Garmin GPSmap 60(CSx) Battery Power Fix = More Rugged GPS
Intro: Garmin GPSmap 60(CSx) Battery Power Fix = More Rugged GPS
I have a Garmin GPSmap 60CSx handheld GPS. I have used it while hunting and boating. Lately, the gps has started to shut down itself. It is very annoying when the power goes out when you need the device.
The device works flawlessly when powered though USB-connector or Garmin power connector. Power issues are only when used on batteries. There has to be a problem with how the batteries are connected to the board.
The problem was also more frequent when boating because of the vibration.
Clearly the connection is not rugged enough. So I decided to dissassemble (and reassemble) the device.
STEP 1: Remove the Back Cover
The back cover is held with six screws and glue at the antenna side. It was quite easy to disassemble, only the glue made me think if I had not found all the screws.
STEP 2: Analyze the Situation
The battery connectors are two clips which are pressed against the GPSboard. I thought that the contact is not good enough. I decided to make bombproof fix. So I took two short wires and soldered them between the battery compartment and GPSboard. First I was tempted to connect battery terminals to Garmin connector. I decided not to, because Garmin connector takes voltages, which are above 10v. The batteries give only 3v...
STEP 3: Solder the Wires
Solder two wires from battery terminals to battery connectors on gpsboard. Select as thin wires as possible.
STEP 4: Reassemble and Enjoy!
Put all back together in reverse order. I found it easier to fix the external antenna connector first. Now my GPS works also on batteries!
12 Comments
Canuck Travellers 7 weeks ago
Great description on the fix for the 60CSx by Saastamo THANK YOU!,
If I may before starting just remove the back cover and push in firmly on the batteries and start the unit while holding in on the batteries, see if the unit comes on, if it does it's definitely needs the fix suggested on this site by Saastamo. Temporary fix for me until I do the permanent fix is to put some tissue inside the battery cover and very firmly pushed it closed and lock it thus shoving the two batteries against the connectors..... but do the authors Saastamo fix to permanently fix the unit.
saastamo 7 weeks ago
Thanks for your kind comments! My 60CSx has been working flawlessly ever since, actually I had forgotten even that I ever fixed it. More than ten years already!
Kfrench1966 5 years ago
This worked perfectly, thank you!
saastamo 5 years ago
You're welcome! Mine is still working 100% no problems.
gmartikyan 8 years ago
Great fix, thank you! I am really disappointed with the Garmin design, though. How does a contact based battery terminal (that oxidize ALL the time) pass any sanity checks in a outdoor, possibly, survival equipment!?!?!?
moody28 8 years ago
BrunoM3 8 years ago
Thank you!! Almost 3 years trying to find a solution.
saastamo 8 years ago
You're most welcome. Two years since my fix and still working with no problems.
BertL 9 years ago
I used a pencil eraser to clean the contact surfaces and bent the battery compartment contacts so they made firmer contact with the circuit board. So far, so good..
saastamo 9 years ago
I also thought first that cleaning would be enough. However, the contacts did not seem oxidized, that's why I chose to do bomb-proof fix. My garmin has been OK almost 2 years in boating use. That means being exposed to heat and water.
Ceddy17 11 years ago
saastamo 11 years ago
