HOW to Make a Usb Mini Aquarium ( for Shrimps)
Intro: HOW to Make a Usb Mini Aquarium ( for Shrimps)
This instructable show you how to make a mini aquarium that work great for sea monkeys , triops .... Powered by LEDS connected to the usb port of your computer. IT's great office decoration :-)
For this project, you will need:
_light bulb ( i used 200w for her big size)
_wire hanger
_ small wood block
_USB cable(any will work)
_ a 100ohm resister
_ LED ( any color you want)
_hot glue
_plastic herbs
_wire hanger
_ small wood block
_ a 100ohm resister
_hot glue
_plastic herbs
STEP 1: THE LIGHT BULB
First you have to clean the light bulb, for this , remove the top black part of the light bulb (Copper Connector) with a scissor and break all the glass part inside it (look the image) and than clean inside it using a toothbrush and some water untill it become clear as much as possible .
STEP 2: The WIRE HANGER
Take the wire hanger and bend it like in the image than drill a small in the wood block and glue the hanger to it .
(see the image)
(see the image)
STEP 3: The LED
Now take the usb cable and strip it . connect the red and black wires to the resister and the LED( see the picture) and glue it on the wood block.
STEP 4: DECORATION
Glue the plastic herbs to hide the cables on the wood.
STEP 5: Finish!!!!
Finaly glue the light bulb to the wire hanger like in the picture and connect to your computer usb port :-D
add some shrimps ( sea monkeys ...) or some really small fish (i recommend 1 fish because of the size)
16 Comments
Onixgato 8 years ago
I like it very much, but I'll be making a bigger version with a bowl instead of a bulb for really small fish. I don't remember what they are called in English, but you can have a few of them in something as small as this with no problem. Congrats for a great project.
jamie.l.balyeat 9 years ago
Um, hello? Are you people aware of how MICROSCOPIC brine shrimp are? This is more than big enough for sea monkeys, this is even bigger than the tank they give you in the kit!
I've also raised and BRED wild guppies in less water than this. You guys don't know what you're talking about... this is perfectly suitable for some very small fish or planktonic invertebrates
dragonkid165 8 years ago
Ranie-K 13 years ago
19charbel96 13 years ago
SURE it will be torture device for bigger fish (goldfish ...)
and i have said: "I recommend 1 fish because of the size" in the last step.
rallekralle 9 years ago
seriously? a betta wouldnt even fit in this
never put live animals in this tiny tank for more than about an hour
the crafting guy 10 years ago
hi, I just made one and was wandering how to get the shrimps in thanks:-)
fish_dude 10 years ago
1 guppy needs about a gallon of water to survive
awesomecreations 11 years ago
jgosselin 12 years ago
19charbel96 12 years ago
_bright and use small amount off electricity
_long life span because in this instructables the led is glued so you can't change it easily
_very bright and colorfull
THanks for watching :)
bellafuzz 13 years ago
Anyways, this is really cool :)
frusciante 13 years ago
