Eliminating Tree Rats
Intro: Eliminating Tree Rats
Rats carry more than 40 harmful human diseases and rat-borne diseases are thought to have taken more human lives in the last 10 centuries than all the casualties of all the wars and revolutions combined. Each year, rats destroy approximately 20% of all the agricultural products in the world, including going after my mangos and avocados. Also, rats eat eggs and prey on baby birds as you see in the top photo.
SO, the problem is how to get rid of tree rats. Setting traps in trees is difficult, time consuming, dangerous from repeatedly climbing ladders, need to be checked daily, and are not very productive. Using poison on the ground in proper bait boxes will have little to no effect on tree rats. Putting poison in trees can kill a lot of birds.
I have a very simple solution that gets the rats but not the birds.
STEP 1: Eaten by a Rat
This is an avocado eaten by a rat. You can tell by the long smooth tooth marks. They only eat the very top of the avo while it is on the tree, and then the avo falls to the ground.
STEP 2: Eaten by Birds
This is an avo eaten by birds. You can tell by the small holes made by their beaks. HOWEVER, it was probably eaten by a rat first which is why it ended up on the ground, and then the birds got to it.
STEP 3: WHAT YOU WILL NEED
Rat poison, block type with holes (Several brands available)
Wire, String, or whatever
Old plastic bottles
Scissors
Pliers to cut wire
WARNING: PLEASE read the caution label on the poison carefully.
Also, NEVER use rodent poison INSIDE your home. The rodent may die in a hidden place and you may not be able to find it resulting in a horrendous rotting stench for months.
STEP 4: Make a Tent
Cut the ends off a plastic bottle with scissors, band saw, knife, or whatever method suits you.
STEP 5: Keep the Tent Low
If you have a large bottle like the above, cut it in half with scissors, band saw, knife, or whatever method suits you.
STEP 6: Make a Hole
Make a hole in the long side of both sides of the tent using nail, knife, drill, screwdriver or whatever.
STEP 7: Secure Bait to Tree Limb
Secure the bait to a tree limb using wire or string. No need to twist or make the wire tight because you will be replacing the bait periodically. It is only necessary to hold the bait in place.
STEP 8: Cover the Bait
Secure the plastic bottle section over the bait using wire, string or whatever suits you.
STEP 9:
Rats can get through a hole the size of a quarter (Euro) so keep the tent low to keep out birds.
STEP 10: Long & Low
A long, low tent is better than a short fat one. That makes it really easy for rats to get to and impossible for birds.
STEP 11: Use Several Baits
Put several baits in each tree. Check fallen fruit for evidence of being eaten by a rat and add a bait and tent on the limb above that location.
STEP 12: The Enemy
Rats carry lots of diseases and are dangerous to the health and well being of you and your family.
STEP 13: Success
You may or may not find the dead rat(s). They often go back to their nests to die. Dispose of the dead rat promptly and properly. Best wishes, Mauibuck
17 Comments
popRemedyWorks 5 years ago
1. wear plastic gloves during the whole process. not due to any toxicity to you but to ensure you do not taint the end product with your own human smell
2. measure exactly equal quantities of these three items:
a cup of flour
a cup of fresh moist brown sugar
a cup of plaster of paris
3. first mix the dry ingredients very thoroughly with a metal spoon
4. make a well in the centre and add a little water. not enough to make it sloppy. start mixing all the dry ingredients until you get it to look like a crumb. try making a ball with a small handfull of the mixture. if it will not "stick" together add a tiny scant more of water. then keep working the mixture with your plastic glove covered hands until you can make a ball shape that holds firm. Make balls a little smaller than a golf ball.
5.Rats like finding food in hidden places where they can nibble in peace. Place three or four balls inside at the middle of a metre long length of plastic piping conduit at ground level, where the plastic conduit is wide enough for a rat or mouse to enter, but much harder for a bird to get in.
6. for stability place a brick on either side of the plastic conduit stationed on the ground, so it does not move when the rat enters.
7. if installing the conduit higher, such as up a tree, then wire it firmly to a branch so it remains horizontal and stable when a rat enters or departs from the tunnel
8. check the tunnels daily and make a new batch of balls after each ball has been well nibbled. Make sure the rat larder is well stocked until such time as no balls have been touched for 4 weeks = usual signal that you have succeeded in eliminating the rats this time
The plaster of paris sets hard in their intestines after they eat it meaning they cannot eat and so they starve to death.
Wearing plastic gloves to position additional items in the plastic tunnels - I also add in fresh rhubarb leaves, fresh green bay leaves, sprouted eyes cut off green potatoes and diced avocado skin - some items also dipped in golden syrup - to add a smorgasbord of edible items that are alleged to be harmful or toxic for rats.
