Easy Wall Mounted Storage Bins for Hardware Parts
Intro: Easy Wall Mounted Storage Bins for Hardware Parts
If you're a maker, they you probably have acquired a vast assortments of parts, screws, widgets and assorted random bits. And if you're like me, then they've all disappeared into cabinets and drawers, never to be found when you really need them.
I decided to organize all my parts into bins that allow me to easily see in a glance what parts I have. At first I was going to build standard shelving, but then I came upon a solution that's inexpensive, easy, flexible and fast. And it looks pretty cool, too!
STEP 1: The Storage Bins...
The key to this project is the bins. I picked up these made by Akro-Mils at a local Grainger store. They're also available on the web for $0.90 each, in cases of 24. This is the model that is 5.5" deep by 4" wide by 3" tall. Blue, yellow and green.
The key feature for the bins is the hook along the back, that is designed to fit into their shelving systems.
These bins also have a 3" by 1" slot in the front for a label.
Other brands & models may work well, but I can vouch for these.
STEP 2: ...and the Mounting Rails
The hardware I used as mounting rails is actually intended to be flashing for dry wall. It cost about $8 for an 8 foot length, which will hold 23 4" bins. Yeah, the math doesn't work out perfectly there, but the bins are actually a hair wider than 4", and you want a little bit of space between the bins when you hang them.
STEP 3: Preparing the Mounting Rails
This is pretty sttraight forwards. Drill a hole at each end and about every foot along the rail. I think I used a 3/16th bit, but it just needs to be large enough for your mounting screws.
STEP 4: Mounting the Rails
Using a level, mount the rails on the wall.
This would probably be a fine time to point out the obvious: You should be mounting this on some sort of finished walls, rather than on a wall that's just exposed studs. If you have the latter, hang 4x8 sheet of plywood on the wall, and attach the rails to it.
I seperated the rails by 4 inches, and used a level to guarantee some semblence of levelness. Although I mounted them myself, it probably would have been a bit easier with an assistant.
STEP 5: Hang the Shelves on the Rails, Fill With Parts, Label and Resort
Once it's all mounted, hang the bins. I got 92 bins to fit in this space. Amazingly, when I went through all my stuff, I ran out. I guess I'll be building more...
For $150, this gives me a really nice organization scheme. Parts are visible, classified, and easily accessible. I will be investigating using some larger bins in other areas to handle oversized parts, but so far, it's been an unqualified success.
56 Comments
bigbadbuzz8 1 year ago
joshua.bastion 3 years ago
ALANC65 4 years ago
RichardP331 4 years ago
There are only a godzillion Sheetrock flashing types
Any clue you could impart which type?
Mike Begley 4 years ago
https://www.menards.com/main/building-materials/drywall/corner-bead/phillips-1-2-x-8-metal-j-bead/jt5hdgmen8/p-1444450726927.htm
I just picked it up at my local Ace hardware. I suspect if you ask for J trim for drywall and show them a picture, they'll be able to find something.
Kink Jarfold 5 years ago
Very nice solution to all the little parts I have roaming around my shop.
KJ
Snowberry 7 years ago
Nick9999 7 years ago
Very cool. I've also used the steel panels with parts bins https://www.plasticboxes.co.uk/gavanised-steel-lou...
Having the bins angled like that is a good idea. Thanks
MarkSindone 8 years ago
Organizing things regardless of where the location is will help to maintain a neat and tidy area to encourage easy retrieval later on. I am in the midst of sorting items out from various rooms around the house before putting the rest up in storage and I think I’m going to start with the workshop with your instructable.
RickS70 8 years ago
real nice.....just what I need
Yonatan24 8 years ago
That looks so cool!
huttarl 9 years ago
Thanks for a helpful instructable. This got me going in the right direction for what I needed. I ended up finding a set of 20 of these bins for $10 at Harbor Freight (including some plastic rails).
hammer9876 13 years ago
Mike Begley 13 years ago
bobzjr 11 years ago
static 13 years ago
noahspurrier 13 years ago
agatornz 12 years ago
marc.cryan 13 years ago
I'm using J-channel from the drywall section of home depot, it is about $2 for 10ft.
kyzla 13 years ago
"How? What? You could have waited!"
"You'd only get in the way," I say.
I've been doing it solo for 15 years...
It's almost easier when you're trying to balance the length of wood/flash/bracket/whatnot and the level and the pencil and the drill as opposed to just the pencil.
ha!
