Garage Door Does Not Close
Intro: Garage Door Does Not Close
It was late in the evening. My wife had just come home. The garage door did not want to close when she pressed the button on the remote. It had worked just fine a few hours earlier. My tools are in the garage. Leaving it open all night is not an option.
STEP 1: Force It to Close?
This is the hard wired switch on the wall. She was able to make it close by holding the pressure plate on the switch down until it had closed.
STEP 2: Signs to Observe
The light on the ceiling mounted opener flashed as she held the wall switch down to close the door. That is not normal.
STEP 3: The Sensors
This is one of the sensors. There are two. One sends a beam of infra-red light to the other. If anything interrupts this beam of light, the garage door will not close and the ceiling light on the opener mechanism will flash as mentioned in the previous step. This is, of course, a safety feature to prevent the heavy garage door crushing anyone or anything that might be in the pathway of the door when it comes down. Check to be sure no child's toy or anything else blocks the path for the infra-red light beam.
The text box feature would not save when I did this Instructable, so I am overlaying colored arrows as keys to my explanation.
Most garage door problems can be traced to the sensors. The circuitry inside the sensors is quite reliable and has a long life. The first thing to check is the mounting brackets (blue arrow). Did something bend them so the sensors are no longer aligned? A quick visual inspection of each should be sufficient. In doubtful cases, you can stretch a long string between the sensors to see better if they are aligned.
The red arrow points to the LED. Each sensor has an LED. It should be bright and show a solid color. Some are green and some are red, depending on the manufacturer of your opener unit. One sensor on our unit showed a bright steady LED. The other, this one, was weak and it fluttered rapidly. That, together with the flashing ceiling light and the need to hold the switch button, are signs something is not right.
The yellow arrow points to the lens. It should be clean on both sensors. This garage is my workshop. It is always possible sawdust could have accumulated on the lenses. As a precaution, wipe them with a rag or a tissue.
The green arrow points to the wire that runs between the sensor and the opener unit on the ceiling. Look for obvious physical damage (bare wires, loose connection, cut or broken wire, etc.)
STEP 4: What, Exactly, Could Be the Problem?
We do have a manual for our opener unit, but its troubleshooting section tells you how to check a few basic things, and then says, "You may need to call a technician for repair service." I am not much in the mood to wait for a technician at the time I want to be going to bed, if I can find one who will come late in the evening.
It has been two years since I had problems with a garage door opener, and that was a different unit than this one. I forget the procedure for troubleshooting one of these units. I have come to go on-line for help on the occasions when the garage door opener fails to work. After a quick search for "garage door opener troubleshooting," I opened this page. There are some general help pages, but they do not offer much more assistance than our manual and its suggestion to call a technician after checking a few basic things like obstructions to the infra-red beam and power to the circuit.
Help suggestions are often very brand specific. The image with this step is a chart for diagnosing problems with the sensors on a Genie garage door opener. Look closely and you can see that Genie gives diagnostic clues and codes in how many times the LEDs flash and in the color of the LED that shows something unusual. Our unit is not a Genie, but a Liftmaster. The help sections for Liftmaster units are more general and not very helpful.
STEP 5: The Solution
I know from past experiences that the electrical connections to the sensor must be good, or the door opener does not work properly. I had already checked for obstructions to the infra-red beam, for power to the system, cleaned the lenses on the sensors, checked for alignment of the sensors by looking for bent brackets and so on. I grasped the small plastic plug at the end of the wire and pulled it out of its socket on the sensor. It required quite a strong pull. Do not pull on the wire, but on the plug. It may seem there is a catch that must be released first, but there is not. When I put the plug back into its socket, the LED no longer fluttered and the garage door worked properly once again. In time these connections corrode slightly with oxidation. Breaking and making the connection again is enough to restore its function. And, I did not need to call a technician.
40 Comments
sukkar.steven 3 years ago
I'm currently experiencing troubles with my garage door at my new home. It has no problems going up but when I click down it goes about 3cm and reverses. The door has no sensors and I don't think it ever did. Any ideas on what to do?
Thank you in advance
Phil B 3 years ago
roymarsh2 3 years ago
Phil B 3 years ago
JeanieB15 4 years ago
GammaFlat 5 years ago
BTW - both lights should always be on unless there is an obstruction or the sensors are misaligned (probably covered above).
(after removing the sensor from the bracket)...Taking the sensor box apart is not difficult. First press HARD at the seems while holding against a hard surface to "crack" the glue or whatever is holding it together. Then try to get something thin between the seam and pry.
Due to rules started in California, solder may not contain certain "dangerous" elements (I think lead). Unfortunately, due to this, a good solder connection has a shelf life where intermittent or permanent connection problems can occur in soldered joints over time.
If you don't have the will to do this, sensors are available online and even at Home Depot for 30 to 50 bucks new.
bobbalkcom 6 years ago
After spending an hour this morning with a garage door that keeps reversing (has been acting funny over the last week) and on live chat with Genie - I finally got the door to go down - and Genie to say that I needed to call in to their help line. Once the door was down I went to the coffee shop to search online help - came across your site/question/answer.
Thank you! I am now convinced the sensors have something to do with this. Will check when I get home. It is a new opener - month and a half or so - has been working fine. Was thinking it was the door though it was serviced last year and appears fine - operates fine - nothing blocking sensors.
You have given me something to check. Thanks!
adidame 6 years ago
Thank you for posting!
Phil B 6 years ago
ChristopherP230 6 years ago
We have a large 8' wooden garage door opener with a new Chamberlain opener and the sensors are fine and alligned, but the door opens fine but it will not close? I've tried incresing the power to the down control and still will not close. It gets to a certain point and stops and when you press the button again it goes up and this cycle continues. Please assit if filmiar
Phil B 6 years ago
I do not regularly repair garage door opener systems, and can go a number of years between troubleshooting problems with one. When you say yours is new, does that mean it is freshly installed and not working, or does that mean it had been working, but now will not go down? I am guessing the door encounters some form of resistance it interprets as an obstacle it should not crush and it stops. Is something binding? Can you operate the door smoothly by hand when it is released from the opener linkage? While the door is released from the opener linkage does the linkage travel across its normal full range? Those are some things I would check.
NinjaDude 7 years ago
Thanks! Your instruct able made me look like a smart guy. I only wish I had made it seem like an all day job. I finished this in record time, then had to do more on my honeydew list.
Phil B 7 years ago
Eclipse2975 7 years ago
Phil B 7 years ago
GuaysheenE 7 years ago
Thank you sooooo much! I had the same problem and after following your clear instruction. It works!! My garage door opener is working properly now. The problem was the two sensors didn't line up.
Phil B 7 years ago
BettyJ6 8 years ago
That is a tough situation since no one wants to leave their stuff unprotected with the door open. I wonder if there was something blocking the beam at the opening? That would make it so it wouldn't want to close. Checking the springs might be a good idea as well. http://www.cbgaragedoors.com.au/repairs-and-services12
JohnS265 8 years ago
Phil B 8 years ago