BarbaraT61 7 years ago
Buck in Maui, I have busy rats in Waialua in a avocado tree eating 1/2 the skin off of the avocados. I am on the edge of farm land. Have seen barn owls fly in at night to eat rats, but obviously not enough barn owls to solve problem. I had thrown rat poison (D-Con) at base of tree last year and there were no chew marks on avocados. This year thought I had solved the problem, but they are back and only 1/8 of tree producing fruit, so loosing any is painful after waiting a year. How could I get more barn owls to go after the rats? The barn owls are amazing to watch fly in. Thanks
MANthrax 5 years ago
You can get more barn owls if you stop killing them by feeding them poisoned rats. When they eat poisoned rats the owls die or maybe screws up reporduction.
Mauibuck 7 years ago
In the 10 years I have been using the posted method, I have only found 2 dead rats and I have virtually NO rat problem. It is my understanding that the rats go back to their nests and die there.
On the other hand, virtually every day I find avocados that have been eaten by birds. Avocados are deadly to birds and cattel, but MAYBE not so much for chickens. Avos are also toxic to lactating mammals but not humans.
"Where does the recommendation come from to not feed your pet bird avocados? According to "A Guide to Plant Poisoning of Animals in North America," avocado poisoning was first reported in 1942 in California, and its toxin — at the time not precisely identified— affects cattle, horses, goats, canaries, budgies, cockatiels, ostriches and other birds and animals. Ostriches have died of congestive heart failure within 96 hours of eating the fruit and leaves of avocados. Symptoms of avocado poisoning in other birds include respiratory distress and sudden death."
So, we are sort of damned if we do and damned if we don't. Grow avos, kill birds. Put out rat poison, maybe kill an owl or pet. There are no perfect solutions. Don't put out poison, the rats devistate the avos and grow big families. I only use the posted method when I see evidence of rats eating either my mangos or avos. It works. Putting the D-Con on the ground will poison birds. I found that out the hard way.
Switching subjects slightly, to improve the yield of my avos and mangos, I use a 16 inch long 1" bit in a 1/2 drill and make holes as deep as I can, about 4 feet apart, at the canopy drip line and fill each hole with a tropical fruit fertilizer. The objective is to get the fertilizer down to where the roots are. Spreading fertilizer on top of the ground is highly ineffective. I do this twice a year, for both my mangos and avos and get great crops every year. In fact, when my avo blooms, I cut off 40% of the blossoms to keep it from overbearing. My avos grow to over 2 pounds. You get 30" rain/year in Waialua. I'm in Kihei and get MAYBE 17" but I irrigate the lawn so we are probably are about equal in water to the trees.
Cacadogg 8 years ago
⊙ ⊙ ⊙ ○ ○ ○ IMPORTANT ○ ○ ○ ⊙ ⊙ ⊙
Please take a look at this article regarding rat poison.
ThanQ
https://www.audubon.org/magazine/january-february-...
amcayanan 8 years ago
Excellent! love the idea of covering the poison to protect the birds.
moen-the-grass 8 years ago
newtypetuna 8 years ago
your information about rats is incorrect to say the least, try not using only google as a research tool but sites with credible sources -masters in terrestrial mammal ecology
Mauibuck 8 years ago
Unfortunately, those who study and try to predict pandemics do not share your view . http://www.pnas.org/content/112/22/7039
Big Projects 8 years ago
Very smart idea
slo5oh 8 years ago
To each their own OP. Trap, shoot or poison. Trapping can catch the wrong animal, poison can work it's way up or down the food chain. I say buy a decent pellet gun and learn to shoot it.
saumipan 8 years ago
You don't need to spread misinformation about rats to demonstrate how to kill them. Rats, themselves, only spread a couple diseases, and only through ingestion of feces. Who eats rat feces? Be clean, don't blame rats. There are humane traps, too, by the way, for catching and releasing rats.
Saumipan, thank you for your comment. I live in Hawaii and we have a VERY dangerous problem with rats. "A 23-year-old man living on the island of Hawai‘i developed a life threatening case of eosinophilic meningitis caused by infection with Angiostrongylus cantonensis (rat lungworm disease: RLWD). He was comatose for 3 months, incurring brain and nerve damage sufficiently extensive that he was not expected to recover." We have had 42 cases that we know of from 2007-2015, eight years. Please google and read up on rat lungworm disease. Our concern is real and life threatening.
rafununu 8 years ago
These poisons are blood fluidifier, the animal dies of hemoragy and you can be pretty sure it will suffer a max.
Regarding diseases, I read somewhere they are catched by their fleas, not them directly. It was the case for the black pest that killed one third of europeans in the middle age, testimonies reported that rats died as well.
RevJuliaG 8 years ago
Some poisons can be secondary fatal, meaning that any animal who eats the dead animal can be effected by the poison. Please check the instructions on the bag of poison or their online information. I have cats and they are not interested in dead animals, only live ones. But I too have the concern.
