Home Made 2.5" to 3.5" IDE Converter
Intro: Home Made 2.5" to 3.5" IDE Converter
So I needed a hard drive for a project and all I had was a 60GB 2.5" IDE one, unfortunately this project used a standard IDE cable and I don't have/don't want a 2.5>3.5 inch converter.
So I wasted an afternoon soldering 44 tiny wires onto a connector.
I went to this link to find out how the 44 pin 2.5" ide hard drive was numbered.
As I understood it, the top row was every odd number and the bottom row was every even number.
I split up a standard IDE cable and stripped 3/4 of a cm of coating off the ends. Then I looped it in half to form a flat oval shape.
I tinned the wire next, put it in the contact area, and heated it up to melt the solder.
The plug that I soldered to was one from a laptop, the adapter plug was designed so that it would be easy to swap a bad HDD for a good one. I suppose it was made so it would be (somewhat) easy to solder to as well.
Here are some pictures of the results, I currently have Windows XP installed on it and it works great.
15 Comments
magnam 6 years ago
good work, gonna try it.
robcam 6 years ago
Nice work
jhavel1 9 years ago
Nice work. BTW you can buy a 3.5 to 2.5 IDE adapter for around $1 (one) dollar on ebay. LOL.
svishnupurikar 9 years ago
hi , I want to attach laptops HDD to computer.... looking at your DIY cable ,I have question.
what about the power supply to HDD; if i sholder I solder pin1 to pin40 ;what to solder for power supply pin41?pin42?pin43?pin44?
zack247 9 years ago
hi there! If you compare the pinouts of the 2.5" drive (http://pinoutsguide.com/HD/Ata44Internal_pinout.shtml) and the standard 3.5" drive (you can find it on the same website as the other link) it will all make sense for you. If I recall correctly, its mostly pin-to-pin, but the 2.5" drive also has power on the same connector, which is why it has the extra pins. Just compare the two pinouts and all of your questions should be answered. :)
Andruha1123 12 years ago
knexsuperbuilderfreak 12 years ago
zack247 12 years ago
Nostalgic Guy 13 years ago
I remember making one of these back in the early 90s for my Commodor Amiga A1200.
i made the mistake of showing a couple of friends & the next thing I knew i had made almost two dozen of them..... lol
zack247 13 years ago
Still it did save a lot of friends a lot of time playing games like Beneath a Steel Sky which if I remember correctly came on thirty 1.44mb floppy disks & sometimes required forur disk changes just to go down a flight of stairs to another room lol
its surprising that they chose to encode the game that way though.
mr.incredible 13 years ago
