Gesture Controlled Robot Using Arduino
Intro: Gesture Controlled Robot Using Arduino
This gesture controlled robot uses Arduino,ADXL335 accelerometer and RF transmitter-receiver pair.
We will divide the entire robot into 3 parts the transmitter,the receiver and the robot.
The different gestures that have been mapped to the direction of the bot are-
Hand parallel to the ground-stationary
Hand tilted forward-forward
Hand tilted backward-backward
Hand tilted right-right
Hand tilted left-left
I've made the transmitter on thermocol though it can also be made on a glove.
All the code, schematics and other pictures in one place are available here.
STEP 1: Materials Required
For transmitter-
- Arduino Uno
- ADXL335 accelerometer
- 433 MHz RF transmitter
- Breadboard
For receiver and robot-
- Arduino Uno
- 433 MHz RF receiver
- L293D motor driver IC
- Chassis and wheels
- 2 DC motors
- Breadboard
Of course you will also need jumper wires and 9V batteries
Instead of using the Arduino and breadboard in transmitter like I did ,you may instead use an ATMega328p, which can be programmed from the Arduino board and solder it along with RF transmitter and ADXL335 on a perfboard.
The perfboard can then be attached to a glove.However here I've used a remote controller like setup with the gestures the same
STEP 2: Assembling the Robot
Fix the wheels on the chassis.
Mount the DC motors on the back wheels and use dummy wheels for the front.
Mount the L293D IC on the breadboard and place it on the chassis
Place the Arduino on the chassis and make the connections of L293D as follows
4,5,12,13 to GND
1,9,16 to VCC(5V)
3,6 to left motor(output)
11,14 to right motor(output)
2,7,10,15 to pins 8,9,10,7 of Arduino(inputs)
8 to 9V battery
STEP 3: Determining the Direction of Robot
You can learn more about L293D from internet.
Basically ,the motor rotates when the inputs supplied are opposite.
For example high,low may rotate the motor in clockwise while low,high in anti clockwise.
If both inputs are same then motor does not rotate.
The sketch in test.ino will help to determine for what inputs for the 2 motors will the robot move forward. Copy and paste the code in test.ino it in Arduino IDE
In my case it was observed that the bot will move forward pin 9 of Arduino is high,pin 8 is low(for left motor),pin 10 is high,pin 7 is low(for right motor).Try different combinations till you get desired direction. Similarly for moving back the combination is high,low,low,high.The bot will go right if left motor is moving and right is stopped by giving same inputs.Similarly for left.
STEP 4: Interfacing ADXL335 With Arduino
Mount the ADXL335 and on the breadboard.
The connections to Arduino should be as follows.The Arduino should be different from the one used in step 2
ADXL335 ARDUINO
VCC 3.3 V
GND GND
X A0
Y A1
Z open
ST open
Now copy and paste the code in adxl335interface.ino and determine the threshold values for different gestures.
The code gives 2 values xval and yval which will have unique values for different gestures.
Determine the range of values of xval and yval when the hand is tilted forward,backward etc.
STEP 5: Interfacing RF Transmitter With Arduino
Mount the RF transmitter on the breadboard in previous step and make connections as follows.
RF transmitter Arduino
GND GND
DATA D12
VCC 5V
Now download the VirtualWire library from the following link
http://www.pjrc.com/teensy/td_libs_VirtualWire.htm...
Extract the VirtualWire folder from the downloaded folder and paste it in arduino-1.6.1>libraries
Now program the arduino of the transmitter with the code given in transmitter.ino.
Basically what the code does is to map the different threshold values (for gestures) obtained in step 4 to different letters (stationary-'s' forward -'f' etc) which are then transmitted through the RF transmitter.
This step completes the construction of the transmitter
STEP 6: The Receiver
Mount the RF receiver on the breadboard of step 2.The connections to the Arduino used in step 2 are
RF receiver Arduino
VCC 5V
DATA D11
GND GND
Now program the Arduino with the code given in receiver.ino.
The code maps the different letters obtained from the receiver to the inputs for directions.
For instance if the receiver receives the letter "f" corresponding to the bot moving forward,it maps the letter "f" with the inputs low,high,high,low which are the required inputs for the bot to move forward.
STEP 7: Run the Robot
Go to this repository to download the code and schematics.Click on the "Clone or Download" button (green in color on the right side) and select "Download ZIP" to download the zip file.Now extract the contents on your computer to get the code and schematics(in the schematics folder).
The gesture controlled robot is now complete.
Connect 9V batteries to both the Arduinos and the L293D motor supply and run the robot.
I've also added functionality by which the on board led on pin 13 of both the Arduinos is on when the bot is moving and off when it's stationary.You may add more such functionality.
Any doubts and connections be clarified by seeing the comments in the given code.
I've posted a video of the robot below.
93 Comments
snehan 2 months ago
what type of dc motors (model number) are needed?
snehan 2 months ago
how many arduino are to be used?
tejaranganath 4 years ago
Suhaib Ahmad 4 years ago
73sihassan 4 years ago
asmitadagade1999 4 years ago
purvajawale100 4 years ago
purvajawale100@gmail. com
nicaopn 4 years ago
Megha Nas 4 years ago
utkarshbutola 4 years ago
hamna.engineer 4 years ago
RupinderS3 6 years ago
anyone intrested in making this project i will help you contact at rupindersi234@outlook.com
Afridi99 4 years ago
Akashboora143 5 years ago
school2019 5 years ago
In step 2, when trying to connect 8 to 9V, how? 8 from the Arduino is already connected to 16 on the breadboard.
please explain.
DivyamY 6 years ago
bro when i am uploading the receiver and transmitter code ,, errors are coming as ...exit status1... pls help me ... i have to present it by tomorrow ... pls help bro
mayank rajguru 5 years ago
sireddynaveen 5 years ago
