Dryer Fix and Re-paint
Intro: Dryer Fix and Re-paint
I fix things. A lot. But one problem I have with fixing things is that if you do it well no one can tell it was ever broken. It’s kind of a thankless job. “What? That used to be broken? And now it’s not? Oh. OK.”
So sometimes when I fix a thing I like to improve it. Or at least make it clear that it’s not just a new one.
So when the dryer stopped turning, and I had a few days to wait before a new drive belt would arrive, I thought, “why not have some fun with the colors?” The pieces come apart easily, and I already had the front taken off. So here is how I did it.
STEP 1: Take Out the Lint Screen
Take out the lint screen, and remove the two screws underneath.
STEP 2: Open the Top
The top pops up with a little prying with a screwdriver. Use a bungee or rope to prop it open.
STEP 3: Front Panels
The front panel is held on with two screws inside the dryer in the top front corners. Remove those and the front lifts off. The bottom panel just needs a tug on the top to remove.
STEP 4: Remove the Drum
It just lifts out. It's a good idea to vacuum out the inside at this stage.
STEP 5: Check the Rollers
One of mine would barely turn. This is what caused the old belt to break.
STEP 6: Take Off the Seized Roller.
There is a little plastic clip that holds the roller on its shaft. Pry it off with a screwdriver, and the wheel will slide off.
STEP 7: Clean and Grease the Roller and Shaft
It took a little scrubbing to get it clean. Then I used lithium grease to lube it.
STEP 8: Put the Roller Back On
Slide it on. Make sure it turns freely. Then put the plastic clip back on.
STEP 9: Put the Drum Back in and Place the New Belt Around It
The belt needs to feed through idler pulley assembly and go around the motor pulley.
STEP 10: Make Your Mark.
Before putting it all back together, visualize the improvement you want to make. I checked out my spray paint supply and found some colors that I liked together. Then I tried a few combinations in Sketchbook.
STEP 11: Spray Paint
Set up some saw horses. Then spray your parts. You obviously have to do this in stages, one color at a time. But spray paint dries pretty quickly. On a breezy day I was able to re-coat or change colors after 20 minutes. I didn't want to take the top off the dryer, so I painted it with a brush and some black enamel.
STEP 12: Reassemble and Done.
Just reverse your disassembly steps. Done. Smile. Take pictures. Write an instructable. You just saved $400 and didn't have to put a perfectly good dryer in the landfill.
14 Comments
richiebricker 2 years ago
scottdesignworks 2 years ago
Ricardo Furioso 2 years ago
Stevens Workshop 2 years ago
The paint job really finishes it off.
IJustLikeMakingThings 2 years ago
JohnW51 2 years ago
seamster 2 years ago
aaahotdog 2 years ago
