Folding Bed Bench (Hidden Cot)
Intro: Folding Bed Bench (Hidden Cot)
I found a version of this bed at a local antique barn. I loved the idea of it and couldn't find any plans online. So here is my interpretation.
This bed works well for small basement suite my wife and I rent. We love having friends over, but if anyone needs to sleep over they are usually subjected to the floor. This handy bench solves the problem and provides a conversation piece at the same time.
This project posed a few complications. Precision and accuracy are necessary. Replicating 32 1x7/8"x24 pieces with 3 holes drilled in the correct spot is difficult.
Hardware is expensive, again everything needs to be the same. I tried to avoid using washers and discovered the leg pieces flexed and jammed against themselves. Washers solved this issue.
Finding material that can flex but is still strong enough. I chose this canvas but it will still need to be reinforced with a cotton belt along the edge to prevent the grommets ripping out of the fabric.
What I learned:
No need to replicate exactly what you see, I made the legs 1x7/8x24" because that's what the original was. It would be simpler to do 1x1x24
Mock everything up first
Sand after everything but before applying a finish.
Be flexible and don't stick to the original design if it doesn't work.
I hope to make another in the future and will post a more detailed instructable.
Hope you all enjoy the photographs.
Material:
Maple (Hardwood store listed it as "Eastern maple")
Thick canvas
Tools used:
Drill press
Thickness planer
Jointer
Table saw
Mitre chop saw
Cordless drill
Orbital sander
Hardware:
Hinges (x2)
8x2 wood screws (
6x 1 3/4 wood screw (x8)
3/16x 2 1/2 metal screws (x44)
3/16 nuts (x44)
washers (44)
1 5/16 eyelet (x16)
Brass grommets 3/4 (x14)
latch with eyelet (x2)
What I learned:
Material:
Thick canvas
Tools used:
Drill press
Thickness planer
Jointer
Table saw
Mitre chop saw
Cordless drill
Orbital sander
Hardware:
Hinges (x2)
8x2 wood screws (
3/16 nuts (x44)
washers (44)
1 5/16 eyelet (x16)
41 Comments
lsmith254 11 years ago
Tip on the grommets: mark fabric carefully and set them dead-center on those marks; less than 1/8 inch off and you will get that sofa-bed "bar-in-the-back" feeling. If you are new to using grommets, they can be removed carefully with a pair of wire cutters. If you can't find matching strapping or webbing, just fold the fabric so there are three full layers of canvas for your grommet row. Dampen your canvas with a sponge during test fit and apply pressure with your palms at tight points. Allow to air dry in open position.
Samw 11 years ago
CindraPalmer 10 years ago
Onyons 10 months ago
Thanks
Romero.Centre 3 years ago
margarethd 9 years ago
A a idéia,vou tentear fazer depois posto as fotos.
kreator 9 years ago
This looks really neat but I have question..doesn't it feel uncomfortable laying on it because of the support pieces running through out it..thanx in advance
karisteed 10 years ago
I am going to attempt to make this bed bench but I have a few questions first, if you don't mind helping me.
1: what are the spacing/placement measurements for the metal screws.
2: what are the measurements/spacing of the back bracing?
Thanks so much for posting this, it will be perfect for my needs!
k24tea 11 years ago
Samw 11 years ago
You aren't the only one who has asked me this. I think I will try to upload a sketchup file (if that's possible on here) to show how it works.
In brief, the two wide boards across the face act as a brace/stop, they are distanced apart so when the legs fold open, they meet each other at 90 degrees. This is actually a feature I adapted from the original model.
k24tea 11 years ago
blodefood 11 years ago
Would you be able to tell us the weight capacity (up to ? pounds/kilos)? I wonder if it could be made a little wider and two of them side by side would be a double bed.
Samw 11 years ago
spylock 11 years ago
realife11 11 years ago
danamark 11 years ago
Samw 11 years ago
Check out this one http://www.gizmag.com/teal-modular-shelters-campers/24809/
oimmuk 11 years ago
