Fun With Oogoo: Make a Folding Indoor Frisbee
Intro: Fun With Oogoo: Make a Folding Indoor Frisbee
Make a folding flexible Frisbee that fits in a pocket. It is thin and light and it collapses when it hits things so it can be used indoors fairly safely.
This instructable will also show how to make a mold using Oogoo and how to cast Oogoo in an Oogoo mold.
The short video shows the Frisbee flying and hitting glass.
STEP 1: Materials
Corn starch-found in grocery store.
Linseed based oil paint from an art store
Naphtha solvent-found in hardware stores
Or Citrus Solvent from: http://www.dwellsmart.com/Products/Lumber-and-Wood-Products/Citrus-Solvent
Can of spray lacquer-found in hardware stores.
100% Silicone caulk- found at Walmart for about $3.
Caulk gun found at Walmart
Small paint brush
Plastic knife
Plastic mixing cup
Frisbee or pie tin or plate to use as a pattern for the mold.
STEP 2: How It Works
Oogoo is an inexpensive, easy to use silicone clay that can be cast into a flexible Frisbee that is thin and light. As the step 2 pic shows, Oogoo has incredible shape memory and even when compressed will bounce back to its original form.
The cast Frisbee is thin and floppy, but when it is set to spinning in a toss, it regains the original shape of a Frisbee. It is a little trickier to throw, but it has similar flight characteristics to a regular Frisbee.
For more details on the uses of Oogoo see here: https://www.instructables.com/id/How-To-Make-Your-Own-Sugru-Substitute/
STEP 3: Make an Oogoo Mold of a Frisbee
Mix The Oogoo And Mold The Pattern
A mix of 1 part corn starch to 1 part silicone caulk is used to make the mold. Mix up about 8 tablespoons of silicone with an equal amount of corn starch.
Mix up a batch with the plastic spoon and then use it to coat the Frisbee with a thickness of around 3/16" to 1/4". As the Oogoo gives off acetic acid fumes, it is a good idea to do this outside or near a fan. Vinyl or nitrile gloves are recommended.
Finishing the Mold
After the Oogoo has set up for an hour or two, mix a small batch of fresh Oogoo and put enough on the bottom of the mold to support the bottom and sides. Flip it over Frisbee side up and put it on a piece of polyethylene plastic on a flat surface. Let this set up over night.
The thumbnail pic shows the finished Oogoo mold.
Finishing the Mold
STEP 4: Casting the Oogoo Frisbee
Spray Mold Release
A couple of thin coats of spray lacquer on the mold will keep the casting Oogoo from sticking to it. It dries fast, so you only have to wait about ten minutes before giving a second coat.
Mix Oogoo Gel
Mix up some Oogoo with a 2 silicone caulk to 1 corn starch ratio. I found about 4 tablespoons silicone to 2 tablespoons corn starch was enough to make the Frisbee. About the volume of 2 peas of linseed based oil paint were added to color the mix.
Add Naphtha solvent until you have the consistency of a gel. WARNING: the Naphtha has nasty fumes so this should be done outside with good ventilation while wearing vinyl or nitrile gloves. A less poisonous solvent like Citrus Solvent can be used instead, but it is more expensive and harder to obtain. It also takes longer to cure.
Coat the Mold
The gel consistency makes it easier to spread the Oogoo thinly in the mold.
Spread the Oogoo gel thinly in the middle ( about 1/32" to 1/16") and thicker ( about 1/8") on the circumference. A small paint brush can be used to smooth it out while still wet. The step 4 pic shows the coated mold.
Remove The Cast Frisbee
After the Oogoo has cured, carefully peal the Frisbee from the mold. Bits of lacquer flakes may be stuck on the surface. The sticky side of duct tape can be used to remove them. The step 4 thumbnail shows the finished Oogoo Frisbee.
Mix Oogoo Gel
Coat the Mold
STEP 5: Other Possibilities
Paint A Frisbee
A thinner mix of Oogoo can be made using more solvent and painted into the mold. This will result in a much lighter and more flexible Frisbee which will probably be trickier to throw.
Extruding Oogoo
The step 5 pic shows a large wiffle ball made with extruded Oogoo. You can throw it at high speed and it flattens when it hits to distribute the force harmlessly. The Oogoo was extruded using a 50cc syringe. The lines were extruded on a plastic ball and then pealed off after the whole thing cured. Where the lines cross each other they tend to fuse together. All kinds of wiffle balls, juggling balls or lamp shades could be made using this technique.
3d Printing
The Oogoo extrudes so well I am working on making an automatic extruder that could be used in a 3d printer. I have also been experimenting with additives that vary the density of Oogoo from very hard to super flexible.
Extruding Oogoo
3d Printing
22 Comments
dmorphew1 7 years ago
I am in the process of trying to extrude and 3D print with Oogoo. What mixatures and methods have you used for 3D Printing?
Corinbw 9 years ago
I really want make a waffle ball. I have the materials, but I was wondering how thick the oogoo should be for extruding?
mikey77 9 years ago
A 3 to 1 mix of silicone to corn starch, by volume, works well.
Mix in small batches, 3 tablespoons or less, so that it does not set up in the syringe while extruding.
Corinbw 9 years ago
if I don't have a syringe, then what do I use... A plastic bag does not work very well, it just breaks
Corinbw 9 years ago
Such a great instructable for something big fun and useful out of oogoo
critopadolf 10 years ago
cccincocc 10 years ago
Your instructables are fantastic and the Citrus Solvent tip is GOLD!
roelofdevilliers 10 years ago
Xthinker 11 years ago
mikey77 11 years ago
hawkfrost64 12 years ago
coast2coastcreator 12 years ago
kwe 12 years ago
could you tell us more about the aditives you've tried please
would 90°alcool work?
thanks
maralyn1969 12 years ago
germeten 12 years ago
iminthebathroom 13 years ago
mikey77 12 years ago
The problem to be solved with 3d printing of Oogoo is coming up with a reliable valve that can almost instantly stop and start the extruding Oogoo which is under pressure.
iminthebathroom 12 years ago
roliop 12 years ago
You could mold the Oogoo on the inside of the Frisbee and that would work. But if you look carefully at a Frisbee you will see lumps and ridges on the outside (top) that are designed to make the Frisbee more aerodynamic. You have to cast the outside of a Frisbee to get a precise duplicate of a Frisbee.
Also, the purpose of this instructable was not to simply make a Frisbee that will fold up and fit in a pocket. It was to show how to cast Oogoo in an Oogoo mold which can be useful for making other things..
