Give Your Holga a Custom Look.
Intro: Give Your Holga a Custom Look.
(subscribe to keep an eye out for that instructable!)
So, this will be split into two very different instructables, either instructable could be followed to get two different custom Holgas.
The Holga is a camera made by Lomo, and is well known for being the cheapest and easiest way to get into Lomography.
To help define Lomography I have borrowed this paragraph from Batness' Instructable on 'How to paint a plastic camera.' (I think he may have borrowed it from wikipedia)
There are many people interested in using medium-format plastic cameras to take photos these days. Translation; film cameras are back in! Using this retro type of camera, you can take "vintage" ye-olde looking photographs.
This new trend was likely started by Lomography . Lomography emphasizes casual, snapshot photography. Characteristics include over-saturated colors, off-kilter exposure, blurring, "happy accidents," and photographers are encouraged to take a lighthearted approach to their photos, and use these techniques to document everyday life. (<--oh noes Wikipedia!)
In this Instructable we will cover-
- Removing the viewfinder and replacing it with a useful little light.
- Prepping and Painting the camera.
- Adding a nice layered paper effect on the grips.
STEP 1: Materials, and Tools Needed.
- A Lomo Holga (between £16 and £40 dependant on specifics of the model)
- Black Direct to metal spray paint
- A small LED circuit
- Two Part Epoxy Resin (aroldyte)
- Some pages from an interesting book (mine was a chinese red book)
- Brush on metallic paint (you can bust open a silver marker pen in a push)
- A 46mm step up ring (step up to your most used filter size)
- Some thin scrap plastic
- Black marker pen (sharpie, used for touching up in some areas)
- Masking tape
- PVA, Woodglue, Elmers Glue
- Scalpel, X-acto, Stanley knife, Boxcutter
- Drill
- Small files
- Paint brushes
- plyers (may be used for breaking some plastic
- Soldering iron (optional, if you are wiring up your own led circuit)
- Small flat head screwdriver
- Medium cross head screwdriver
STEP 2: Remove the Top Section.
To remove the top of the Holga, we first need to remove the film advancing knob.
Carefully slide a thin screwdriver under the knob, and rotate it slightly to allow you to get a firm hold, pull straight up to break the bond between to knob and the advancing spool. The glue is strong, but also cheap, so can be easily broken.
Once you have this removed you will see two small screws, these plus another screw on the opposite side need to be removed also.
Lift the entire top section straight up. If you have one of the versions with a flash, you will need to make sure you do not loose the little black plastic switch.
Be sure to discharge your camera flash fully, so as not to shock your self on the flash circuit.
STEP 3: Fitting an LED
With the advice in hand I went about making better use of the space.
This may vary a little if you are using the non flash version of the camera.
First you need to slide out the two plastic elements that make up the viewfinder, hold onto the front one, we will use that later.
Using your pliers slowly bend the plastic side of the veiwfinder until it becomes weak and snaps off.
I had already sourced an LED circuit from a cheap torch, which I also cut out the battery holder from. We still want to change the batteries easily, so I made this hatch face the outside.
Using a combination of a sharp knife, and your pliers, and even a coping saw, enlarge the rear view finder to accommodate your battery holder.
I also drilled a hole to the side of the battery holder to fit my push switch from the circuit.
Using epoxy resin glue the LED, battery holder and switch in place.
The last three pictures show the camera with the switch fitted, and a test of the LED.
STEP 4: Reassemble.
The main suggestion I have is that if you struggle to get the flash switch to stay in place, drill a small hole into the switch, and screw in a spare screw, allowing you to hold the switch without it falling inside the camera.
If the top does not sit right, turn the advance spool until it clicks into the metal stopper. Then it should sit in.
It can be a bit fiddly, but you will get it eventually.
Put the screws back in, be sure not to open the camera up too often, as it is very easy to chew up the screw holes, which are only made of plastic.
STEP 5: Paint Job.
I used my favourite 'direct to metal' spray paint, I know its only a plastic camera, but its a good paint, and I know it will stick.
First, slide of the metal clasps at either side, they should slide up and off if you hold the metal tab away from the camera.
There are four main areas to mask off.
- The lens area
- The flash
- The viewfinder section where the LED is on the front
- The small window on the back to show where the film is.
The first layer will not cover it. Leave about 5 minutes between each coat, if you spray so much that the paint looks wet, that is probably too much, and will take an age to dry.
Once the camera has been left for an hour or two (preferably over night), we can attach it with some silver paint.
Pour a tiny amount of silver paint onto a flat surface (some scrap card) dab a little onto a brush then brush off the excess onto another scrap of card/paper, once the excess has been removed you can slowly start to brush it onto the camera, repeat until you have the depth that you want.
STEP 6: The Step Up Ring.
You could add this on before you painted the camera, but it would be hard to try and paint the outside of the ring, while not gunking up the threads on the inside.
The 46mm step up ring is just about the right size to screw into the front of the camera, to allow it to screw in smoothly run a sharp blade around the inside lip to remove a little material.
Try screwing in the ring, if it does not seem to want to go in after an attempt or two, take a little more off. Repeat until you get a good fit.
If you take too much off, and if it feels a little loose, just pop a few dabs of glue in as you screw it into place.
STEP 7: Custom Grips.
Here are a few suggestions for what you can use -
- Old Comics
- Newspaper
- Magazines
- Books
- Books in other languages
- Old wrapping paper
We start by tearing up the book, I found it much easier to cut out some pages with a knife first.
My book lending itself to be torn up into strips, where as a comic book may do better being torn up into small squares. (decide what effect you think will look best.)
Once you have a nice pile of paper, its time to get gluing. I suggest doing all of the following just with your fingers, much easier, and alot more fun.
I suggest PVA (Elmers, or Wood glue), it dries as a plastic, and is hard wearing.
Spread some glue onto the camera, a nice even layer, then start placing some pieces of paper on, every time you put a piece on, squeeze a little bit onto your finger and cover that piece in more glue, keep going till you have covered the areas you want.
With it being paper you can easily layer it up, when dry it will appear more see through, so be sure to get 2-3 layers of paper over all of it.
Once it is dry (give it at least 24 hours) we can go about trimming it down at the edges, if you do it carefully you should be able to feel the edge of the various areas, if you do cut too much off, or make a mistake, just patch it up with glue and paper, and try again!
STEP 8: Finished!
The great thing about this tutorial is that a different coloured paint, and a different type of paper can be used to create a very different effect!
Anyone who posts a picture below of their Custom Holga (using this tutorial or not) will get a Custom Holga Patch from myself!
Thank you for reading, and be sure to let me know what you think in the comments.
15 Comments
crazyg 11 years ago
McGrep 12 years ago
ekoh 13 years ago
noahh 13 years ago
HotPinkBulb 13 years ago
Batness 13 years ago
Great job! I do love me some Holgas. I'm thinking of painting mine or layering fabric on it somehow...just haven't narrowed it down.
I guess I'd better; I want a Holga patch! XD I'm terrified that I'm going to ruin the flash when I take mine apart...I might have to use a non-flash Holga.
=SMART= 13 years ago
Lithium Rain 13 years ago
caitlinsdad 13 years ago
Clayton H. 13 years ago
