Home-Made Sugru
Intro: Home-Made Sugru
I just came across this awesome and fairly new substance that is called sugru. Sugru is a whole nother class of silicon because it bonds to most materials, and when it sets this stuff is basically indestructible. I didn't really feel like buying this stuff online so i did some searching on line and came across this way make sugru and it was very cheap, in all it probably only cost me $4 to $5 to make around 9 ounces.
STEP 1: What You Need
- silicon caulk (you can get this at any home improvement store)
- A paper cup
- A plastic spoon
- Corn starch/corn flour
- Food coloring
- A paper cup
- A plastic spoon
- Food coloring
STEP 2: The Mix
Put the amount of silicon caulk you want into the plastic cup, the mix is 50/50 so you are going to want to put the same amount of corn starch in the cup as you put silicon caulk.
STEP 3:
you can color this any way you want but I used a few drops of food coloring and mixed it thoroughly until it turned the color I want
STEP 4: Adding Water
Now time to add a very small amount of water, after you add the water mix it around and dump the excess water out. the mix is going to be a little soggy so add a pinch or so of corn starch and mix it in to the mix. now you should be left with a substance like play-do that you can mold, bend, and twist around.
Note: if your mix is still too sticky to use you can put some corn starch in you hand and start rolling the mix around in your hand.
STEP 5: Finished
Now you don't have to go online and get ripped off by the sugru company you can just make your own sugru.
If you liked this instructable please check out some of my others
Please vote, favorite and subscribe to my instructables page,
feel free to comment on this,
Thanks!
Thanks!
20 Comments
joknrok 7 years ago
ErkM1 8 years ago
Innovation_Incorporated 8 years ago
Ive used spray paint successfully too, it just doesn't give as much as a good color.
apple-o 9 years ago
This isn't *exactly* the same as the "oogroo" instructable, because that recipe specifies linseed based oil paint for color and this one specifies food coloring.
The last time I was at Home Depot, I looked in the paint department and could not find any linseed oil based paint - can anyone recommend where to find this, either online or at a national chain (and if so, a specific brand or product)?
wolf68_at_gmail_com 8 years ago
Linseed based paint is usually over with the wood Home Depot has it for around $23/Gal, You can get on home depot.com and order it if your local store doesn't have it. They will ship it to the store for free.
chartle 8 years ago
A little late but you want to go to a craft store or artist supply and get tubes of oil paint.
I found a begiiners asssotment of paint for maybe $6.
muddog15 10 years ago
It may harden like Sugru, but will it rip off like regular sugru does?
Tamaresque 10 years ago
Apolo8 10 years ago
Somethingtotallyrandom 10 years ago
Nick-Smith-513 10 years ago
jeffandstuff 10 years ago
paintchick 10 years ago
Cekpi7 10 years ago
Penolopy Bulnick 10 years ago
