Dixie Porch Lights
Intro: Dixie Porch Lights
I've always liked mason jars. There is something uniquely Southern when it comes to these cultural mainstays. Try this with different colors/sizes of LED's to make it your own.
STEP 1: Gathering Materials/Tools
Mason Jar (with band and lid)
Solar yard light
All weather sealer
Copper wire
Drill
Drill bit
Needle nose pliers
Most of the materials I already had and you can probably scrounge them up easily yourself. I spent $1.50 each on the solar lights at wally world. The copper wire was left over from the Arc Reactor instructable I found and completed from this website. I didn't end up using the needle nose pliers, but they may come in handy depending on the wire you use. I got the mason jars from my grandmother's garage. I recommend you seek those out through a similar avenue to find jars with character. Try to find a variety of jars for the "perfectly imperfect" look. You'll need a drill and a bit that matches up to the size of the LED, more on this later. I used liquid nails clear seal, but any all weather sealant should do the trick.
Solar yard light
All weather sealer
Copper wire
Drill
Drill bit
Needle nose pliers
STEP 2: Bore a Hole
Drill a hole through the center of the lid. Insert the bottom of the light through the hole to make sure the hole isn't too small or too large.
STEP 3: Weather Proof
Run a bead of sealant along the outside diameter of the LED and fit inside the hole you just drilled into the lid. Once it's placed, run another bead on the other side. This will create a "double seal". I chose to seal at this location for a cleaner look. When I first tried this I didn't weather proof at all and wound up with a jar full of rain water. I opened up the solar powered LED yard light and was happy to find an 0-ring seal. Check to make sure the one you purchased has the same.
STEP 4: Rig the Wire
Run the copper wire around the neck and make a bridle. No special skills needed, just make it work. Twist the terminations enough to where they won't come undone. Now they are ready to hang from your awning.
STEP 5: Enjoy!
Hang or place and bask in the glow of your creation on a cool, barefoot and blue jean night.
STEP 6: UPDATE-18 FEB 2013
The sealant wasn't working so hot. I was talking to my uncle about it and he suggested a drill bit for tile and drill a hole at the bottom to let the rain water drain out. I chipped one, so be careful to not cut yourself.
8 Comments
BrownDogGadgets 11 years ago
Anderson Pooper 11 years ago
cwunderbar 10 years ago
Or glass etching cream can work too.
godfish 11 years ago
Dr. P 11 years ago
immrroboto 11 years ago
l8nite 11 years ago
