Folding Table
Intro: Folding Table
I uploaded this video on YouTube on how to make this Cedar folding table. Here's some more detailed instructions if you would like to build it. It's a pretty easy project, and can be done in a weekend. I chose Cedar for this project, it's a great outdoor wood that holds up well.
STEP 1: Choosing Lumber, and Hardware
I had to resaw the boards I used in the video, but if you use 1/2" lumber it will speed up the build a lot.
You will need,
7' 3" x 3 1/2" x 1/2 lumber for the top, and bottom supports.
11' 10" x 1 5/8" x 1/2" lumber for the legs, and table pot supports.
12" of 3/8" dowel,
7 1/4" of 1" dowel
24 #6 1" screws
STEP 2: Cut List
The four top pieces are,
15 1/4" x 3 1/2" x 1/2"
Two bottom supports are,
13" x 3 1/3" x 1/2"
Four legs are,
20 1/2" x 1 5/8" x 1/2"
Supports under the top are,
14" x 1 5/8" x 1/2"
Eight pieces of 3/8" dowel
4 at 1 1/8"
2 at 3/4"
2 at 2"
One piece of 1" dowel
7 1/4"
STEP 3: Sanding
Sand all the pieces to the same thickness.
A surface sander makes this very easy, but not necessary
STEP 4: Drilling the Holes
Using a drill press will make this much easier, and more accurate.
All the 1 5/8" x 1/2" support pieces need a 3/8"drilled 7/8" from one end. The 20 1/2" pieces also need a 7/8" hole drilled 9 1/2" form the opposite end. Two of the 14" x 1 /58" supports also need a hole drilled on the edge, this is the 1/2" side. find center-7" and drill a 5/8" these will be the stops for the top of the table.
STEP 5: Rounding the Corners
I used a bottle cap to mark the corners, this can be done with a compass as well. Mark all the corners on the 1 /58" pieces, and the 13" x 3 1/2". Only two of the 15 1/4" x 3 1/2" pieces have the corners rounded, on one edge. I used a spindle sander, this works well for rounding the corners.
STEP 6: Installing the Dowels
Glue in the 3/4" dowels into the 14" piece you drilled a 5/8 hole on the edge. The 2" dowels, are glued into the 20 1/2" pieces. Glue the 1 1/8" into 14" supports. (Not the ones with the 3/4" dowels) Let the glue dry before assembly. The 20 1/2" legs go on the outside of the 14" supports with the 3/4" stop dowels. The 14" supports go on the outside of the other 20 1/12" leg. The last two 1 1/8" dowels, are glued in to the 20 1/2" piece for the cross brace, glue them on the outside leg.
STEP 7: 7 1/4" X 1" Dowel
Find center on the dowel, I used a center finder to do this. Drill a 5/8" hole in each end, about 1" deep. Install the dowel/handle into the 2" 5/8" dowels, don't glue them in.
STEP 8: Finish
Put your finish on the legs before assembling the top.
STEP 9: Install the Top, and Lower Supports
I used #6 1" screws
Square the two top pieces up. I used a 1/8" spacer between the dowels, and two pieces. Use a tape measure to measure the overhang on each side. Pre drill for the screws, I used a square to lineup with the supports. Screw the 15 1/4" pieces to the inside support with the dowel stops. The lower support is screwed to the inside leg 1 1/5" down from the top piece.
Flip the table over, and repeat this process. The only deference is you screw the pieces to the outside supports, and outside legs.
STEP 10: Apply a Finish to the Top
Slow motion table opening,and closing
Apply a finish to all the remaining pieces, and let dry.
27 Comments
David Chafe 3 months ago
telesphorelalancette 2 years ago
Great little project for the week-end.
Do you think I should stain the parts before assembly?
Any tips if I want to make a dozen?
I have a friend who's a bush pilot and he organizes a yearly meeting for pilot/camper on an old decommissioned airfield and I'm sure he'd be a hit with those.
Muzikji 8 years ago
Thank you so much,well done really.
I'm planing to do it, but first I had to convert to metric for all my tools are so, and numbers came out absolutely crazy!, I don't know if I round it up it will work or not, but I'll give a try
I think there is something not right in this paragraph:
"Two of the 14" x 1 /58" supports also need a hole drilled on the edge, this is the 1/2" side. find center-7" and drill a 5/8" these will be the stops for the top of the table."
drilling a 5/8" into a 1/2" side?
FredP28 4 years ago
drclaus 3 years ago
jackhealy2017 3 years ago
FredP28 4 years ago
Packmon47 5 years ago
jli15 5 years ago
What is the dimension of this folding table? What if I want to make a tilting table top (like a drafting table top)?
PeichingL 6 years ago
Thank you!! This is very handy. I made it to fit my desired size and into a chair instead of a table. Works very well.
VanderleiS2 7 years ago
It has the measurements in centimeters?
Thanks!
gsgates 7 years ago
I had one of these tables a long time ago in an RV we had, it was the handiest thing. Very strong, yet very compact to store for travel. Bought a new RV and remembered that table and thanks to youtube I have a table like this again. 4 hours and 3 cedar fence boards later. Thanks for the video.
Carl Jacobson 7 years ago
Yonatan24 8 years ago
That's so cool! I need to make one of those too!
Carl Jacobson 8 years ago
Thank you!
LisaM70 8 years ago
repairguy03 8 years ago
I built a very similar table in high school back in the 60's. It was made from Douglas Fir for durability,I like the looks of Cedar but find it to be too soft to stand up to heavy abuse. The project looks good nice job.
firechildc 8 years ago
Could this be used as a stool? Any idea of how much weight it would hold? Excellent build, btw!
I use it as a stool too, and I'm 180
NarayanK 8 years ago
Thank you so much to share the brilliant idea to make the folding table
