Guitar Hero Controller FIX Extra-Strum(FIX SWITCH)
Intro: Guitar Hero Controller FIX Extra-Strum(FIX SWITCH)
How to fix the strumming switches of your guitar controller!
This is my first instructable, i hope to be as clear as possible.
WARNING!!!!!
DISCLAIMER: Before we go any further in the instructable, you must know that this Mod/fix can leave your strum broken, so try this fix under your own risk. I'm not responsible for any damage that may happen.
This is the way i fixed my down-strum switch, which was giving me two strums when doing one strum, causing to miss the notes frequently.
I tried to find how to repair this problem by searching the net, and i didn't find anything helpful other than "BUY A NEW GUITAR". Why should i have to buy a new one just for one darn switch!
So i tried to find the answer myself.
This time i'll be using a 3d representation of the switch, because i thought the switch was broken or something i didn't took any photos coz i wasn't confident that this could work, and then when it worked i was too lazy to reopen the whole thing just to take some pics. (COZ I WAS ROCKING HARD YEAH!)
Note that there are wrong parts in the 3d representation. I did the 3D mainly by memory so there are wrong parts, but the examples are good enough to give an idea of what's inside the switch.
I will update the instructable with photos next time. My up-strum switch will be needing a tuning soon, so I'll take photos of the process.
What You'll Need:
- Solder
- Guitar Controller
- Screwdriver (that fits in the screws)
- Soldering iron
- Solder paste
- Game to test
UPDATE:
WARNING!!!!!
What You'll Need:
- Solder
- Guitar Controller
- Soldering iron
- Solder paste
- Game to test
UPDATE:
STEP 1: Prepare Your Guitar Controller.
First of all you need to open your guitar. I used a flat head screwdriver to open mine and worked good.
Once you've opened your guitar you will see the circuit boards, the one we'll be using is in the middle of the guitar where its placed the strumming bar.
We're gonna unscrew the four screws in the middle of the circuit board. I did it this way coz it's still firmly attached to body of the guitar and it serves as a support for unscrewing.
Then we're gonna unscrew the other 4 screws and lift the board.
STEP 2: Taking Off the Switch
Once the board is free, turn it to see the other side of it.
Take off the plastic with the holes to free the switches. This plastic prevents the switch to move and break its pins while you're strumming.
Now we melt the solder of the switch we want to fix, try to not delay too much or you can melt the plastic that holds the metal pins.
Take off the excess of solder of the metal pins, otherwise the switch will not open.
Now you have the switch in your hand!
STEP 3: Open the Switch
Now we try to open the switch by bending just enough the "T" plastic that holds the two pieces together. Then pull the two pieces and open the switch, take care when doing this step, the inside parts will fall when you open the thing, these parts are two, a spring and a metal "J".
Now we can fix the problematic part.
STEP 4: Problem and Solution
Here are the parts you'll find in the switch. The problem is located in the 4th piece of the image, the problem is in the fork-shaped metal.
In the images you can see why the extra-strum is happening. When the white plastic goes down (top of the switch) as you strum, it moves the lever thing of the plaque that at the same time moves the fork pins and this makes contact with the other metal plaque,sending the signal.
In the 5th image you can see the problem in side view, what we want to correct is the inclination of the fork pins by pushing them as in the last image, doing this simple thing will correct the extra-strum and you will be happy. ;D
STEP 5: Switch FIXED
Now all that rests is to put everything in place and close the switch.
Remember that this 3D model where made by memory, so there are mistakes in the scale and place of the pieces, but this references are good enough to give you an idea of whats inside.
Put the pieces back in the plastic case, close the switch and re-solder it to the circuit board. Connect your guitar to your console or PC and test the switch with your finger, if you're satisfied with the feeling of the switch, then you can proceed. Put the plastic holder of the switch and screw the plastic to the circuit board. Then screw the other four screws and put the cover of the guitar and screw till its finished.
NOW ROCK ON MAN!!!! YEAH!!!!!
I hope this instructable was helpful and easy to understand. Thanks for watching it and/or comment.
