Easy Greywater System
Intro: Easy Greywater System
Super easy steps to reduce your water consumption through use of greywater. Simply fill up buckets with excess water from your shower and sink and use it to flush the toilet.
STEP 1: Buckets!
Obtain medium sized buckets in order to fill up with water either from your sink or shower.
STEP 2: Shower or Sink or Both!
You can fill up the buckets with water from your shower while your waiting for it to heat up. You can also fill it up with water from your sink. This only works with sinks that have external plumbing, or pipes you can see and touch. With these sinks all you need to do is place the bucket beneath the sink and open the valve located on the pipe. You'll see that all the water going down the sink will be caught in the bucket and can be used to flush the toilet. Make sure you do not fill up the water too much, it may be too heavy to easily pour then. You want it to be about a liter and a half.
STEP 3: Do Your Thing!
enough said..
STEP 4: Flush It!
Pour the collected water directly into the toilet bowl. It will flush if there's enough water, guaranteed! Now you have efficiently used the bathroom and saved water in the process! Yay!
13 Comments
martin farid nilchian 7 years ago
I noticed the finish in my tub has worn down a bit over time, due to the hard plastic rubbing in the same spot (especially where the tub curves upwards). Little bummed about it, this was supposed to bring good karma to my showers!
My shower runoff gets me 3-5 gallons a day. (It's become kind of a game to keep it at 3 gallons)
But consider this stunning fact:
5 gallons a day = 1,825 gallons a year
1 pound ground beef = 1,847 gallons of water
Pa1963 8 years ago
Did you undo the trap under the sink? You need to keep some water in that bend to block sewer gases.
SpeakForTheTrees 14 years ago
justbennett 12 years ago
tinker234 12 years ago
diy_bloke 12 years ago
372752 12 years ago
mrfoltz 13 years ago
jayufa 14 years ago
jtobako 14 years ago
dmcunningham 14 years ago
steelnix 15 years ago
Mr. Rig It 15 years ago
