Gutterless Rain Barrel - a "Drain Barrel"
Intro: Gutterless Rain Barrel - a "Drain Barrel"
I wanted to share instructions on how to build a "drain barrel" for those of you who may not have gutters on your house. This project is most useful for those of us who have a clearly-defined gouge in our wood chips where the water pours off the roof.
STEP 1:
Purchase three cedar decking boards and screw them together in the shape of a trough. Seal all joined edges with a clear silicone caulk.
STEP 2:
Obtain containers in which the capture the rainwater; it would be best to find containers with about a 2" opening.
STEP 3:
Line up the containers and measure the distance between the center of the containers' openings. Leave about 1/2" per container for expansion. Measure the diameter of the container's opening and use a hole saw (attached to the drill) to make holes in the trough.
STEP 4:
Purchase a 10' length of PVC pipe. It should be slightly less in diameter than your hole. Count the number of holes and divide evenly. Cut the PVC into equal lengths. Purchase a narrowing PVC conduit to glue to the top of your pipes. Drill two holes in the widest part of the conduit and use a miter saw to remove the material between the holes. This will make a slit to help drain the water into the pipe and ultimately into your container.
STEP 5:
Construct some simple "feet" to attach to the ends of the trough. If you drill a hole in the middle of the end of the trough, you will be able to swivel the trough up-side-down on the lag bolt to prevent snow from weighing the trough down during the winter. Dig a hole on both ends for the "feet", level the trough, and add concrete to prevent the structure from moving during a hard rain.
STEP 6:
Rake the area under the trough so that you can remove the containers easily. Insert the PVC pipe, and add metal menders if you like to ensure the container's slit stays level with the trough. When it rains, the water will be directed from the trough, into the PVC pipe and then into your container. When the container is full, lift the PVC pipe out of the mouth of the container, remove the container, and water your plants. When the container is empty, put it back under the trough and slip the PVC pipe back down into the mouth of the container. If you like, you can purchase a rain barrel with which to pour the full containers.
52 Comments
devbert 9 years ago
meralgia 2 years ago
chickrd 2 years ago
CormacF 7 years ago
duh! some houses are governed by lords of the land or HOAs that have the stupidest rules for attaching gutters to the houses (or leaving trash cans outside your gate for more than a day, but that's another article). I'm sure this person thought of that before building. who knows? maybe this is a project for those that are afraid of heights?
carmp3fan 7 years ago
teddlesruss 6 years ago
I think guttering is for the win - saves making guttering. Also easier to make the spouts to go to the rain collectors, you could use PVC cement to glue some 3" lengths in place.
PS: I'm thinking the white PVC guttering not the metal kind.
chickrd 2 years ago
Uncannie1 7 years ago
What about using empty milk containers or cat litter containers? This might work well for my greenhouse, running line (like used for refrigerators) to each area of the plant area would water them. A simple clip would cut the water until you're ready to water the plants. I have a piece of gutter... and plenty of cat litter containers and refrigerator water line. Hurry up spring!
purecajn 8 years ago
the only problem with this build is that all containers must be removed and stored before algae begins to grow due to their being frosted. Using a container that doesn't allow the sunshine thru will help prevent this problem. Also remember to screen the top to help prevent debre and mosquitos.
JON-A-TRON 9 years ago
SMART
wolfgang64 9 years ago
Please can you tell me what kind of containers you used and where you got them?
by the way very nice.
Judycol87 9 years ago
WayneB1 9 years ago
FREAKING COOL!!!! I live in a double wide with a metal roof and was trying to figure out how to do this...THANK YOU...pure awesome!!!!
homer35805 9 years ago
Have you thought about any way to filter the water before it goes into the containers? Maybe a flow thru type arrangement filled with sand for a filter? I know sand is still used as a primary filtering mechanism in many water systems in the US. Other than that, great idea to keep beds from being washed out and capturing rainfall for drinking or just watering...
fahrradtraegertest 9 years ago
Nice water collector
CurtosNoirDesign 9 years ago
jzimbler 9 years ago
I think i would be using really big wide funnels on each container to catch the rain then i can wash the funnels out .... and know the water is as clean as it could be beyond a leaf, or a bug or a bird that enjoys flying and pooping while its raining
