Four Hour Kayak!
Intro: Four Hour Kayak!
You can build a kayak of green willow shoots, a blue tarp, some wire and Grip Clips in just four hours!
STEP 1: The Amount of Willow Used to Make the Kayak.
amount of willow used. You can use any flexible saplings or branches.
STEP 2: Some of the Willow Is Twisted Into Ribs. Some Into Stringers.
Some of the willow is twisted into ribs. Some into stringers. The largest two ribs are 16" by 27".The stringers are overlapped 2' 3" (this makes the stringers stronger in the middle where they need it the most.
STEP 3: You Can Tie the Willow Together But It Is Faster to Use Wire and a Visegrip.
Use galvinized wire about 1/16' and bend it into this shape:
STEP 4: And Use a Vise Grip to Twist Them:
Give a general description of your Instructable
STEP 5: Ribs Joined to Stringers
Here you can see ribs joined to the side stringers. Note cords on the two mid-stringers making the bottom of the boat flat. If not flat, the boat tips over too easily.
STEP 6: Completed Frame.
Completed frame. Length is 11.5'. Stringers are about 15' long and overlap the two center ribs. The center ribs are 27" wide and 16" deep. The next out from the center ribs are 19" by 14". The smallest ribs are 13" circles. Spacing of the ribs is 17", 17", 24", 24", 17", 17".
STEP 7: A Blue Tarp, 12' by 9', Was Used to Cover the Frame.
A blue tarp, 12' by 9', was used to cover the frame. The tarp was gathered along the top of the boat and fastened together with six Grip Clips: http://www.gripclips.com
STEP 8: The Boat Turned Out Great! It Handles Well in the Water,
The boat turned out great! It handles well in the water and is good looking. Total cost about $40; includes tarp, Grip Clips and binding materials.
STEP 9: Only 22 Lbs!!
Kayak is for flat water only. In fast water boat could collapses on you and pin you in. Always wear a life jacket.
STEP 10: This Boat Is Intended for Flat Water Use and Not for Use in White Water.
If the tarp is pinched between rocks and the boat's frame, it can be punctured. Two tarps layered or a nylon-reinforced tarp is stronger. However, since the blue tarp is easy to obtain and can be repaired with duct tape or with a patch of tarp material and silicon rubber as a glue, the blue tarp kayak makes a lot of sense for most conditions. Wear a life jacket at all time. Flotation devices such as inner tubes should be added inside both ends of the boat for additional safety. To make a stronger boat you can cover the frame with heavy coated nylon or vinyl. You can also make the frame of thicker wood. silicone rubber can be used to seal the gathering at the stern and bow by applying a generous amount between the layers before securing (this is not necessary unless you plan for the seam to be under water). This boat is intended for flat water use and not for use in white water. One reason for this is if the boat was crushed against a rock, the frame could collapse or brake pinning you in the boat and preventing you from swimming to safety and possibly drowning you.
48 Comments
zkelemen 5 years ago
made it :)
steve.schmor 9 years ago
Great little project for a dad and youngster. You could use larger zap straps instead of wire and also put some branch strips for a seat or bring a small piece of plywood so it's more stable to sit in. don't forget the duct/gorilla tape.
beopkik 10 years ago
camping crazy 11 years ago
hossweightlifter 12 years ago
Djembejim 12 years ago
You can buy them in a pack for 5 dollars at home depot, and tarps are a bit more on the expensive side
ddenny3 12 years ago
Terivia 13 years ago
wakefiec 13 years ago
jtpoutdoor 13 years ago
ilpug 13 years ago
pitzhr 13 years ago
militiaguy 13 years ago
Mbrito 14 years ago
rowerwet 14 years ago
rock climber 14 years ago
bongo matt 15 years ago
linuxlifer 15 years ago
lowpro 15 years ago
marian h 15 years ago
