Hack for Cleaning Inside Sliding Window and Door Tracks
Intro: Hack for Cleaning Inside Sliding Window and Door Tracks
The Simplest Instructables are usually the best. Here is an effective easy way to clean inside any sliding window or door track. It requires minimal supplies and works extremely well.
STEP 1: Marking the Sponge
Place a regular kitchen scrub sponge on the track of the window or door. Using a marker, put a mark on the sponge where each piece of track is. It doesn't matter how many tracks there are as long as the sponge is wider than the track.
STEP 2: Cut the Sponge
As the title says use a knife and cut down the lines on the bottom of the sponge. Cut the full depth of the sponge, this may take several passes with the knife.
STEP 3: Clean Away
Wet the sponge in warm soapy water and push it down the track. When the sponge gets to the end of the track there may be larger debris left just vacuum it out and push the sponge down the track again.
STEP 4: Done
All done! Now your windows and doors will slide quietly and easily.
28 Comments
RogiO 1 year ago
chrisehlers2x 1 year ago
WendyTrethewey 1 year ago
Toolsthatbuild 1 year ago
edward_og 1 year ago
tem494 1 year ago
I would suggest using an electric knife for cutting the foam I believe it will make a cleaner cut.
Eusébio Neves 4 years ago
Toolsthatbuild 4 years ago
farmboy79 4 years ago
snowf7 4 years ago
chuckstake 4 years ago
ferrotype 4 years ago
Any thoughts on what to do to clean up the "mold" that accumulates in window sills after being shut tight for 6 months?
etriker 4 years ago