27 Comments
michaelcesar37 3 years ago
sorry for my english, i'm using the translator
Ro-mico 3 years ago
Saludos.
romulofarias37 4 months ago
Jadwer 2 years ago
andre.hankedoamaral 9 years ago
nice vid man, but did you find the switch for replacement?
mattbuffardi 4 years ago
https://www.ebay.com/itm/REPLACEMENT-STRUM-SWTICH-GUITAR-HERO-5-LES-PAUL-PS3-XBOX-360-NINTENDO-WII/293478013314?hash=item4454a71982:g:fGkAAOSw2EZc-rP8
dsrabelo 4 years ago
Ro-mico 4 years ago
Sorry to hear that you couldn't fix it. The originals seem to be White Alps or off-brand. What I've seen is that this company http://matias.ca/switches/click/ makes mechanical keyboards with switches that recreate White Alps, here's an ebay link of those types of switches. https://www.ebay.com/itm/3x-NEW-Matias-ALPS-Keyboa...
These seem to be original White Alps
https://www.ebay.com/itm/1-x-SKCM-White-ALPS-Repla...
Some time ago I couldn't find any switches with two prongs like the Alps, just the Cherry types which have three.
Look for those on ebay, those seem to be accurate for the guitar controller.
Wish you luck.
DustySeven7 13 years ago
AdeptCain 9 years ago
I can tell you that these are not Cherry MX switches, these are a proprietary brand, the pin placement is different, and even if they were Cherry MX switches, they'd be blues, because blues are the only clicky ones. Blacks are very heavy linear switches (no click, no bump) for heavy typists, which I use in my keyboard at home. Just pointing it out so that people don't buy a Cherry MX black keyswitch to replace these switches, because I'm not sure if they'd fit straight away, and they would feel VERY different. That said, I just ordered a couple of MX reds to put in to my GH3 guitar, so if they fit, and require a little modification, I might make an instructable for people in the future, as Cherry MX switches are made FAR better than the junk that comes stock in these guitars. :)
Ro-mico 9 years ago
They look the same.
I looked it up just to make sure.
http://deskthority.net/try-f29/the-switch-try-bag-...
If it works, please make an instructable. Cheers! :)
It looks like the stock switches are clones of ALPS switches, not sure which model, but they're just branded with GT-X, not ALPS, but with the ALPS button bit. Cherry MX switches all have the + type part at the top
Ro-mico 13 years ago
But I'm cheap and I prefer to repair things than buying replacements. BTW the other day my GH world tour guitar was doing double strumming and I fixed it, I didn't have to de-solder (is that correct?) the switch from the PCB, and now works just fine.
I'll be doing an instructable off of this "new" fix. Now I just have to find some time to do it.
I really appreciate your comment, 'cause I went on to do a "lot of research" to find a replacement switch and realized it was better for me to try and fix it, you know, 'cause its free.
Best regards.
ClickCLK 10 years ago
Hey, Ro-mico, I just registered an account here to say huge thanks to you, this guide is awesome. I tried several times to understand how this switches are working, but with no luck. Your guide really makes clear what the cause of the problem is and makes it very understandable. I hadn't done this steps already (2am now at my hometown), but I will do it tomorrow for sure, and I already know that it will work like new if I do all this right. Thank you, from all of my heart. Tomorrow I'll get 600k score on TTFaF at last!
P.S: I have a keyboard with cherry MX Brown switches and they doesn't look like switches on x-plorer, so I think that's not a cherry MX switches...
Ro-mico 10 years ago
Since I did the instructable, six years ago, I haven't needed to fix it again. I also fixed my GH World Tour Guitar that had the same problem. Still plays like new.
Poggle566 10 years ago
I've been wanting to update this instructable for a very long time, it's just...(lazy-me just can't).
Well. The controllers in which I have done the things I said in the Instructable are: GH3 Xplorer Xbox360; Guitar Hero World Tour Xbox360. In both cases the insides were almost identical, the switches are the same model. So I think this could work just fine with your guitar. Just remember if you want to fix it, be as careful as possible.
This time I really want to put a video of me doing the repair. So, if you want to wait till tomorrow, I'll put the video (finally) in the instructable. Just so you get a better idea of what to expect while trying to fix your controller.
Cheers!
tory bowen 12 years ago
Ro-mico 12 years ago
Be very careful with the replacement :)
See ya!
