remember that the breadboard rows are connected inside, so you can plug in components and wires to make quick temporary connections. You could load up a new Tinkercad Circuits window and build your own version of this circuit along side the sample.
Identify the pushbutton, LED, two resistors, and wires connected to the Arduino in the Tinkercad Circuits workplane.
Drag an Arduino Uno and breadboard from the components panel to the workplane.
Connect breadboard power (+) and ground (-) rails to Arduino 5V and ground (GND), respectively, by clicking to create wires.
Extend power and ground rails to their respective buses on the opposite edge of the breadboard by creating a red wire between both power buses and a black wire between both ground buses.
Plug the LED into two different breadboard rows so that the cathode (negative, shorter leg) connects to one leg of a resistor (anywhere from 100-1K ohms is fine). The resistor can go in either orientation because resistors aren't polarized, unlike LEDs, which must be connected in a certain way to function.
Connect other resistor leg to ground.
Wire up the LED anode (positive, longer leg) to Arduino pin 13.
Drag a pushbutton from the components panel to the center of your breadboard, and place it across the center column break so that its legs are plugged into four different breadboard rows.
Click to create a wire connecting one button leg to power.
Connect the diagonally opposite leg to Arduino digital pin 2.
Create and position a high value resistor (such as 10K) between that same button leg and ground.
STEP 2: Pull-Down Resistor
Why do we need a resistor in order to read the switch?
At rest, the two sides of this switch are not connected to one another. You can hover over the switch pins to see their Terminal labels. The switch is normally open, meaning at rest, Terminal 12 and Terminal 22 are not connected to Terminal 11 and Terminal 21 of the pushbutton. Arduino pin 2 is connected through a beefy 10K resistor to ground. When the button is pressed, the switch leads are connected, which allows pin 2 to be connected to 5V power, with no resistor. Since electricity takes the path of least resistance, the pin will sense the connection to power strongly, and ignore the weak (10K) connection to ground.
But when no other signal is present (when the switch isn't being pressed), that weak connection to ground is all the pin can sense. So the resistor is "pulling the pin down" to ground, and so it's called a pull-down resistor. Without one, pin 2 would be not connected to anything until the button is pressed. This is called "floating", and can result in random noise from static electricity and electromagnetic interference. Similarly a resistor can be used to tie a pin to power, which is called a pull-up resistor.
Add a multimeter component to the workplane and wire it up to Arduino pin 2 and ground.
Click Start Simulation and click to press/hold the pushbutton to observe the digital signal being picked up by pin 2.
To better understand what's going on, it's useful to also take a look at a free-wired version of the sample circuit, pictured here.
STEP 3: Code With Blocks
Let's use the code blocks editor to listen to the pushbutton, then make a decision about whether to light up an LED based on the pushbutton's state: pressed or not pressed.
Click the "Code" button to open the code editor. Play the GIF above to see the program built in blocks.
Click on the Variables category in the code editor. Create a new variable called buttonState.
Drag out a "set" block.
We’ll store the state of our pushbutton to our variable buttonState. Click on the Input block category, drag out the the “read digital pin” block, and place it into the “set” block after the word “to”.
Since our pushbutton is connected to the Arduino on Pin 2, change the dropdown of the “read digital pin” block to 2. Now your blocks should read “set buttonState to read digital pin 2” which sets our buttonState variable to read our pushbutton state!
Click the Control category and drag out an if then/else block.
Configure it to evaluate whether buttonState is equal to HIGH using a Math comparator block. Drag out the Math comparator block into your if statement to check whether our variable buttonState is equal to HIGH.
We want to turn our LED on if the button is pressed - otherwise, we want our LED to be off. Under the Output block category, find the “set built-in LED to HIGH” block. Try adding two of these blocks to our if statement so that the LED will only be on when the pushbutton is pressed. set built-in LED should be HIGH when the buttonState is HIGH - otherwise, set built-in LED should be LOW.
