Giant Jenga Diy
Intro: Giant Jenga Diy
Hey everybody it's momo. And today were going to make an outdoor Jenga set/ lawn jenga! Do enjoy!
STEP 1: Supplies
1- sander
2- power saw
3- 8 foot long, 2x4 wide wood
4- (not necessary, but advised) safety glasses
2- power saw
STEP 2: On the Power Saw
Put in a stopper thing so you won't have to measure every time. The stopper should be at 8 and one forth inches away from the blade knife saw thing (as you can see, I don't know much)
STEP 3: Cut
Just simply saw until you have a piece not big enough to be an actual block. You should get 11 full blocks out of each plank
STEP 4: Sand That Puppy
That's a violent title. Anyways, you just want to sand like shown above and sway the piece back and forth, so you sand the whole thing. Do this to all of the edges
STEP 5: BLOCK SIZE (very Important)
As you can see this step is important. It should be 8.5 inches long, 1.5 tall, and about 2.6 inches wide. (Just go in order of pictures AND YOU WANT TO CUT OFF THE AMOUNT SHOWN FOR THE WIDTH) I used 9 planks (11 blocks each plank) after all the math, I got about 4.12 feet tall for the total set
STEP 6: What I Did
To make it more orderly (just a tip) you can put them into a wheelbarrow when you finish cutting and sanding
STEP 7: Finish!
And now you have really cool lawn jenga! Fun to play if you invite some friends over or just something to kill time. Hope you have fun!
STEP 8: If You Haven't Already...
If you haven't already click that button and follow the farm family and give a cow it's wings! Love y'all •_£
25 Comments
Lcomer852 7 years ago
We are having trouble with our blocks sliding. Has anyone had that problem? I tried the wax paper suggestion but it didn't work. Any ideas?
LincolnsCreations 2 years ago
TomS19 7 years ago
Minwax Gloss Polyurethane. My set is stained, so I used Minwax gloss Polyshades, first. Then follow up with a coat of spray Gloss Polyurethane. Always Gloss. Never semi-gloss. Semi-gloss doesn't give it the same "slickness" It takes 2-3 days for all that poly to fully cure, but once it does, you will love the results.
DaveK77 7 years ago
So is it possible to just do the gloss polyurethane without the polyshades first? Or do you recommend staining first for better sliding? Also, do you spray one side at a time, let it dry, then flip over and spray the other side after 2-3 days?
Laurenlouiser 8 years ago
psanute 7 years ago
Correct. 2 X 4s require 10 and 1/2 inch cuts.
TomS19 9 years ago
This is not as easy as it looks. You are dealing with rough framing lumber here. They must be planed down to exact thickness, otherwise you get different thicknesses of blocks. This makes some of them practically fall out while the block next to it is impossible to pull out because it is bearing the weight of the whole stack. I am finding this out the hard way on making this for a client. Plane down your material first! If you're lucky enough to have access to a surface planer...
ve2vfd 7 years ago
I saw an interview with the British lady who commercialized the game (which she learned as a kid in South Afrika a long time ago) and she did specifically mention that the original game was made by hand with all the imperfections that implied. According to her some blocks almost falling out and others being pinned is the point of the game.
When they mass produced the game, planing them into perfect pieces was a problem as it made the game too easy and they had to add imperfections to the blocks in the planing process so they are NOT all the same.
(She and the game Jenga is profiled in season 1 episode 9 of the "Million Dollar Genius" tv show on the History Channel)
BillG41 8 years ago
baleavitt74 8 years ago
Yeah, that was a good way to lose an arm
momoluv 8 years ago
Well, I honestly considered saying something along those lines to the person to whom I was replying, but decided that if you hadn't chastised him for name calling, I'd stay out of it. It is still, however, important to be aware of safety hazards at all times. That was my only point. I meant no offense to anyone. I only wanted to point out the possibilities in demonstrating the operation of the machine in question so unsafely.
That being said, I do wish I had complemented you on the quality of the post. It is precisely what I was looking for and I plan on making project soon. Thanks!
stocktondenos 8 years ago
momoluv 8 years ago
ChandraK7 8 years ago
pkfoss 8 years ago
Momo- Great job! Good instructions for a simple & quick Jenga set. You could have expanded the step 5 instructions a bit to cut down the width to the 2.6" that you want and it would have made it more clear for the people who just scan the instructions looking for errors. I think that if we try to buy some pretty straight 2X4's, we can live without planing the boards as suggested in one response. Making and playing this will be a great activity addition to our 4th of July vacation. Thanks for the inspiration!
BrianaOmundson 9 years ago
The set looks great, but please, please, please don't ever use a saw with crossed arms. You almost gave me a heart attack! Either pull the trigger with your left hand, or just hold the material to the left of the saw. Basic shop safety 101.
wardjm1 9 years ago
I had the same thought....
mommywoman 9 years ago
