External Xbox 360 Hard Drive (HDD)
Intro: External Xbox 360 Hard Drive (HDD)
This instructable is on how to create your own external Xbox 360 hard drive.
This hard drive can be used to store: Music, videos, photos, a much more!
STEP 1: Supplies
What you need for this instructable is:
1 Xbox 360
1 external hard drive
1 USB cable
1 Power cable ( if your external hard drive requires it)
To start off plug your hard drive into your mac. (USB cable, power cords)
1 Xbox 360
1 USB cable
STEP 2: Formating
To format your hard drive for the 360:
Open the application "Disk Utility" (it's under the utilities tab in your applications folder. Picture 1)
With disk utility open, select your hard drive model; not the name you've given it, just the model...
Then, select the partition tab... Picture 2
Now, you should see a drop down menu labeled "Volume Scheme."
This menu is were you choose how many partitions you want on you hard drive.
My drive is pretty big so I chose three partitions..
Chose your desired size of your partition.
Then, in the drop down menu labeled "Format" select "MS-DOS (FAT)" for your 360's partition;
you can choose different formats for other partitions.
Hit Apply...
Hit Apply...
STEP 3: Add Files
Now you can add almost any files to your hard drive!!
I chose to add some music & a few movies...
you can add what ever you want...!
STEP 4: Xbox 360
Now it's time to play, use, hack, etc. all of the files on your hard drive...
First, plug up all of the necessary cables (USB, Power) to your 360.
Then, turn on your 360 and go to your "music library" press A (picture 3)
Now, select your source as "Portable Device."
Finally chose what files you want to play, use, hack, etc.
35 Comments
katie.vanderwende 9 years ago
If you have a windows machine it will be the same steps fat 32
manson1 10 years ago
what if u dont have an apple mac computer and all u have is a pc...
2026933 10 years ago
Deus 15 years ago
willrandship 14 years ago
Deus 14 years ago
Really? That's weird considering they are MS. Wasn't XFS what the original Xbox used?
Brian996 11 years ago
gmh5760 12 years ago
my 9 lives 12 years ago
mr.noris 13 years ago
wnbtechie 13 years ago
easy way to upgrade your Xbox hard drive for the cheap without worrying about the limitations of an external hard drive or the complications of doing a JTAG
hi111 13 years ago
hi111 13 years ago
cody777 13 years ago
27723773 13 years ago
Deus 15 years ago
duct tape 14 years ago
Deus 14 years ago
