Flat Pack for Storage Plywood Picnic Table
Intro: Flat Pack for Storage Plywood Picnic Table
These picnic tables are each made from a single sheet of plywood, take about 30 minutes to mark out, and about 1 hour to cut out. The sanding and painting is down to the individual, so I'll not quote any times for these two processes, but I have finished mine with a combination of wood preserver on the undersides and gloss paint on the topsides .
A short video of me assembling and disassembling one of my picnic tables: http://www.youtube.com/watch?v=xATfmOkLh7Q&list=UU1iX9q83W978_o37wLxqkvw&index=2&feature=plcp
You will need a copy of the plans, which you can download and save from here:
http://familyfun.go.com/crafts/picnic-table-to-go-709134/
To mark out the plywood, you'll need: a rule or tape measure, a pencil, a square, and a straight edge of about 4 feet long, or slightly longer; a planed 4 X 1 piece of timber just over 4 feet long, or a length of steel are ideal.
I have used a cordless jigsaw for the rounded cuts, and cordless circular saw for the long straight cuts, but a jigsaw will be more than adequate for all the cutting requirements.
Pay close attention to the plans, as they follow both a Centre Line set of dimensions, and Accumulated dimensions from the bottom edge of the sheet of plywood. The only really tricky part of the plans and the dimensioning is ensuring that you follow the accumulated dimensions correctly and mark out accurately.
Note: I have used 18 mm thick shuttering plywood rather than the recommended 1" thick plywood: so if you follow my lead here, you'll need to reduce the joint let ins from 1" to 18 mm.
STEP 1:
You will obtain a good quality of cut if you use a jigsaw blade that cuts on both the up stroke and the down stroke.
STEP 2: The Cutting Order.
1) Cut out the table top.
2) Cut out the seat supports
3) Cut out the seat tops
STEP 3: Cutting the Detailling
When these are done you can begin cutting all the curved detailing for the table ends and centre support on the remainder of the sheet; it is easier to do this now before you cut these components from the sheet.
STEP 4:
STEP 5: This Step Is Optional:
In my opinion they are not necessary near the top of the table end, but would be better placed lower down the panel.
I have used a 2 inch diameter holesaw and a jigsaw to cut out the hand grips.
STEP 6: Time to Cut Out the Slip Joints
STEP 7:
Here is a link to the additional instructable on how to make the additional feet for the picnic tables shown in the photo:https://www.instructables.com/id/Additional-feet-for-Picnic-tables/
I painted two of my six tables bright yellow to use at the many shows and festivals that we attend, but that was a mistake as it attracts many flying insects. We now have them painted a more subdued gloss Yellow (Ral 1028) which does not attract the insects. The Cargo Cycles logo and contact details have been applied to the table top, which has turned out to be a rather good way of making the public aware of my business .All six flat pack plywood picnic tables and two 25 X 10 marquees fit into the back of one of our electric assist Pedi-vans with room to spare .... a great way to haul stuff around the on the show grounds and festival sites.
32 Comments
JohnG253 8 years ago
I made half a dozen of these tables for my local Scout group about 13 years ago. I found that, no matter how careful I was, I always had some breakout with the ply so I ended up chewing the cutting of the main parts & finishing off with a router to put a nice smooth, rounded edge on everything. I also scaled everything up slightly. The base I constructed from 18mm ply (for strength) and the top/seats came from sheets of 12mm ply to cut down the weight. Since the top is the only piece carried separately, I added a handy waste bin holder - cutting 2 holes with a large hole saw, just touching each other. These were then made into 1 large hole with the jigsaw. A couple of small scraps of wood were then screwed to the underside to hold the handles of a carrier bag. All waste spilled on the table was then easily pushed into the opening. I also made some of these to use in the camp kitchen since they are VERY portable / sturdy / stable. Finishing them off with plenty of varnish to make them long lasting & easy to clean.