STEP 4: Pushbutton Arduino Code Explained
int buttonState = 0; void setup() { pinMode(2, INPUT); pinMode(13, OUTPUT); } void loop() { // read the state of the pushbutton buttonState = digitalRead(2); // check if pushbutton is pressed. if it is, the // button state is HIGH if (buttonState == HIGH) { digitalWrite(13, HIGH); } else { digitalWrite(13, LOW); } delay(10); // Delay a little bit to improve simulation performance }
When the code editor is open, you can click the dropdown menu on the left and select "Blocks + Text" to reveal the Arduino code generated by the code blocks. Follow along as we explore the code in more detail.
Before the setup(), we create a variable to store the current state of the button. It’s called int because it’s an integer, or any whole number.
Inside the setup, pins are configured using the pinMode() function. Pin 2 is configured as an input, so we can "listen" to the electrical state of the pushbutton. Pin 13 is configured as an output to control the LED.
Anything after a set of slashes // is a comment, just for us humans to read, and is not included in the program when the Arduino runs it. In the main loop, a function called digitalRead(); checks the state of pin 2 (which will be either 5V aka HIGH or ground aka LOW), and stores that state in the buttonState variable we created at the top.
Below two more comment rows is an if statement that checks to see if buttonState is HIGH (== is a comparison operator, not to be confused with =, which is an assignment operator). If the condition is met, the built-in LED is set HIGH (on). If not, the code contained inside the else { is executed instead: the built-in LED is set LOW (off). If statements can exist alone, or with one or more else statements.
STEP 5: Button Circuit Starter
This circuit is also available as a circuit starter in Tinkercad Circuits. You can use this circuit starter anytime you want to read a pushbutton or other kind of switch or digital input.
Grab this circuit and code combo any time using the starter available in the components panel (dropdown menu -> Starters -> Arduino). The circuit starter has the same code as the sample circuit for this lesson, but lacks a breadboard and relies on the Uno's internal LED wired to pin 13 instead of an additional LED.
STEP 6: Build a Physical Arduino Circuit (Optional)
To program your physical Arduino Uno, you'll need to install the free software (or plugin for the web editor), then open it up.
Wire up the Arduino Uno circuit by plugging in components and wires to match the connections shown here in Tinkercad Circuits. For a more in-depth walk-through on working with your physical Arduino Uno board, check out the free Instructables Arduino class (a similar circuit is described in the third lesson).
Copy the code from the Tinkercad Circuits code window and paste it into an empty sketch in your Arduino software, or click the download button (downward facing arrow) and open the resulting file using Arduino.You can also find this example in the Arduino software by navigating to File -> Examples -> 02.Digital -> Button.
Plug in your USB cable and select your board and port in the software’s Tools menu.
Upload the code and watch your LED light up when you press the button!
STEP 7: Next, Try...
Now that you’ve learned to detect a pushbutton and use if statements to evaluate its state, you're ready practice more coding and explore new digital inputs.
Can you figure out a way to swap the logic in your circuit, so that the LED is lit by default and goes dark when the button is pressed? There are three different ways to do this: try switching what the if statement is evaluating for, or swapping the LED pin states inside the if and else. Or switch the wiring instead!
Continue on to the next lesson where you'll learn to read a potentiometer using analogRead().
Try swapping out your pushbutton for other digital inputs such as a PIR motion sensor or tilt switch.
Learn how to monitor your Arduino's digital and analog inputs through the computer using the Serial Monitor.
You can also learn more electronics skills with the free Instructables classes on Arduino, Basic Electronics, LEDs & Lighting, 3D Printing, and more.
6 Comments
shafeeq17 2 years ago
Scottys_Tech 4 years ago
I can sequence my process using times but for the real project, limit switches would be much better.
Thanks in advance,
Scott
mollie_lc 5 years ago
Am following this lesson and it seems to be going well so far - is there a way to put a value on the HIGH function of the pushbutton?
I'm trying to make a circuit where if the button is held down for 4 seconds, the LED will come on for 2 seconds but any lower than that then the LED doesn't come on at all.
I've managed to do everything else but when using the blocks I'm struggling to find a way of putting a value on HIGH, so if you have any tips/advice then please let me know!
bekathwia 5 years ago
Perfect DIY 5 years ago
whats the software in the screen recording of pushing the button and the voltage meter going up?
Tinkercad Circuits! Used throughout this lesson and all other lessons on this account =D : https://www.tinkercad.com/circuits
