Easy Pattypan Mini Souffle
Intro: Easy Pattypan Mini Souffle
Pattypan are less known cousins to pumpkins. They look funny, can grow up to a moderate size, and taste very delicate and slightly sweet when young and small.
Here is a soufflé recipe that is quite simple. In particular it does not involve separating egg yolks from white and beating the latter.
STEP 1: Gather Ingredients
For two small pattypans:
This recipe is only about the pattypans, so you should additionally plan the other parts of your meal.
- 1 egg
- 100g cheese (Gruyere, Tilsit, Jura)
- 1 dl cream
- pepper
STEP 2: Prep the Pattypans
- Carefully cut off the top part
- Hollow out the pattypan
- Keep the top part for decoration, cutting it thinner if needed
- Steam for approx 2 minutes
STEP 3: Make the Filling
- Mix one egg
- Add grinded cheese
- Add cream
- Add some pepper
- Optionally, add some pressed garlic
STEP 4: Bake
Pre-heat oven: 180°C / 360°F, middle to slightly low rack position
- Cut a band of wax paper
- Staple it to form a ring
- It must fit into the hole
- Carefully add the filling, not exceeding the top of the pattypan
- Meanwhile, cook any other things you have planned.
- Constantly check your oven. The top of the soufflé may not burn. Due to the fact that the heat has to cross the pattypans, it takes a bit longer than for traditional small soufflés. If it is still liquid but brown on top, switch the heating to bottom only.
STEP 5: Serve
Serve with rice or noodles, and anything else you want. Add spices according to your liking.
Bon appétit!
Bon appétit!
6 Comments
tmenig 12 years ago
laxap 12 years ago
If you use beaten egg whites, it could grow much higher than on the photo. With the paper you'd get a nice cylinder.
shesparticular 12 years ago
laxap 12 years ago
I've only seen the micro ones as preserves in oil, stuffed with goat cheese or philadelphia-like cream cheese. I just love them too. But I think the size would make them very critical to host a soufflé, as well as to get baked properly.
jessyratfink 12 years ago
laxap 12 years ago
