EDC Leather Notebook
Intro: EDC Leather Notebook
A notebook that goes everywhere with you should be used for everything. On one page of my notebook I have an Ira Glass quote, my upcoming flight information, and a grocery list. On the next page are plans for my last ‘Ible. I couldn’t have done that in a Moleskine notebook. I feel like anything I write in a Moleskine has to be perfect; the ideas have to be complete. An EDC (everyday carry) notebook shouldn’t be something pristine. It needs to be something you can scribble notes in and rip pages out of.
This notebook is infinitely customizable.
- There’s a template that can be sized up or down.
- You can make it with many different materials,
- It can have any number of pages,
- And close with any kind of fastener.
Why else would you want to make your own leather notebook? You will never have to buy another one! The pages are replaceable. I cut mine from A4 printer paper. I have carried the same notebook for 5 years and replaced the paper 6 times. I keep the old pages that I want to save in a small binder.
STEP 1: What You'll Need
Materials:
- Leather scrap (6” x 9 ¾” for attached template)
- 2 ft. Leather cord (I used 4mm square latigo)
- 1 Snap (optional)
- 1 Rivet (optional)
Tools:
- Scissors or razor
- Hammer (only if using snaps and rivets)
- Hole punch
- Permanent marker
STEP 2: Trace Pattern on Leather
Using a permanent marker (or a pen if it will mark the leather), trace around the outside of the template. Be sure to mark the holes.
STEP 3: Cut Leather and Punch Holes
Using a sharp pair of scissors (or a razor with a straight edge), cut out the pattern. If using scissors make long and straight cuts.
Punch the holes in the leather using a rotary punch or similar tool.
Save a 3"x 3/4" strip to make the strap that will keep the notebook closed.
STEP 4: Rivet Strap to Cover (optional)
Align holes, insert rivet, cap, and tap down with hammer.
STEP 5: Add Snaps (optional)
The female part of snap will attach to the strap. The male end attaches to the cover. Use the setting tool (which comes with every package of snaps) to attach the snaps.
STEP 6: Lace Notebook
Its time to lace the notebook! But first, we must cut the paper.
I cut down normal A4 (8 1/2" x 11") sheets of paper. The pages in this book are 4" x 5 1/2" so you should get four out of each sheet. Using a paper cutter and a hole puncher, I made enough paper for about six notebooks (~700 pages) in about 20 minutes. If you have access to a drill press, punching the holes would take almost no time at all!
On to the lacing.
Start by tying an overhand knot in the end of the leather cord. To help thread through the holes, trim the end of the cord at an angle. If necessary, use an awl to stretch the holes. Follow the captions in the photos (you will have to click on the photos for some of the captions to be visible).
For extra credit, round the corners of the notebook and strap with scissors.
STEP 7: Enjoy Your New Notebook!
Please post pictures of your notebooks in the comments! I would love to see what you design.
45 Comments
knate2347 9 years ago
I used 6 oz veg tan from a previous project to give it a little more stiffness when sketching on my lap, but loosened the fibers a bit to give it some flex in my bag or crammed in my oversized pocket. After a good oiling and a bit too much wax I laced the pages in with some waxed thread, added a simple keeper strap, and a whittled stick from a bush in the backyard.
Turned out to be a great little book for sketching on the back porch or in front of the camp fire.
joshuallen 5 years ago
Samsonknight123 8 years ago
jogrebe 5 years ago
The PizzaGuy 7 years ago
How can I enlarge the size of the book? Like you know, to your standard sized book?
jaimelicious 7 years ago
Love the 'ible - I love how flexible / durable this looks; most leather-covered notebooks are stiff and heavy.
On an unrelated note, where did you get your wrist splint from?! Mine are all boring beige...
Yoshinok 7 years ago
Thanks! I hope you make a notebook. Be sure to post it when you do!
I think my local drugstore (Kinney Drugs) had that splint. I don't suppose you have them in the UK? Also, I saw from your profile your an archer! You should check my other instructable out and build yourself a bow!
freementia 8 years ago
Any ideas on where to put a loop to hold my pen?
Yoshinok 8 years ago
craigdoll 9 years ago
a noteworthy leather craft...interesting result
Showler 9 years ago
Jwallen910 9 years ago
what weight in oz is the leather?
The Rambler 9 years ago
This is awesome. I made a leather journal as well but I actually bound the pages. I like yours better because you're right, I feel like I can't write anything in it because it's there for good. Now I want to make one where I can rip pages out.
jessyratfink 9 years ago
What a pretty and simple design. :D
Yoshinok 9 years ago
Thanks!
aclevidence 9 years ago
adthegreat 9 years ago
AbDuCt 9 years ago
This is such a cool idea! Have you ever tried to add some rigidity to these somehow by maybe sewing in cardboard or plastic so they are not as floppy? Also have you tried to brand or emboss these? I was thinking about trying to make a mini branding out of wire and heating it up to see if I could burn a design into a project like this. Have you tried anything like this? Thanks again and good job!
I have not tried sewing in anything to stiffen them. The stiffness is actually what turned me off to Moleskines. I can tuck these notebooks anywhere, I like that they are flexible. As far as branding goes on the leather, yes. I have tried it. I think making a solid stamp and striking with a hammer is a bit more effective than a hot brand. Heat on leather can often make things contract/expand in ways that will make the surface pucker.
AbDuCt 9 years ago
Do you have any photos of the stamped leather? Also how much strength do the pages have? Would they tear and fall apart if you are a bit to rough with them or are they fairly sturdy unless you mean to tear them out? One of my concerns is the pages coming dislodged or torn by accident if I am a bit to rough with it. Thanks for the reply!
