Introduction: Folding Table
I uploaded this video on YouTube on how to make this Cedar folding table. Here's some more detailed instructions if you would like to build it. It's a pretty easy project, and can be done in a weekend. I chose Cedar for this project, it's a great outdoor wood that holds up well.
Step 1: Choosing Lumber, and Hardware
I had to resaw the boards I used in the video, but if you use 1/2" lumber it will speed up the build a lot.
You will need,
7' 3" x 3 1/2" x 1/2 lumber for the top, and bottom supports.
11' 10" x 1 5/8" x 1/2" lumber for the legs, and table pot supports.
12" of 3/8" dowel,
7 1/4" of 1" dowel
24 #6 1" screws
Step 2: Cut List
The four top pieces are,
15 1/4" x 3 1/2" x 1/2"
Two bottom supports are,
13" x 3 1/3" x 1/2"
Four legs are,
20 1/2" x 1 5/8" x 1/2"
Supports under the top are,
14" x 1 5/8" x 1/2"
Eight pieces of 3/8" dowel
4 at 1 1/8"
2 at 3/4"
2 at 2"
One piece of 1" dowel
7 1/4"
Step 3: Sanding
Sand all the pieces to the same thickness.
A surface sander makes this very easy, but not necessary
Step 4: Drilling the Holes
Using a drill press will make this much easier, and more accurate.
All the 1 5/8" x 1/2" support pieces need a 3/8"drilled 7/8" from one end. The 20 1/2" pieces also need a 7/8" hole drilled 9 1/2" form the opposite end. Two of the 14" x 1 /58" supports also need a hole drilled on the edge, this is the 1/2" side. find center-7" and drill a 5/8" these will be the stops for the top of the table.
Step 5: Rounding the Corners
I used a bottle cap to mark the corners, this can be done with a compass as well. Mark all the corners on the 1 /58" pieces, and the 13" x 3 1/2". Only two of the 15 1/4" x 3 1/2" pieces have the corners rounded, on one edge. I used a spindle sander, this works well for rounding the corners.
Step 6: Installing the Dowels
Glue in the 3/4" dowels into the 14" piece you drilled a 5/8 hole on the edge. The 2" dowels, are glued into the 20 1/2" pieces. Glue the 1 1/8" into 14" supports. (Not the ones with the 3/4" dowels) Let the glue dry before assembly. The 20 1/2" legs go on the outside of the 14" supports with the 3/4" stop dowels. The 14" supports go on the outside of the other 20 1/12" leg. The last two 1 1/8" dowels, are glued in to the 20 1/2" piece for the cross brace, glue them on the outside leg.
Step 7: 7 1/4" X 1" Dowel
Find center on the dowel, I used a center finder to do this. Drill a 5/8" hole in each end, about 1" deep. Install the dowel/handle into the 2" 5/8" dowels, don't glue them in.
Step 8: Finish
Put your finish on the legs before assembling the top.
Step 9: Install the Top, and Lower Supports
I used #6 1" screws
Square the two top pieces up. I used a 1/8" spacer between the dowels, and two pieces. Use a tape measure to measure the overhang on each side. Pre drill for the screws, I used a square to lineup with the supports. Screw the 15 1/4" pieces to the inside support with the dowel stops. The lower support is screwed to the inside leg 1 1/5" down from the top piece.
Flip the table over, and repeat this process. The only deference is you screw the pieces to the outside supports, and outside legs.
Step 10: Apply a Finish to the Top
Slow motion table opening,and closing
Apply a finish to all the remaining pieces, and let dry.
26 Comments
1 year ago
Hi Carl!
Great little project for the week-end.
Do you think I should stain the parts before assembly?
Any tips if I want to make a dozen?
I have a friend who's a bush pilot and he organizes a yearly meeting for pilot/camper on an old decommissioned airfield and I'm sure he'd be a hit with those.
7 years ago on Introduction
Thank you so much,well done really.
I'm planing to do it, but first I had to convert to metric for all my tools are so, and numbers came out absolutely crazy!, I don't know if I round it up it will work or not, but I'll give a try
I think there is something not right in this paragraph:
"Two of the 14" x 1 /58" supports also need a hole drilled on the edge, this is the 1/2" side. find center-7" and drill a 5/8" these will be the stops for the top of the table."
drilling a 5/8" into a 1/2" side?
Reply 3 years ago
I agree and have the same question.... how do you drill a 5/8" hole in a stock that is only 1/2" (= 4/8") thick? But no comment from the author of the plan.
Reply 2 years ago
Guys, the hole goes into the narrow 1/2" side, in the direction of the 1 5/8" width. It's for the stoppers I believe.
2 years ago
Question about measurements. You say 5/8" hole in 1/2" side. Which is correct? Instructions are not clear about which dowel goes into which hole. Very confusing. Made cuts, drilled holes...can't figure out how to put it all together. Can you help?
3 years ago
And another question to the author. In "step 4 ; Drilling holes" it says - quote: The 20 1/2" pieces also need a 7/8" hole drilled 9 1/2" form the opposite end. - end-quote. My question is.... Which dowels going into this hole? I have according to the instructions a) 3/8" diameter dowels and b) 1" diameter dowel. Neither of them fit into this hole. Maybe I just miss something in the plan :-(.
Question 4 years ago on Introduction
Nice job.If I wanted to make one 24" high. What would the measurements be. Thanks Bobby
What is the dimension of this folding table? What if I want to make a tilting table top (like a drafting table top)?
4 years ago
Thank you!! This is very handy. I made it to fit my desired size and into a chair instead of a table. Works very well.
6 years ago
It has the measurements in centimeters?
Thanks!
6 years ago
I had one of these tables a long time ago in an RV we had, it was the handiest thing. Very strong, yet very compact to store for travel. Bought a new RV and remembered that table and thanks to youtube I have a table like this again. 4 hours and 3 cedar fence boards later. Thanks for the video.
Reply 6 years ago
Thank you! They're very handy, I use it all the time.
6 years ago
That's so cool! I need to make one of those too!
Reply 6 years ago
Thank you!
7 years ago
How do I make the stand, that holds 6 foldable bedside stands?
I built a very similar table in high school back in the 60's. It was made from Douglas Fir for durability,I like the looks of Cedar but find it to be too soft to stand up to heavy abuse. The project looks good nice job.
Could this be used as a stool? Any idea of how much weight it would hold? Excellent build, btw!
I use it as a stool too, and I'm 180
7 years ago on Step 10
Thank you so much to share the brilliant idea to make the folding table
Very rare to find instructions to build this table. Thanks for showing how it is built. It would be nice to see a slow fold and unfold.
Thanks.