The table used for the hot water urn had to be easy to level. This was accomplished by making 4 squares (feet), attaching them to 12" uprights with hinges (so they would take up less room when transporting) and utilising some simple pegs through holes drilled in the legs & uprights.
These tables went with us on dozens of camps and survived far, far longer than any of the professional kit they bought - and the beauty of this design - if you break it, it's easy to perform an emergency mend (wood glue is very strong) and easy to cut a new piece.
Gareth0123 8 years ago
Yes, the plans for these plywood picnic tables have been around for a very long time. We even had these tables when I was in the 4th Melton Mowbray Darwin cub scout pack some 45 years ago, and the plans probably pre-date me at 54 years old by at least another 10 years: http://sne.tripod.com/camptbl1.gif
Using the the fine "double cut" jig-saw blades that cut on both the up and down strokes as shown in the main Instructable does considerably reduce the chance of breakout
MarkSindone 8 years ago
I have always loved DIY furniture pieces which are low cost and easy or convenient enough to make. This is because when I need to move out to a new location, I can just simply leave my current furniture pieces behind or dispose them off as they are not expensive and I can just build new ones upon arriving at the new house. This concept really helps me in making house move easier and saves time and effort.
BartholomewH 8 years ago
Lovely flat pack project!
Among my favorite knock down fittings here!
Cheers mate!
PasadenaMom 9 years ago
So my neighbor gave me this for my sons.. I plan to sand and paint.. But, what is the little base thingy made of? I don't have that...
Gareth0123 9 years ago
I assume that you mean the additional feet mentioned in step number 7. There is a link to a separate instrcutables for them included in step number 7.
Here is that same link; https://www.instructables.com/id/Additional-feet-for-Picnic-tables/
woodbox 9 years ago
Hello, Gareth!
Using your idea, I made a drawing of such a table to cut it on the CNC
Download drawing can be here
http://mebel-sam.net.ua/proekty/item/70-stol-iz-lista-fanerny-so1
Plan download to print off.
davidags 10 years ago
orindentonhiggins 10 years ago
vandykee 10 years ago
Long time DIYer; first time commenting here. I knocked this project out in two weekends: one to (go to the hardware store and) mark out and cut, one to rout the edges and paint.
They say that you can pick two out of these three: better/faster/cheaper. I chose faster and cheaper, without caring much about looks. I predrilled 3/8" wherever I had to change the jigsaw direction, then hacked some pretty unstraight lines. >_<
I used a roundover bit in a handheld router on all the edges and a quick run of the palm sander just so it would take paint. Going for speed, I slapped 3/4 of a quart of primer on the pieces, then 8 oz of clear polyurethane (1 coat) and called it done.
When assembled it's got an obvious wobble due to my rough/wide jigsaw work. I knocked a wood shim in the worst gap (where the three base pieces overlap), and it's good enough for a camp kitchen. It's white and far from perfect but it should last me through a couple camping trips.
EcoExpatMike 10 years ago
A pic of the one I built here in the Philippines with my niece testing it out...
SUGGESTION, make the channel slots for the plywood 7/8ths inch so it isn't so tight. I had to sand the HECK out of it to get it to go together easily...
Enjoying our little house in the Philippines but tools here are SO expensive...
The kids love it. And the local carpenters, once I was done, said I could get 3000 pesos for it! With just 1250 pesos for the 3/4" marine grade plywood. So 1750 peso profit makes me around $40 richer if I sell out!
psidat 10 years ago
http://www.rollanet.org/~rrars/tech_files/picnictable.pdf
Mike
kevinhannan 10 years ago
However I cannot find the plans and have trawled through the website link. If I get to see the plans I shall certainly have a go at this fine 'ible.
Gareth0123 10 years ago
If you scroll down to the bottom of this web page, you will find a (free) downloadable PDF version of the plans http://overthegate.myfreeforum.org/sutra268083.php#268083
allen.curry83 11 years ago
DeanAshby 11 years ago
