Hidden Blade - Assassin's Creed Inspired
Intro: Hidden Blade - Assassin's Creed Inspired
Hey there I've been working on a this project on and off this summer. (mostly this fall)
As you can see it's A hidden blade, I started with a ,desk drawr slide ,some sheet metal (For the blade and part of the trigger mech) ,a few nuts and bolts ,and some thick steel wire. also a paper clip or 2 bent into some small springs.
I'll be building 1-2 more after i finnish this one i'll be making an instructable for those. This one's kinda the test dummy.
30 Comments
McJarod_ImLovinIt 8 years ago
great for a prop, but sheet metal is NOT ideal for blades, too flimsy and very likely galvanized. if you are into actual knife making, and you have a forge or propane torch try heat treating with some higher carbon steel, this will harden it. but never forget to temper it as well
Steam_powered-grapefruit 8 years ago
https://m.instructables.com/id/Assassins-creed-hidden-blade-10/
Quintus19 8 years ago
i agree
amcmorris1 11 years ago
the shadow creed 9 years ago
dude id love to help it seems pretty easy just do everything that the hidden blade has to have but then weld a peace of bent metal at the end
yourallygod 8 years ago
well you need the hook to be durable for the pulling and all that the actual thing will need to be able to withstand and hold human weight along with the fact that it would need to not fall off so it is pretty difficult to make the hidden hook blade thing :P
the_burrito_master 11 years ago
the_burrito_master 12 years ago
Luca Vermeer 10 years ago
xxDarkk 10 years ago
the_burrito_master 10 years ago
Fart burst 11 years ago
Dzucky 11 years ago
justwilliambrown 11 years ago
shadow123456 11 years ago
sonnytunrer13 11 years ago
Annix15 12 years ago
PindaHoofd 12 years ago
