Grocery Bag Hot Air Balloon
Intro: Grocery Bag Hot Air Balloon
Facts about hot air balloon
Hot air balloons (in the east known as sky lantern) fly when the air inside the hot air balloon is less dense than the air surrounding it. Hot air is less dense than cool air; the heated air causes the balloon to rise simply because it is lighter than an equal volume of cold air. Buoyancy is an upward force that the air exerts, and it helps hot air balloons and blimps stay in the air. A hot air balloon uses a heat source to heat up the air inside the balloon.
This is an instructable of making a hot air balloon from a grocery bag.
The reason I did this instructable was my passion of hot air balloon.
References:
STEP 1: Items
Items (This items are easily get from your local store)
- Grocery bag (I find the biggest ones)
- 4 drinking straws
- String
- Needle
- Candle
- Sticky tape
- Aluminium foil
Tools
- Scissor
- Lighter
STEP 2: The Frame
- Firstly, I attach every ends of the straws with the sticky tape. (I make sure that the usage of the tape are just adequate as not to add extra weight to the frame)
- I tape the straws so that the angle of each corner is 90 degree.
- When finished, it will look like a square.
STEP 3: The Platform
- I cut the thread into two and tie the threads in the middle (the thread should be long enough to be tied at each corner of the frame later).
- Then, I cut the aluminium foil in square.
- Using a needle with the thread, I link every corner of the squared foil. (Be very careful not accidentally tear the foil in the process)
- To secure the fixture, I attach the sticky tape in the middle.
STEP 4: The Carriage
- I tie each thread's end to the frame.(you need a lot of patience and nimble fingers)
- The facing downside will be the side with the tape and the facing upside is without the tape.
- In the center of the foil, I will put a candle (or a few).
STEP 5: The Balloon
- I attach the under carriage to the grocery bag with stick tape.
- Then, I light the candle and let the bag expand slowly. (It will take a while before the balloon is fully expand. You can add additional candles to quickly assist the process)
- I test the balloon for a while before let it go to rise.
- Please watch the test flight video.
FYI, I burn a few balloons before I succeed :D
HAPPY MAKING!
Please don't forget to vote for me.
31 Comments
fraggle_rock 7 years ago
Please think twice (or three times) before littering the countryside with material that can cause such damage to wildlife and has the risk of causing uncontrolled fires.
If you must make one then ensure that everything in the construction will bio-degrade rapidly and with as little fuel as possible.
Don't use plastics at all!
http://www.rspca.org.uk/adviceandwelfare/litter/ch...
IxoraStrawberry 7 years ago
Thanks for commenting :)
plasticbaldy 7 years ago
I've seen this done with a cotton ball soaked in methylated spirit instead of a candle and a bigger soaked & lit cotton ball on the ground under the balloon to initially fill it with hot air. Obviously best done in winter when the air is cold and ground is wet so you don't get to spend time in jail as Bubba's wife for starting a bush (forrest) fire.
15ashworthh 7 years ago
I have been experimenting with this idea for a wile i will give yours a try and see if it works
Thanks for commenting.
I have been experimenting with this idea for a wile i will give yours a try and see if it works .
AlexAndAmigos 7 years ago
cool
cool
Demascus 8 years ago
IxoraStrawberry 8 years ago
SunithaV1 8 years ago
superb!!!!
