Homemade Laundry Detergent
Intro: Homemade Laundry Detergent
I wanted to
A. Save money
B. Be ecologically phosphate free
If you learn from my mistakes your results will surpass mine in both respects, I am sure.In addition to my clothes coming out "so fresh and so clean, clean" it was a very satisfying and aesthetic making process!
A. Save money
STEP 1: Gather Materials
You wil need:
Food processor
1 bar laundry soap like Fels Naptha or Zote, or Ivory - Zote can be found in hispanic grocery stores
1 Box Borax - found in the laundry aisle
1 box Washing Soda or Oxi Clean, orBaking soda - (Washing Soda AKA soda ash AKA sodium carbonate available in some grocery stores made by Arm and Hammer or you may find it art supply stores in the dyeing section)
OPTIONAL- essential oil of your choice, I didnt do it but I think tea tree might be nice.
Some recipe considerations, there are many variations to be found online but I based mine on this here http://www.thegreenguide.org/article/diy/household
Powdered Laundry Detergent
# 1 Cup Grated Fels Naptha Soap
# 1/2 Cup Washing Soda
# 1/2 Cup Borax
# For light load, use 1 Tablespoon. For heavy or heavily soiled load, use 2 Tablespoons.
I adjusted for the fact that Zote is at least twice as big as a Fels Naptha bar, and personally if I'm going to make a mess I'd rather double or triple the recipe which still easily fit in the food processor, also I used baking soda AND oxi-clean instead of the washing soda, the reason being that I could not find the washing soda, and Oxi-clean is essentially the same thing but with added peroxide* which does add a mild bleaching action, should be "color safe" though. It is also my understanding that baking soda is similar to washing soda but half as alkaline, so using baking soda will give you a gentler blend.
*note don't try and make the liquid recipe behind the link with "oxi clean" because the peroxide will make the whole mess foam, that was what I originally tried -- and ended up with useless semi solid foamy spooge.
Food processor
# 1/2 Cup Borax
STEP 2: Grate Your Bar
I used the ultra pink Zote laundry bar though the recipe called for Fels Naptha (or you could use Ivory), this is where I wonder if it's actually phosphate free, but look at the color! yummy pink shreds! you may want to cut the bar down a bit before stuffing it in and using the grating disk attachment.
STEP 3: Add Other Ingredients
The big shreds of the bar soap might not dissolve as is, so you will need to change to the chopping blade of your processor, and now is the time to add the powder to the bowl of the food processor and blend it till it is fine, and don't huff the particulate OK? it will feel and taste beyond gross.
STEP 4: Conclusion
Clothes came out great!
But not sure if ....
A. that Zote is phosphate free, and (EDIT: someone commented that phospahates have been illegalized anyway, havent fact checked that though)
B. the purchase of the oxy clean sure drove my cost up, next time I will find the Washing soda.
borax 3.59
baking soda .75
Zote .75
oxyclean 5.00
= 10.09
But since one or two little scoops are enough I estimate about 75 washes? so that comes out to .12 a wash, I guess even using oxi clean it's not so bad.
borax 3.59
baking soda .75
Zote .75
oxyclean 5.00
= 10.09
328 Comments
IvyR6 7 years ago
Hi, I have been wanting to try to make my own laundry detergent but I can't find Borax in my country. Can I use Oxyclean instead?
MarioL111 5 years ago
The borax is good for complexing metal ions that cause water hardness, which will cause soap scum with the Zote, but not necessary. Baking soda is useless compared to sodium percarbonate (Oxi-Clean) as a cleaning agent. You have technically made a soap with added surfactants, not a true detergent. By the way, just sodium percarbonate in the washer does a great job in hard water.
Debra000 7 years ago
you really do need Borax.. my email is below.. im so crazy about this ...maybe I can get you some if its legal
UNSEPARABLE TECHSCIENTIFICS 6 years ago
COOL MIXING!
EXCELLENT!
: D
knarker 7 years ago
Sounds like a winner! I just read an article about the benefits of doing laundry in cold water so just wondering how well this detergent works in cold water?
what I do for cold water.... I START machine on HOT just enough to gather about half a cup in a plastic glass...put two tablespoons of my dry detergent mix in and stir for a half min..dissolves fast..switch over to cold water..you are all set
hi again...I took several photos but their in my ipad..im on desk top
I made this yesterday and am about to go collect neighbors wash!!!!! I made about a years worth and have found that about 2 tbls is all that's needed..whites are awesome..cuts construction type dirt completely..Ill never use store bought detergent again.. I used Zote,Washing Soda, Baking sods, Oxiclean ,borax AND sented crystals. ..dhendriks33@gmail.com for those that want "dry powdered detergent" instead of the cooking method
CurtisS27 7 years ago
pattiemelt 7 years ago
However - washing soda & baking soda are NOT the same thing. Baking soda's chemical makeup is NaHCO3 (1 sodium, 1 hydrogen, one carbon, and 3 oxygen molecules). Washing soda's chemical makeup is Na2CO3 (2 sodium, 1 carbon, and 3 oxygen molecules).
For those of you who can't find washing soda but do have baking soda, there is good news & an easy fix. You can make washing soda out of baking soda. Just spread a thin layer (probably 1/4 inch or less) of the baking soda on a cookie sheet, sheet pan, large cake pan or something oven-proof & bake it at 400 degrees F for an hour. Mix & bake for another hour or until the powder turns dull & yellowish. Now you have washing soda.
mdshay 7 years ago
I did that but it didn't turn yellowish, and it never turned "grainy".
It did become exothermic with vinegar, however.
( I baked it for about 4 hours.)
jessiejw8 7 years ago
I can't find household soap in the UK to use these home made powder recipes. Can you suggest a brand from the UK for me please. Love this. I want to save money and be environmentally friendly too. Thank you Jessie
jannie.lloyd 7 years ago
I've been out of the UK for several years so don't know if it's still available but Fairy used to do a Laundry Soap.
CazRaX 7 years ago
Your group is closed and not taking any new members, so posting this "info" is just teasing and not at all useful. This type of comment is not very constructive since all you are doing is saying that this is being done wrong, you know the answer but you won't tell us.
DennisS4 7 years ago
So why do you say homemade laundry detergent is not good? I think you should explain because you did post on a page that is how to make homemade laundry detergent. Thank you in advance for your explanation.
randi_s 7 years ago
sleepblack 7 years ago
I've been making this for years, using Zote, because of my Eczema ridden daughter, I use three bars of Zote (bought from Big Lot .90 ea) 2 boxes of Washing Soda (from Walmart or Meijer 2.99 ea) and 1 box of Borax (Walmart or Meijer 2.99 ea), I have in the past added a small container of and oxiclean like product also from Big Lot, I didn't notice a difference. It works great.
KatieB103 7 years ago
OMG> the thought of having to go to BigLots, Walmart and Meijer just made me sick to my stomach! But I guess your batch reduces trips to the store. So that's good!
