Electric Acoustic Guitar
Intro: Electric Acoustic Guitar
STEP 1: Microphone
The major thing that you will need in this project is a microphone ( any kind ) as you can see i got mine from an old rock band microphone from a broken wii
STEP 2: Disasemble Microphone
Only disasemble if it is a big microphone if not, it is completely unnessecary
STEP 3: This Is What It Should Look Like After Youve Taken the Top Off
STEP 4:
From here you should be able to pull the body out
STEP 5: Then the Base
STEP 6: Cut the Wire
Cut it as far down as you can at first to be safe
STEP 7: You Should Then Be Able to Pull Off the Bottom
STEP 8: Strip Wire
Strip the wire so you can remove the actual microphone from the body
STEP 9: Strip the Rubber Coated Wire
STEP 10: Get an Amplifier Wire
STEP 11: Strip the Amplifier Wire
STEP 12: Install Mike Into Altoids Can
Connect the wires from the amplifier and mike in an altoids can or any mthing like one
STEP 13: Install Foam
Foam will support the mike and prevent scruffy sounds
STEP 14: Poke Holes
Poke holes to enable sound through can
STEP 15: Sound Filter
Install a thin layer of foam above the mike for better sound qualaty
4 Comments
john_houle 10 years ago
MikB 10 years ago
Nope. You got lucky. Your Wii/Rockband mic must be a dynamic mic, meaning it generates a signal without needing external power. A magnet and a coil. This is good.
A lot of cheap microphones use an electret capsule. These produce no signal unless they are powered, and a guitar amp won't provide the low voltage bias needed to run them, so you now will have to add a battery, a resistor, a DC blocking capacitor. Otherwise, no signal.
Stick with dynamic mics for ease, else look up powering electret mics -- it's only 2 components and a battery, but they are essential!
