Don't Throw Out That Ugly Cast Iron Skillet
Intro: Don't Throw Out That Ugly Cast Iron Skillet
If you see one of these at a yard sale grab it!
STEP 1: Burn Off the Gunk
Turn the skillet upside down in the oven and run the self cleaning cycle
STEP 2: Scrub the Crude
This is the only time you should ever use soap on a cast iron skillet.
Using an SOS pad or other scrubber and soap clean off the crust.
Dry completely
STEP 3: Start the Seasoning Process
Heat in a 200 degree oven for 15 minutes
Brush on a thin coat of crisco
Then rub it in and off until it looks dry
STEP 4: Bake on the Seasoning
Preheat the oven to 500 degrees and bake the skillet upside down for one hour
STEP 5: Keep Going
Repeat Repeat Repeat Repeat!
Yep 5 times
Ta Dah!
You have a beautiful vintage cast iron skillet.
Nothing cooks fried chicken like an old cast iron skillet
14 Comments
Pittiemama 4 years ago
shootfilm 5 years ago
RobR2 5 years ago
Love my Cast Iron set!! I got it from my dad when he inherited grandmas old house. The set was siting out in the humid Florida garage for a few decades as grandma started using nonstick cookware. I used a first step of rust removal by using a wire brush on a drill, before steel wool, then heated on grill and used for seasoning.......BACON GREASE!!
stechi 5 years ago
Nice job, but I don't know what you mean by "self-cleaning cycle", "SOS pad", and "crisco". Are they trade names? Can you describe the actual materiasl so we can find something similar in other places? Thank you!
eekanif 5 years ago
The self-clean cycle on most (American) ovens is a timed, very high temp (usually the max temp the oven can attain) program that "super bakes" all of the cooking mess from the inside of the oven. Mine runs for 4 hours. "SOS" is another American brand, it's a medium and fine guage steel wool pad infused with cleanser. "Crisco" is American vegetable shortening (hydrogenated vegetable oil) - typcially used as a replacement for lard. I hope this helps.
Silly Suzzy Sez 5 years ago
My stove has a âself cleaningâ feature, for the oven. You just turn the knob to self clean and in about 2 hours or so the oven will be clean. SOS pads are a brand of steel wool pads impregnated with soap, and crisco is a brand of solid vegetable shortening. If your stove doesnât have a self cleaning feature you can accomplish the same effect using an outdoor grill or a fire pit.
steveastrouk 5 years ago
"Self cleaning mode" is a mode in many electric ovens where the oven can get to an unusually high temperature to burn off carbon.
An "SOS pad" is a scouring pad from cleaning ovenware. They can be made of metal wires, or a material called ScotchBrite.
Crisco is a kind of vegetable oil, often made with Canola or Corn. Flax oil is considered the best oil to season with.
carlos66ba 5 years ago
Nice! Some people say that flax oil provides the best seasoning. I have no experience.
I didnât achieve the results I expected using Flaxseed oil. It takes several more rounds of the seasoning process to get a good finish. I am patient enough for 5 rounds, not so much when itâs taking 8-10 rounds. I use the Flaxseed oil after I have cooked in the skillet as an ongoing seasoning. After cleaning my skillet I put a couple of drops of the oil on my hands and rub it all over the skillet, then rub it off with an old washcloth.
pliska 5 years ago
Iamm1ckser 5 years ago
Would this work on an Aluminium skillet ?
Kind of. Alumnium is very soft though, and its easy to gouge. There is no known toxicity issue with aluminium oxide.
raphan 5 years ago
No only on iron or steel. Avoid aluminium as its oxydes are really dangereous.
Kink Jarfold 5 years ago
My dear ol' mammy used to say, "Waste not, want not." Great instructable.
