Halloween 2009: "Fire" Breathing Dragon With Articulated Wings
Intro: Halloween 2009: "Fire" Breathing Dragon With Articulated Wings
This is a slide show to demonstrate the signature prop from our Halloween 2009 yard haunt. Her name is Puff, naturally.
Our theme was Haunted Castle, and the name of the Castle was "Dragon's Lair Castle".
There were 2 instructables that were very useful in this dragon prop,
For the wings:
https://www.instructables.com/id/Articulated-Wing-Framework/
I took this design, and scaled it up 50% and added a double acting air cylinder for control. If doing the wings again, I would consider aluminum channel rather than pine strips, as at 50% larger, plus the air cylinder the weight is becoming an issue.
The fire light effect is based on a 3W RGB Led driven by a custom microcontroller circuit and using code heavily modified from this instructable:
https://www.instructables.com/id/Flickering_LED_Candle/
I changed the hardware to drive about 300mA per red / green / blue segment, and to change the color slightly as a function of the brightness. The controller board is a bit over featured since I intend to use it for other things in the future.
The construction of the dragon was as follows (photos were unfortunately not taken for the first step, so I may have to add a few sketches to this slide show) Update: I found a couple photos taken on a cell phone and have added them.
- A metal frame made from 'Unistrut' (an L shaped metal angle that has holes every inch) bolted into the rough shape of the dragon (you can see the detail in the early photos)
- Strips of cardboard were glued to the metal forming a series of rings at various diameters, bigger in the middle, and tapering near the neck and tail.
- A shop vac extension hose was threaded from the neck to out the bottom of the dragon, to connect to a fog machine. The fog will blow across the high brightness LED which flickers, and this should create a plausible fire effect. A length of speaker wire was also run at the same time to provide power for the LED fire and for the non-flickering LEDs in the ping pong ball eyes.
- Paper Mache was used to cover the cardboard with newspaper using a standard flour and water paste. The final coat of paper mache was with white paper towel used to give a a primer coat and a nice texture.
- The dragon was painted with poster (tempera) paint. A final coat with clear gloss spray paint gave a nice sheen.
This project would not have been possible without the support of my friends who helped in paper mache and painting and setup (Matt, Ross, Lanah, L, B, Irene, Charlotte, Tara, Tim, Tom) but most of all I would like to acknowledge the contribution of the creative director and my lovely wife Rose, who both contributed wonderful imagination and lots of hours of time to this effort.
Please enjoy.
For some additional pictures, including lots of the trick-or-treaters
Here is a slideshow video set to music (Video created by IdaRose Sylvester)
For the wings:
Please enjoy.
15 Comments
UniKitty75 10 years ago
popscott3 13 years ago
TheRavenKing 13 years ago
porcupinemamma 14 years ago
neilh 14 years ago
Why Thank You! That is a wonderful thing to say. Sadly, we are some distance from you, just south of San Francisco, California.
--Neil.
Some Dork 14 years ago
neilh 14 years ago
tmboyd 14 years ago
lhotchki 14 years ago
neilh 14 years ago
Scruggs 14 years ago
kenexinator 14 years ago
to creep people out
l8nite 14 years ago
rachel 14 years ago
