Edited Drawings Saved As JPEG
Intro: Edited Drawings Saved As JPEG
I have an old, inexpensive CAD program that does some nice things, but it cannot save in a format I can load with my Instructables. This Instructable will tell how to convert drawings from any drawing program to the JPEG format.
In the photo you see a simple cylinder I made in my CAD program. The CAD program does not allow me to erase unwanted lines. (If it does, I have not discovered how.) Perhaps I could have drawn or painted over the unwanted lines with a color identical to my chosen background color. But, I will show you an easier way later.
STEP 1: Move the Drawing to Microsoft Paint
Press the PrtScrn/SysRq button on your keyboard. This saves your current screen to the computer's clipboard.
Open Microsoft Paint. The photo below shows the trail to Paint through All Programs.
STEP 2: Paste Into Paint
Pull down Edit on the Paint menu and select Paste. The screen image containing your drawing can now be edited further in Paint. But, do all edits possible in the draw program before beginning to edit in Paint.
STEP 3: Erase Unwanted Lines
Click on the yellow eraser from the tool menu. Select the width of the eraser's coverage (blue square at the bottom of the vertical toolbar) and begin erasing unwanted lines.
STEP 4: Crop
Use Paint's Crop tool to outline the portion of the image you wish to use. The image should be as large as possible on the screen. You can enlarge the view by pulling down Paint's View menu. Go to Zoom and select Custom. A larger image will produce better final results.
To make the actual crop, pull down Paint's Edit menu and select Cut. Then Pull down Paint's File menu and select New. When asked if you want to save your changes, click on "No."
STEP 5: Paste and Save As a JPEG When Finished.
Pull down the Edit menu in Paint and select Paste. Then pull down the File menu in Paint and select Save as... Open the Save as type... window in the Save dialog box. Select JPEG and save to your hard drive.
STEP 6: Finished
You now have your edited drawing ready to upload with your Instructable, or to use in some other way. You have combined the best features of your favorite drawing program with those of Paint, and saved the final product in JPEG format.
11 Comments
Bill WW 11 years ago
I use both AutoCad LT and TurboCad for engineering drawings, both are more complex than we need for Instructable projects. TurboCad is a much better value than the overpriced AutCad. Home Plan Pro is a very user friendly and inexpensive CAD software.
Phil, you often add annotation and arrows to your photos. Do you do this on Photoshop, or a different program?
Phil B 8 years ago
Bill,
I apologize that i did not see this until three years after you posted it. I usually add arrows and notations in plain old, no frills MS Paint.
Bill WW 8 years ago
Gee, that was so long ago - I forgot about it. Yes I also use MS Paint.
iceng 8 years ago
Does it have smudge ?
Phil B 8 years ago
I do not believe it does.
maruawe 15 years ago
Phil B 15 years ago
jongscx 15 years ago
ac1D 15 years ago
PKM 15 years ago
