From Spoon to Broadhead
Intro: From Spoon to Broadhead
This instructable will teach you to turn a normal spoon into the blade for a broadhead and subsequently affix it to a field tip.
Tools:
-anvil/hard surface
-vice
-hammer
-pliers
-dremel and various bits
-table top grinder
-soldering kit
-blade sharpener
Supplies:
-spoon
-field tip
STEP 1: Hammer It Flat
Hammer the spoon flat.
Draw your broadhead outline.
STEP 2: Cutting the Shape
Affix your spoon handle into the vice.
Place a cutting disc onto the dremel.
Cut the two sides off the spoon, giving you a nice triangle.
*Do not cut the handle off yet!
STEP 3: Grinding the Edge
Use the table top grinder to shape crude edges.
The spoon handle makes it a lot easier to grind the edges.
STEP 4: Field Tip Preparation
*You can use either a hollow field tip that is glued onto a shaft or a solid field tip that screws into an insert.
Here I use a solid field tip. The same steps applies to both solid and hollow field tips.
Clamp the field tip horizontally in the vice.
Cut the tip off using the dremel.
Clamp the field tip vertically in the vice.
Cut approximately half way through the field tip.
STEP 5: Lose the Handle
Time to get rid of the spoon handle.
Clamp the handle in the vice.
With the dremel cut the outline of a square into the broadhead.
Then cut the handle off.
*I cut a small square into the broadhead to facilitate the field tip as seen in the pictures.
Take the dremel with a grinding bit now and narrow on either side of the broadhead to make it easier to fit the field tip onto the broadhead.
STEP 6: Combine It All
This part can be a little tricky.
You may have to grind down either side of the broadhead till the field tip fits.
Vice the broadhead and lightly hammer the field tip into the space.
STEP 7: Solder It Together
For this step I used a mini butane torch since my soldering iron wasn't hot enough.
Fill the gaps with solder. Allow to cool.
With a dremal, a cutting tip and a grinding tip, get rid of the extra solder.
Clean up the broadhead with the grinding tip and a wire brush tip.
STEP 8: Finishing Touches
Use the sharpener to give the broadhead a razor sharp edge.
23 Comments
Markstern 2 years ago
The most difficult bit to do without electricity would be the soldering (unless you can find/own a butane powered iron) I'd wager.
This last part is simply my opinion but I wouldn't do any of this on a standard benchgrinder, no appreciable work saved and it's far too easy to grind off too much etc.
weldor 9 years ago
GwanTL 9 years ago
I'm not exactly sure what kind of solder I used. I'm not exactly what one would call an experienced welder. This was my way of getting some practice in using as few purchases as possible. I'll go pick up some 15% silver solder like you suggested for my next project. Which is by the way a two-blade broadhead, meaning that the solder job is doubly important.
Thanks for the useful suggestions welder!
weldor 9 years ago
GwanTL 9 years ago
I do have an oxy acetylene torch but I do not have a place to use the torch until the summer.
weldor 9 years ago
dewnorth 9 years ago
Is this how Daryl Dixon never runs out of arrows? ;-)
Dukanater 9 years ago
this is a rly good idea but i think you should take it a step further do the whole project like you had to make arrows for some apocalyptic scenario so basically all hand tools no electricity and i challenge you to make the whole shaft not just the arrow head =p lets see you shine
stierney2 9 years ago
@Dukanater - these were "made" from 3/8" hardwood dowels. All done by hand, sanding and shaping, as well as the fletching, etc. The only thing that used "modern" technology was the adhering of the field tips...
GwanTL 9 years ago
That's a tall order. Ignoring the shaft of the arrow, the metal alone would take a long time and a lot of effort to grind an edge down without a table top grinder.
The shaft itself is a different kind of challenge. Because you could go simple and just throw a hollow field tip on the end of an appropriately sized tree branch. Or you could go fancy, age the wood properly, cut it down to size using hand saws and smooth out cylindrical shape using sand paper. But again, that would take a lot of time and effort.
I don't think I'm skilled enough yet to tackle such a challenge.
j-vega 9 years ago
Now, I need a crossbow, congratulations.
MaryLenehan 9 years ago
Dukanater, I'm with you. I worry there won't be any electricity left when I need to do this - come The Zombie Apocolypse...
GwanTL 9 years ago
Luckily in the event of an apocolypse of any kind there will likely be ample supplies sitting around.
So since your broadheads will run out (due to damage from use) long before your shafts and feathers knowing how to make broadheads from stuff that there will be an abundance of is a good idea. I'm looking into trying to use old tin cans and metal road signs. Both will be far easier to cut and form a sharp edge without power. They would literally be single use due to how weak the metal is but they should be sharp enough to hunt with.
Carmelite 9 years ago
A better source of metal might be from old x-acto blades, broken hacksaw blades, or putty knifes.
GwanTL 9 years ago
Good point. Although the grand majority of commercial broadheads are single use anyway. If used for hunting, bones will be cut but also shatter and/or seriously damage the blades.
I used spoons since it's easy to get a lot of them and the general shape of the spoons makes it easy to work with. I have some old single layer frying pans and circular saw blades that I will be trying next.
Wolfbane221 9 years ago
GwanTL 9 years ago
Thanks for the tips! Next time I'll try your suggestions.
GwanTL 9 years ago
I have'nt tried it out yet, but the weight is comparable to a store-bought broadhead. After I shoot it a few times I plan on cutting holes in certain spots if the weight causes an issue.
Captain MacTavish 9 years ago
My father told me that you should want to have the weight in the front instead of the back but if its too heavy then yeah you know
